My 84 extra cab is gone. Tacoma build now.
Started by Hyena, November 21, 2004, 12:25:12 PM
panhard keeps the axle/truck frome moving side to side.  :)  got to have it with a 3 link non-wishbone style suspension.
Doof
thats what i figured, just wasnt sure if it was right or now
i read on pirate if you keep it level or a little negative to the frame/axle it will help with body roll.  right now it is level and it is at ride height axle to frame wise.  the front should drop another inch or so when i put the tires on it.  of course that is after i get everything else done lol.
Doof
haha yea... i cant wait to see that thing on the trail
are you gunna try to have it done for the roundup? or just when it gets done its done
trying for the roundup, but i don't think i will make it.  probably going to have to find a new job here soon.  my shops moving 45 minutes away and i can't afford the gas for that kind of a commute.
Doof
that blows.... try the airport, see if they need a welder if you can do weld AL
I don't want to weld anymore.  its freakin' killing me.  especially aluminum.  thinking about law inforcement.
inmyownsummerami
WHITE WHEEL ROCK CRAWLERS "If your wheels ain't white, they ain't right"
:greengrin:My 1st Gen. Toyota SAS (2wd to 4wd) :greengrin: (In Progress)
RIP "Goody Goods" My DDW Brother
slabcs
What's a roundup without Brad's truck on its side?  It just wouldn't be the same.
Relentless
ToYocRawleR
If i get another ticket i swear im just going to become a cop.  I doubt theyd take me though.
Rigs:
05 F-250 Powerstroke
93 RunneR ...Build-up  http://board.marlincrawler.com/index.php?topic=85644.0
fortysixandtwo - I drove through Dunsmuir once I dont think anything there is "super nice"
Just kidding man. I guess there is, its your bed
kiyul4130
you better make the round-up. im sure i wont be wheeling anywhere till then. it will be our rigs maiden voyages
-kiyul-
ECV 7-11
KYOTA FOREVER
#2381
won't make it at this rate.  the only way i would come close is if i find a cheep set of air shocks to throw on there.
Got a package today.  need to drill out the hole in the steering arm to 1 inch tomarrow at work, then i can fab up a mount and put it on.
kiyul4130
weak, its gunna break. needs more triangulation, in thanks for the chance!
-kiyul-
ECV 7-11
KYOTA FOREVER
4DEES
Is That A Single Ended Ram?
***ROCK BRAWLERS~Southern Cali***
www.rockbrawlers.com
'85 Toy, 42's and a body lift!
ROCK IT TILL THE WHEELS FALL OFF!!
yep!  got a tie rod in the front, ram will be in the back going directly to the drivers side steering arm.  should have pictures up tomarrow of it halfway mounted.
4DEES
Quote from: Hyena on June 24, 2008, 08:17:41 PM
Hmmmm.... That Sounds Cool, Was Wondering Why You Went With A Single. Sounds Like It Should Work Pretty Good Though.
Jud
A guy that wheeled in our group at the con had that same single ram setup on his sammi. It seemed to do ok but he blew a line at the begining of the trail and had to turn back.
"bout tree fiddy"
Jud
Oh and those removable pins make it way easy to work on when you blow a line on the trail.
"bout tree fiddy"
Hopefully i don't blow a line at all lol.  my buddy Peter has this setup on his toy with a 60 also and it works pretty good.
Doof
i dont think thats big enough... ill trade you a manly one off my big wheels
MiniSimp
Quote from: Hyena on June 19, 2008, 10:16:49 PM
You better make it, I gotta grab some beer from ya! :yesnod:
I'll be there with beer either way!   :biggthumpup:
New/used high pressure pump.
kiyul4130
great job. ya your junks going to be way more bling than mine whether im done first or not. make sure that ram goes into bypass before the knuckle stops!!!!!
-kiyul-
ECV 7-11
KYOTA FOREVER
ya for sure.  i am mounting it when it is fully extended and at full stop.  then i will make a spacer out of aluminum for a stop on the shaft if i need to.
Duffil
looking nice brad. keep it up.
854RUN
-JOSH-
toy4x4ota
how did you mount it to the ram to the center
edit: just noticed you had it on a jack stand, that said, how do you plan on mounting it to the center. isnt the center section cast?
LIFTED TRUCKS ARE GAY
