Making Of The Willy Mammoth
Started by Willy Mammoth, November 18, 2004, 08:06:16 PM
0 Members and 31 Guests are viewing this topic.
Willy Mammoth
#390
While you guys where playing around, I was out there working. So I bet you would like to know what I was working on. Well I'm gona tell ya. It goes like this, when I welded the tailsaft housing it warped from all the heat so it needed to be milled down to make it flat again. Then all the other surfaces needed to be machined to make sure they have the rite step. Next the shifter shaft will need to be bored into the plug that was welded in.
Willy Mammoth
:respect: Big Mike you are the best. Your my hero!  :king:  Now just so nobody gets any ideas, I locked this thread so I could post pictures without having to keep selecting them due to the recent high traffic and couldn't unlock it again. :_oops:
Thanks Big Mike  :thumbs:
Willy Mammoth
#392
Back to the story at hand. where was I, Oyea, More pictures.
FATB0Y
Mr.Willy you are the King of home brew rigs.
:bowdown:  :bowdown:  :bowdown:  :bowdown:  :bowdown:  :bowdown:  :bowdown:
:bowdown:  :bowdown:  :bowdown:  :bowdown:  :bowdown:  :bowdown:  :bowdown:       :king: <-Mr.Willy
ok i got lost somewhere , why did you have to weld that shaft into the housing :dunno:
Willy Mammoth
Quote from: 79Coyotefrg on March 18, 2005, 06:54:18 AM
The shaft isn't welded into the housing :smoke: JK
I shortened the trans by about 5" and had to shorten the tailshaft housing. That left me with almost no room for the shifter shaft and no support for the back of the shaft. I welded a plug or bushing into the back of the housing that I need to bore out so the shaft has somthing to slide into.  :crossed: Hopeing I have enough room so I can use 1st, 3rd and 5th. Otherwise I will only have a 2 spd. :rofl:
Trust me I "think" I know what I am doing :headscratch:
brainlessfool
I never seam to stop being amazed when i see the progess on the willy!  :thumbs:
Willy Mammoth
That is pretty wierd, but at least you tried something different.  Keep it up!!!
FATB0Y
Quote from: Willy Mammoth on March 18, 2005, 04:57:18 PM
well than sounds like ya need to :smoke: a nother one so you'll KNOW what your doin' :rofl:
Willy Mammoth
#400
:nope: I don't cause I can do a better job with out going  :duh: and  :_oops2:.
Well the shifter linkage has been sorted out and works. Now it's on to cleaning up the transmision and final Assembly. Should have it done tonight.  :crossed:
Lady Di
Quote from: Hyena on March 18, 2005, 07:53:27 PM
not the first time fer that, fer'sher! Needless to say (why do people say that and then proceed to say it anyway?) he is the master of "trying something different".
Anyhoo, I'm back from the  :sleeping: bridal shower (actually, it was quite fun  :beerchug: ), Mr. Willy is putting the transmission back in the case. I'm sure there will be more to follow.
BTW- Brainless...LOVE your avatar. :cheer:  :usa:
Life is like a bowl of beer flavored chocolate covered dog turds.. it makes no sense. :pokinit:
Where is the Mammoth?
How the Mammoth came to be
Number Two :pokinit:
scheid6996
Its a redneck thing
"Nobody Loves Me"
Willy Mammoth
#403
Well I got the trans finished today, but not without my share of problems. First the plug I welded in didn't stick through enough and I had to add a piece so the shifter shaft wouldn't slide out of the hole. Then I didn't have a boring bar long enough to bore the hole for the shaft so I had to use the shaft and grind a cutting edge on the end that was going to be cut off and use it to bore the hole. After all that I started putting the trans together and found the first/second fork Had the plastic coming off. I had to stop and braze it up and reshape it. Tried to use the milling machine to shape it, but found that it wasn't jigged rite so I had to use the grinder to finish it off. Just when you think nothing else could go wrong I found out that I lost an interlock pin at some point and Had to make one of those too. :tantrum:
Any way the important thing is it is done and it works. I put the transfercase on it and filled them with oil. I then ran them on a drill and shifted them through all the gears to get oil flowing. :banana:
Tomorrow It's time to install the engine, trans and transfercase back into the Willy. :dancing: :bud: :cheer: but for now it's time for some  :sleeping:
Willy Mammoth
#404
 :beerchug:
FATB0Y
Mr Willy You never cease to amaze me  :bowdown:
brainlessfool
me too, hey better stop playing on the mammoth and finsih that pluming work so ya's got hot water in the house!!
Lady Di
Quote from: brainlessfool on March 20, 2005, 07:10:45 AM
:rofl2: that wall has been like that for at least, what, 8-10 years? The washer and dryer are on the other side of the wall along with the water heater.
There is never time to finish a project but always time to start a new one! :yupyup:
Well gots to get to work, :whip: Mark's getting the engine and tranny in.
I've got to do some work on the windshield frame to get that primed.
The weather is gorgeous. Mid 70's and sunny. Life is good :cheer: but I CAN'T WAIT TO PLAY!!
:bud: :biked:
Lady Di
This just in:
I got the windshield frame prepped :whip: and it will be primed next week.
MrWilly got the tranny and transfer case in and  :flamer:  is in the process of fabricating a new and improved gas tank.
Story at 11:00.
Lady Di
#409
oh the humanity! Between the yellow and the new holes it's starting to look more like swiss cheese!
scheid6996
Its a redneck thing
"Nobody Loves Me"
scheid6996
Its a redneck thing
"Nobody Loves Me"
Lady Di
Quote from: BigMike on March 20, 2005, 05:58:15 PM
You guys are cheating
HE MADE ME DO IT!  :_oops:
:headscratch: wha'd we do now?   :dunno:
Willy Mammoth
#414
As you heard the engine, trans and transfercase is in. I didn't like the stock gas tank because it didn't fit rite and there was a lot of waisted space around it that could be used for fuel. I used up the rest of the metal from the hood to fab a fuel tank. We calculated 16 gallons without the drop section. I had to cut up the floor to allow for a section of the tank to be able to transfer fuel from one side of the tunnel hump. Had to cut another hole for the drop section of the tank. The drop will help keep the engine from starving for fuel on off angles. You don't want to run a diesel dry.
Willy Mammoth
#415
 :flamer:
Willy Mammoth
#416
 8)
scheid6996
Its a redneck thing
"Nobody Loves Me"
Willy Mammoth
#418
 :red_eyes:
reklund5
WOW!!  It's definitely yellow!
Looks great!  Can't wait to see/hear it run under its own power!  :eyebrow:
Ryan
