My 84 extra cab is gone. Tacoma build now.
Started by Hyena, November 21, 2004, 12:25:12 PM
Got a lead on some parts i need for cheap.  ah i can't wait for my check to come in.
NorCalToy
:flamer: IFS
mainly for the brakes and steering
95SAS
Great job on the truck! Cant wait to see how well it works.  :driving:
1986 extracab, SAS 38.5's Locked Duals, truggyfied, beadlocks
1988 2wd bagged and body dropped 3'' with a healthy 22r....
my build
http://board.marlincrawler.com/index.php?topic=35602.0
kiyul4130
i have a question about dodge 60s. what does it take to run internal hubs (chevy style). do you have to convert the hubs over to chevy along with the stubs, or can you just buy different lockouts?
-kiyul-
ECV 7-11
KYOTA FOREVER
freds40
GM wheel hubs are internally splined for internal locking hubs. Dodge wheel hubs are not. They simply have the surface drilled for the external locking hubs.
If you want to run internal locking hubs or any of the aftermarket internal drive flanges, you need GM wheel hubs. They will interchange with the dodge wheel hubs no problem.
"between projects"
kiyul4130
Quote from: freds40 on May 22, 2008, 02:50:36 PM
ok thats what i figured. so the stubs are the same then. cool.
-kiyul-
ECV 7-11
KYOTA FOREVER
I believe you get 3/4 ton chevy rotors,  and calipers and buy a couple brackest from some company on pirate to make them work with the 60 spindles.  i forgot what company it was.  a little grinding od the calipers and you can fit 15 inch wheels.  i should be going through this here shortly.
not right now.  hopefully in a week i will have some up of the finished front links.
Quote from: kiyul4130 on May 22, 2008, 12:28:27 PM
i'm gonna go with these brackets
http://screaminseeman.com/calipermounts.htm
Doof
on post 2294 you have your switchs and what not... did you make those and put the stickers over each switch or did you buy that set up
I bought everything from www.offroadcontrols.com  it comes with stickers to put on the panels.  not as nice at 12voltguy stuff but it is good enough for me.
Doof
kiyul4130
pics, updates, something, hows work. blah.....
-kiyul-
ECV 7-11
KYOTA FOREVER
Doof
tap a keg and build a bumper for my runner... custom front and rear...
hahahaha...... carry on
i had some pictures but i somehow deleted them.  o well.  got the front links done, got some free lugnuts for the rear axle so the tires are actually bolted up.  picking up a TG powersteering pump, Rockstomper master cylinder, newer brake booster and a proportioning valve on sunday all for $275.
Got the TG PS pump bolted up.  need to mount the new reservoir and figure out all the fittings i need to get with the ram and orbital valve.  also got the master cylinder, booster and proportioning valve but i didn't unstall them yet.
ya, get top through a bunch of money i don't have into my ford!  looks like the toyota will wait again.  thinking the CPS went out on it.  it ran like :pokinit: on the way home fromt work and had no power, then finally died.  but i did get pushed through an intersection by a CHP!  that was fun.
lilbuddy
RIP Kyota.... you are the man
GET IT!!!
inmyownsummerami
Shitty. Those sensors are pure garbage.
WHITE WHEEL ROCK CRAWLERS "If your wheels ain't white, they ain't right"
:greengrin:My 1st Gen. Toyota SAS (2wd to 4wd) :greengrin: (In Progress)
RIP "Goody Goods" My DDW Brother
inmyownsummerami
There is a recall on the sensors. Check here to see if your truck is covered http://www.ford.com/owner-services/customer-support/recall-information
Here's a little more info about the recall http://www.thedieselgarage.com/forums/showthread.php?t=56025
I new about the recall but just didn't get around to it.  thanx for that website though!
its only $25 for a CPS, it will probably cost more money to have it towed to Ford.  i may just pick one up and put it in myself.
Doof
:pokinit: y for sure... thats cool the CHP helped you out though
not much new.  ordered the ram today.  going to install the brake stuff i got tomarrow.  going golfing with my dad later today!  :)
Doof
45-42=87  :)  Plus as i came back into the clubhouse i opened this door for a dude and it turned out to be Bobby Jackson from the Kings!  i was stoked.
Doof
Doof
so i was just checkng out your toy rebuild pics on mygay and was looking at the panhard bar... what exactly is it for? prevent axle wrap or help keep the axle from tracking?
