Making Of The Willy Mammoth
Started by Willy Mammoth, November 18, 2004, 08:06:16 PM
0 Members and 190 Guests are viewing this topic.
MiniSimp
Quote from: Willy Mammoth on May 12, 2005, 06:36:40 PM
Oyea, I have to share this :banana: :jawdrop:  Bobby Longs chromoly axles are here. :biked:
:bling: :banana: :chicken:Moon walking chicken! :greengrin:
Willy Mammoth
gonzo
Lady Di
Life is like a bowl of beer flavored chocolate covered dog turds.. it makes no sense. :pokinit:
Where is the Mammoth?
How the Mammoth came to be
Number Two :pokinit:
Lady Di
there is more response to the moon walking chicken then there is to the casting!! :rofl2:
btw - awesome job MrW. :rofl:
MiniSimp
MRS W!!!!
You're in trouble!
Never wear sandals around molten aluminum!!!!
Lady Di
#696
Quote from: MiniSimp on May 12, 2005, 07:15:24 PM
MRS W!!!!
You're in trouble!
THAT ISN'T MY FOOT!!!  :slap: That was our self proclaimed nosey neighbor Jerry, (hey Jerry  :wave:  I know you're reading this) but he didn't know what Mark was up to.
For future reference: I don't wear sandals! If you see sneakers, or more likely, boots, then that would be my foot.
Willy Mammoth
That's not me . That's my neighbor, I know better.
TrackVino
So back to the subject, how did the casting come out?
Moon walking chicken!!!  :rofl: :chicken:
reklund5
Ok wait.  You're casting YOUR OWN case!?!?!?
Now I thought I was a do-it-yourselfer but that is just cool!  Just a thought, but with your milling/machining ability, any reason not to use a chunk of billet?
Ryan
Willy Mammoth
Quote from: reklund5 on May 12, 2005, 09:04:34 PM
Ryan
Scrap aluminum is cheaper and it doesn't make as big a mess.
Lady Di
Ryan
He thought of that but that is much more expensive. We'll see how this goes first. It's very experimental. Or so I've heard tell.  :disturbed:  I'm sure he'll fill you in on the details!
:rofl2: moon walking chicken! :rofl:
Lady Di
Quote from: Willy Mammoth on May 12, 2005, 09:13:15 PM
oops, didn't see this post!
Willy Mammoth
Back on the transmision problem at hand. I tore it down and inspected it. I didn't find any thing except for the 4th gear syncro is draging causing the input shaft to spin at the same speed as the tailshaft. That is why it is hard to shift. I replaced the syncro and put it back together. I found it will spin free without the transfercase installed, but as soon as you bolt up the transfercase it gets tight again. I will have to remove the transfercase and check to see if the tail shaft is being pushed forward by the transfercase. There was a lot of metal shavings in the oil so I think it wore in and got tight. We will know tomorrow.
Willy Mammoth
I figured out the trans problem. The transfercase was putting a side load on the tailshaft causing it to bind. I clearanced the tailshaft housing and it turns free now. Must have had something to do with snatching out those 5 full sized trucks last weekend. It is all back together and working fine now. Even 5th gear works. Amazing how a simple snap ring can make a difference. :_oops:
We are going to drive it tomorrow when we go looking at motorhomes.  :crossed:  I'm not worried about the Willy, I just hope we can find a motorhome we can afford and they will take our trailer as a trade.
BUBBA
Nice work Mr. W,wish you were my neighbor,
btw howd the casting go
My budget beater
TrackVino
Willy Mammoth
Quote from: rocktoy35 on May 14, 2005, 11:05:40 PM
The test went well, but now I have to figure out how I want the gears to sit then build a Styrofoam case so I can cast it. This is going to take time.
InstaGator
Damn, I thought you were smart before, now I feel like I am not even worthy enough to read your posts!!  :bowdown: Awsome job your doing.
Lator......
Nissan's need Marlin too. Won't you help?
gonzo
Quote from: Willy Mammoth on May 15, 2005, 05:28:53 AM
So when you build the case you piece together the styrofoam into the shape you want?  Do you use glue to do this, or do you just lay them together?  This is cool stuff Mr. Willy
MiniSimp
Quote from: Willy Mammoth on May 14, 2005, 08:45:09 PM
Good job Mr W! Now get cutting on that case.
88runner
I was thinking about how to correctly cast a piece and came up with this idea
put some wet sand on the bottom than put the styrofoam on it and cover with wet sand, then take the whole thing put it in a oven to warm it up, also you should make a sort of place in the sand to help putting the aluminum in the hole.
:dunno:  just a thought  :headscratch:
88 4runner v6,
5.29 with 35" tires,
Isuzu Rodeo rear disk brake,
solid axle'd
Willy Mammoth
We found this motorhome we liked, but not sure we will get it. It's more than we need to spend after the Mammoth and all.
So we did a test fit in our trailer. We had to change the rear tires in order to get it in.
:_order:
Willy Mammoth
Quote from: 88runner on May 15, 2005, 06:21:06 PM
put some wet sand on the bottom than put the Styrofoam on it and cover with wet sand, then take the whole thing put it in a oven to warm it up, also you should make a sort of place in the sand to help putting the aluminum in the hole.
The foam part will become the part. The molten aluminum will vaporize the foam as it is poured into the sand. You have to be careful the sand is not wet or it will explode with the heat of the aluminum. (1650 degrees)
brainlessfool
Your going to trailer that beast to caliy? that just anit right. Drive it out here!  :driving:  it wonts to be on the road! I can hear it from here. "take my  :moon:  out of this trailer now!" can't ya hear it? lisen to your Willy.   :ha_ha:
BUBBA
Quote from: Willy Mammoth on May 15, 2005, 06:25:22 PM
You should find a bigger trailer,you know one that you can fit two rigs in  :eyebrow:
then you could just swing by and pic me up on the way
My budget beater
Why not just let some air out of your tires?
Willy Mammoth
Quote from: Rocksurfer on May 15, 2005, 06:38:11 PM
We tried that, still wouldn't fit and you can't steer with 4 flat tires.
Quote from: Willy Mammoth on May 15, 2005, 06:44:47 PM
I figured that, thought I'd throw it out there though.
