Making Of The Willy Mammoth
Started by Willy Mammoth, November 18, 2004, 08:06:16 PM
0 Members and 107 Guests are viewing this topic.
Willy Mammoth
Oil cooler too. I have to get hoses made and install them before I car try it out, but that's it for now.
Duffil
lookin good Mr. W! :thumbs: keep at it, MCR4 is gettin close!
Willy Mammoth
Got the ram assist done and it works pretty good. There is a little wander going straight down the road, but nothing that is hard to control. Not sure Yet how much extra power there is, will have to report on that later.
The roof rack is done and can be scratched off the list.
MiniSimp
Quote from: Willy Mammoth on August 09, 2005, 07:12:14 PM
Is that how Mrs W is making you ride to MCR4? :greengrin:
Willy Mammoth
I got my square drive shaft done and I feel like a real dumb @$$. I used the early drive shaft for the parts and didn't find out till after I ground out a place for the grease fitting that the newer shafts have more room around the joints and more ability to bend more.  :smack:
InstaGator
Quote from: MrsWillyMammoth on July 30, 2005, 03:12:10 PM
Skycraft is where I got the tubing for the chains, the guy there was having a good time helping me decide what would work best. I love that place, you just walk around with all kinds of ideas coming to mind.
I haven't seen that other one but someone else around here told me about it not too long ago too. Where abouts are you Insti?
The only thing I don't like about Skycraft is whenever I go in there for 1 item I walk out light on the wallet with a bag full of goodies and 4 more things I have to do!!! I'm over in Deltona but I drive truck localy so I am all over central Fl. just about everyday. My truck is just about done and after some testing I'm going to put together a different type of Ocala run, I'll let you guys know whats going on when I start. It should be after you come back from the con.
Lator.......
Nissan's need Marlin too. Won't you help?
88runner
hey MrWilly did you check the garage door clearance  :headscratch:
88 4runner v6,
5.29 with 35" tires,
Isuzu Rodeo rear disk brake,
solid axle'd
Willy Mammoth
Quote from: 88runner on August 20, 2005, 01:02:40 PM
Yea Yea, I know! it don't fit with the damm rack on. It's a royal pain in the back side, but it won't need to be on very often.
Lady Di
Quote from: InstaGator on August 19, 2005, 08:22:25 PM
Lator.......
Cool, PM us if you are going to be doing any trailriding.
Life is like a bowl of beer flavored chocolate covered dog turds.. it makes no sense. :pokinit:
Where is the Mammoth?
How the Mammoth came to be
Number Two :pokinit:
Willy Mammoth
I just had to share this. I finished the new spare rear draveshaft and got it installed. Who would even know there was a spare hidden somewere if it wasn't for this thread?
And in case you hadn't noticed the front hitch is done too.
Willy Mammoth
One more  :disturbed:
InstaGator
Quote from: MrsWillyMammoth on August 20, 2005, 03:18:24 PM
Will Do!! Let me know when you go testing or trail riding as well.
Lator.....
Shamb
wow this rig has went threw an amazing transformation!
Can't wait to see it in action on the Con.
:thumbs:
Willy Mammoth
Well, I didn't get as much done as I wanted to, but I did get the Jerry can hung on so it is out of the way. Now I need to build a deck over the rocket boxes to hold them in and give us a place to pack more stuff.
Still looking for a 85 or newer driveshaft slip so I can get the square shaft done right. Anybody have anything?
I also need to come up with a E brake of some kind.  :idea: I am thinking of using a pull handle between the seats that is hooked to the brake pedal so it pulls the pedal down when you pull the handle up. :dunno:
MiniSimp
Quote from: Willy Mammoth on August 21, 2005, 05:29:22 PM
Yeah, like a car e-brake with a ratchet lock.
How is your departure angle with the spare and Jerry can on there?
Willy Mammoth
Quote from: MiniSimp on August 21, 2005, 06:08:02 PM
Better after I make the skid bar, It's not too bad now, but rather than drop off on the tire or can I want to make a skid bar that slips into a trailer hitch.
