Making Of The Willy Mammoth
Started by Willy Mammoth, November 18, 2004, 08:06:16 PM
0 Members and 10 Guests are viewing this topic.
Willy Mammoth
:flamer: The Mammoth goes under the knife again. It is waiting for a new set of Marlin front springs for the rear. The CJ7 front springs ain't going to cut it. As it turns out I only have to move the rear shackle mount back a couple inches for them to fit, so now I'm  :toiletwait: again.
Willy Mammoth
I set the winch up on the front to see what I need to do to install it. There has been some talk about turbos so here is a pic of the turbo that might make it on the engine.
Uncle Jesse
You just don't quit!  This is an awesome buildup.  On your recent trips out road testing how did those isuzu rear brakes do?  Do they have enough ooomph to stop those huge tires?
By the way, get that turbo done!
Willy Mammoth
Quote from: Uncle Jesse on April 25, 2005, 09:17:17 PM
They seem to at this point. I have the proportioning valve open all the way and they don't want to lockup. I want to put the booster on so I don't have to push so hard to stop. Oyea, I think the power steering needs to be hooked up too. Time to dry dock it for a while and get the rest of the stuff done.
FATB0Y
Quote from: Willy Mammoth on April 24, 2005, 07:06:15 PM
I know all about them falling out, I almost lost a finger cause of that.
Me 2 Have scarz 2 prove it  :paranoid:
Willy Mammoth
I pulled the springs out of the front and put the leaves back in. I put them in the rear so now I need to move the sackles back. This thing is going to scrape the header beam going in and out of the garage. I should get the new front springs next week and be able to get it back on the wheels. There is a lot of things that need to be done to get it ready for Memorial Day weekend. Haven't decided where to go yet, but we gota go somewhere.
Uncle Jesse
Well, I don't have a caliper to measure the stock axle diameter, so I did the next best thing.  Got the parts dept. where I work to get me a isuzu rotor so I could test it on a stock axle then return it if needed.
An unmodified isuzu rotor does not fit on an unmodified toyota axle.  The flange diameter is too big, as well as the center ring diameter.  Bummer
Willy Mammoth
Quote from: Uncle Jesse on April 26, 2005, 06:07:24 PM
The stud holes need to be drilled a bit and the center could have a ring made, but I don't have a problem with them centering. If you can find a larger diameter rotorthat will fit the caliper bracket could be made to move the caliper to the proper location. You can also grind the axle down a bit so the rotor will fit. It seems to work real good, I just can't push hard enough on the peddle to get them to lock up without power brakes.
Doesn't the 4 runners or land cruisers have disks?
Uncle Jesse
I meant the axle diameter and ring are too big.  I couldn't even get to the part to see if the stud holes were too small.  I do by the way, have my doubts about them getting me the right rotor, but it does look just like yours.  This one just seems to me to be puny in size, as compared to the stock drum.
I have been eyeballing mitsubishi montero sport rear discs, but they have a tall hat due to the drum parking brake.  It would probably push the caliper to far back, or not fit inside a 15" wheel
scheid6996
Its a redneck thing
"Nobody Loves Me"
Willy Mammoth
I spent time today finishing off cutting up the buggy. I borrowed the winch plate and bumper to make the winch mount for the Willy. That's all welded in and painted now.
MiniSimp
Looking good Mr. W!
You gonna paint that winch?
Willy Mammoth
Quote from: MiniSimp on April 27, 2005, 06:54:15 PM
Looking good Mr. W!
You don't like the rust? Ok i'll paint the winch.
MiniSimp
gonzo
What is your Milemarker rated at?
Willy Mammoth
Quote from: gonzo on April 28, 2005, 05:03:04 AM
9000 Lbs. and with the rite pump I bet it will do more. This winch has been well tested.
TrackVino
I'm going to attempt to paint my rig in a couple of weeks. I will be using the documented guide you gave me. Thanks for all the tips. Hopefully my rig looks almost as good as yours.  :beerchug:
gonzo
Quote from: Willy Mammoth on April 28, 2005, 04:51:26 PM
Hey Mr. W, what pump would you use?  The reason I ask is because I have a mile marker installed on my 86 4 runner.  It does OK in low but not in high (under load).  I believe my p/s pump buts out 950 psi at idle but the winch actually requires 1500.  Any suggestions would be very helpful.  Thank you
Willy Mammoth
Quote from: gonzo on April 29, 2005, 04:59:28 AM
You could put a larger spring in your pump regulator or use a GM pump, somthing from a hydra boost truck or somthing. Use a transmision cooler on the return to help keep the fluid cool.
FATB0Y
Mr. Willy you are a fart smucker :rofl: I ment a smart fuc_er :yupyup:
Willy Mammoth
Quote from: 03HDFATBOY on April 30, 2005, 02:50:13 PM
Don't think so, but I think I am a fink sarter. :disturbed:
FATB0Y
Quote from: Willy Mammoth on May 01, 2005, 07:29:49 AM
don't you mean a "finkin' stucker" ? :fart:
Willy Mammoth
TrackVino
What the heck are you guys talking about? Just put pictures of your rig willy!!!  :chew:  :offtopic:
Lady Di
Quote from: TrackVino on May 01, 2005, 11:55:42 PM
I think he meant he's a "fink starter"  :fart: and I will attest to that one!
and have you seen our latest pics on the new Adventures of the Willy Mammoth thread yet, Vino?
Life is like a bowl of beer flavored chocolate covered dog turds.. it makes no sense. :pokinit:
Where is the Mammoth?
How the Mammoth came to be
Number Two :pokinit:
Willy Mammoth
Got the springs in today and got the springs in today. :gap:  It looks like this thing is 2" taller than it was before, but will just fit in the garage.
Willy Mammoth
I'm going to need taller shocks too. I only have 1 1/4" extension left on the front an none on the rear.
reklund5
what's the extra height do to your driveshaft angles?  I know they were problematic...
Ryan
Willy Mammoth
Quote from: reklund5 on May 03, 2005, 08:03:58 PM
Ryan
Don't help that's for sure. The front is no problem, but the rear, well that is a problem. It is ok so long as the whole rear doesn't extend at the same time. I have plans to customize a transfercase with a lower output to fix this problem and then put in a V6 third to fix the weak high pinion problem. All in time, but first I have to find the parts.
Dont I remember a thread where buying shock longer than what you think you'll need just incase you upgrade later??  :hahaha:
