My 84 extra cab is gone. Tacoma build now.
Started by Hyena, November 21, 2004, 12:25:12 PM
.035 NR 211 flux core with a lincoln 175 220.  the gusset for the steering arm was welded with .045 Ultra Core dual shield from a CV-400 at work.  that :pokinit: burns hot.
its just tacked in.  i will burn them in later when i get the right shocks and make sure they clear everything.  don't mind my sick spacer clamp i have.
TIMS89CRAWLER
www.choptechfab.com
www.myspace.com/choptechfab
CHECK THE BUILD
gotrocks
Ok now it makes sense.  Is that whole tube solid?
Doof
is that going to be strong enough?
gran-it there really isnt much weight to it, but it seems not up to par with the beef of how everything else is on this so far...
:twocents:
its not done, i don't do anything single shear.  kent had almost the same thing on his front.  all he did was bend the bolts but that was only single shear.  he made it double shear and it is solid now.
Duffil
just wondering...why didn't you run 2 plates out and mount it with the loop parallel to the tube instead of perpendicular like you did?
wouldn't that help with the shock shifting under compression/extension?
i really just don't like mounting shocks that way.  i think it puts less of a bind on the ends like this.
i'll be waiting for those new FOA 2.0 coil overs to come out and when they do i'll shatch up 4 of them.  $300 a pop with springs is crazy!
Doof
gotrocks
Quote from: Hyena on October 20, 2008, 10:14:43 PM
Yeah I'll be interested to see how they work for you. I've thought about getting a set for my buggy but the $2000 for a complete fox set is just not logical to spend.  However if I can do it for $1200 I might think about it.  Thats cheaper than 2.5 air shocks.
kiyul4130
looks like the coils are going to be really close to the exhaust.
-kiyul-
ECV 7-11
KYOTA FOREVER
gotrocks
You sure you not looking at the intake?
Reynolds
Looks to be about the same distance from either the exhaust manifold or intake. Fortunately, it would probably be easier to move the intake side then move the upper coilover mount out if need be.
-Brian
kiyul4130
ya, in between the intake and exhaust manifold. it might just be the pictures though.
-kiyul-
ECV 7-11
KYOTA FOREVER
thats the intake manifold and the intake tube on the passenger side.  it will be close.  thats why i am waiting for the 2.0 coil overs to come out.
Reynolds
Quote from: Hyena on October 21, 2008, 06:08:37 PM
Shoot, the only issues you should have with the exhaust manifold side is when the passenger side is fully drooped out. That's when it will be closest to that area. I really need to do :pokinit: like this to my truck, I think too much when it comes to other peoples stuff :D
-Brian
went to pick n pull today and picked up a hardline for the rear axle.  $7 was well worth it.  also snabbed the banjo bolts for the front calipers with my 5 finger discount, but they turned out to be the wrong thread size :(
kiyul4130
Quote from: Hyena on October 25, 2008, 07:31:32 PM
nice try blanco nino!
http://www.kangarude.com/gi_joe/nosebleed.php
-kiyul-
ECV 7-11
KYOTA FOREVER
Doof
kiyul4130
-kiyul-
ECV 7-11
KYOTA FOREVER
sick, got the right size fitting for my hydro lines and i can't install them because they hit each other on the orbital   :mad:  im about done with this piece of :pokinit:.
slabcs
Relentless
Doof
is there anyway to loosen the fittings into the orbital and move them just enough so you can get those fittings on?
Reynolds
Quote from: slabcs on October 31, 2008, 06:49:37 PM
Use your old steering box.
Genius! I can't believe no one has thought of that...
-Brian
Quote from: Reynolds on November 01, 2008, 04:31:17 PM
That's what TopStreet did :rofl:
Reynolds
-Brian
for that 89 4Runner on Rocks.. he is using the IFS box to actuate the the steering ram lol
Doof
Quote from: that HO kid on November 02, 2008, 05:11:53 PM
dude.....
:smack:
:shake:
EPIC FAIL