Willy Mammoth
I also bumped the side of the front tire against a tree and turned the wheel. After revving the engine a couple times it pushed the Willy over away from the tree. That ought to be good for breaking something. I see 6 stud knuckles in my future if that happens. :gap:
Jafa
Go hydraulic! small caliper on a disc bolted to the output flange on ya trans case. Sky do a kit
http://www.sky-manufacturing.com/
Altho their's isn't hydraulic
'89 Hilux,1UZ-FE,coils,4 links,4inch sus,3inch body/engine/drivetrain,int cage,PTO 12000lb milemarker hyd(mid mounted),rancho's,36' Simex ET's,secondair beadlocks,4wdiscs, full floater rear,TF handbrake,ARB front locker,Detroit EZ rear,30spline Longs......
New Zealand
Willy Mammoth
Quote from: Jafa on August 23, 2005, 06:37:57 PM
I would love to do it that way, but there is only 1/2" between the flange and the floor.  Thanks for the input though.
Willy Mammoth
I was thinkin about a timing pully that has the cog grooves and a shoe that has cogs to match that pulls tight with a cable. Darn if I can't find my pullys.
Mattinker
Have you thought about a band brake? I'm sure you've seen one somewhere, they're used on epicyclic gears to actuate them, amongst other things. A steel band with brake lining material runs around a brake drum on the outside, one end of the band is fixed and the other is pulled to tighten the band against the drum. There must be a four or five inch brake drum in the breakers yard somewhere that you could turn the outside smooth to accept a band? The band itself would be quite simple to invent, riveting brake linings backwards  on to the band. This would have a gradual release, unlike a "cog" system.
Just my two euro cents,
Matthew
BUBBA
Quote from: Mattinker on September 02, 2005, 12:42:58 PM
Matthew
Alot of older Jeeps came with a drum parking on the transfer case from the factory.I'm not sure what years,but I had a 71 cj5 that had one.Those didn't work well at all.You would be better off with a disk and pads rather than a drum,If you decided to go that route.Personally I like the idea of a positive engagement parking brake.There wouldn't be no chance of it slipping and your beloved rig rolling off into the sunset.It's not a good feeling to see your rig leaving without you,believe me I know.
My budget beater
Mattinker
The disk won't fit under the floor!.
Matthew
BUBBA
Quote from: Mattinker on September 03, 2005, 12:01:43 AM
Matthew
:headscratch: I don't know why it wouldn't.
My budget beater
Willy Mammoth
Here is a shot of the rear of the transfercase showing how much room I don't have for a disk.
I like the cog brake idea too, but I don't have time just yet so I plan on having a hand brake that pulls the brake pedal down. So long as the hydraulics are good it will hold all four wheels. :crossed:
Willy Mammoth
This weekend is it, We gota as much as we can befere next week or we are in trouble.  :smack:
Got rock lights to install, Third member to mount on the front bumper, CB to install, a deck to build over the back and on and on.
Oyea, and the front axle needs to be put back together after installing the V6 third and Bobby Longs 30 spline  cromo's.  :ack:
88runner
you had a high pinion fromt if i remember correctly, why did you swich to the v6 third ???
88 4runner v6,
solid axle'd
Willy Mammoth
Quote from: 88runner on September 03, 2005, 05:41:01 AM
I knew I shulda explained my plans here. :rofl:
:think:  I was going to build a custom T case to lower the rear output and put the V6 in the rear, but time has run out. I decided to keep the HP in the rear and have built a spare driveshaft. I needed a spare HP 3rd in case, but the gears aren't available yet. So I built the V6 and put it up front now while I was in there doing the Bobby Longs. That way I don't have to do it on the trail when I need a HP for the rear.
I know this is all wrong, but that's what makes it intersting.  :_oops:
:gap:
Willy Mammoth
#928
Labor Day update day one: I got the front diff done with the V6 3rd and Bobby Long's. Also manager to cut up a perfectly good 84 front Axel housing and weld it to the front bumper. :shake_head: Just so I will have a to place to hold my spare diff, like everybody has a spare diff on their front bumper. :disturbed:
Willy Mammoth
 :clap2: Did another flex test to see if the tire will hit the spare diff and it does, so I moved it a bit. I also got 30" of flex this time which is 6" more thane the first and 12" more than the last. I may take a spring out of the front still. More on that later.
