Florida's finest I would presume?
That would be "off road gal"
I know this is a weak idea, but what gear oil are you using? It sounds like your syncros have seen some use. Try running some thinner synthetic oil, maybe that will help?
I would think that if it were the clutch disc or flywheel, that it would occur in all gears, not just three. It also appears that the problem does occur on all three shift rails. Check the shifter base where it meets the shift rails. Couldn't tell you what to look for though.
I cleaned off the operating table when I got home so I could start making my custom transfercase. I picked up a couple complete cases and found a couple that were for parts only. The objective here is to get a lower rear output to correct my driveshaft angle problem so I can get rid of the high pinion rear and go V6 third.
is there a way to possibly make an off-set Toy transfer case work, then clock it down a little bit, so you can bolt it up to your low-pinion V6 third? just a suggestion, don't know how feasible it is....
I think you are talking about the Crusier case? That is a chain drive isn't it? I want to use the gear case and the 4.7 low. Maybe if I can make it real short I may be able to go duals too.
Wont happen, ive been working on the rig just about every day now. Lots of little things pop out of the woods when you get your rig from a junk yard. Ill be there.
and we'll be looking forward to pulling your rig over the rocks!
She knows that we won't have to. We had a 4.3 in a Nissan 4x4. The guys at the mud bogs wouldn't let us run anymore cause we were cleaning up. I would pull you if you needed it though.
Ive actually only been 4 wheeling about 3 times, and drove for about 10 minutes. I think I need some lessons on how to drive over rocks.
Started by Willy Mammoth Chit Chat Camp
Started by Willy Mammoth « 1 2 ... 68 69 » Trail Reports, Events, and Gatherings
Started by cruzila Chit Chat Camp
Started by MiniSimp Chit Chat Camp
Started by BigMike « 1 2 3 » Chit Chat Camp
