Jrock's BuildUp
Started by jrock, April 04, 2009, 06:21:30 PM
crazykooter
Jarome just get the stops that go on the shock itself.  They work awesome.  Heck I have a set brand new here.
Plan on putting them on the 5125s I have when i get the shocks setup.
jrock
I should put a set of those on the rear. Do you screw off the eyelet to put those on? Can you take off the shock's eyelet?
crazykooter
You have to slide then on and once they are on the only way to get them off is to cut them off or cut the shaft of the shock.
YOTA yota
jrock
 :gap:Now it's your turn  :beerwhack:
YOTA yota
haha yea right i dont think my truck will ever be one color
jrock
Quote from: YOTA yota on March 15, 2011, 09:51:43 AM
Its easier than you think  :gap:
Newest project, Bed Bob. Yes Duffil and everyone else I finally did it  :_oops:  :outtahere:
:rofl2:
13.5-13.75 inches.
superyota
looks good.  keep the pictures coming.  i'm getting ideas....
ABD Motorsports
#4475
www.placercountycrawlers.com
KK6QDW
jrock
Ideas my fanny, you should take out 10-12inches. My f150 springs aren't as long as your Chevy's so I get to get away with more bed loss :)
This tack welding stuff is a PITA.
superyota
i really don't think i can take that much out.  i'm thinking 6-9 inches tops.  i'm starting to think maybe i'll cut a bunch out and mount my shackle on the back bumper.  not sure yet.  wish i had a bit more time.
ABD Motorsports
#4475
KK6QDW
superyota
maybe i should just go off of where the bedside got toasted on soup bowl.  that might be a good place to measure at :gap:
ABD Motorsports
#4475
KK6QDW
jrock
Quote from: superyota on March 15, 2011, 01:48:11 PM
haha, thats kinda what I did on mine. I cut out the dented section :) Hopfeully now I can stop loosing tail lights :)
I personally don't like the look of the shackles hanging out behind the bumper, I only did it accidentally.
superyota
if i was to leave my shackels where they are, i think i would be pushing it to cut 6 inches out.  thats my biggest dilema right now.  is it even worth it?  will 6 inches make enough difference to stop my from catching the back end and breaking out tail lights?
ABD Motorsports
#4475
KK6QDW
superyota
ABD Motorsports
#4475
KK6QDW
jrock
Quote from: superyota on March 15, 2011, 01:56:09 PM
Dove it too ;)
Quote from: superyota on March 15, 2011, 01:58:52 PM
:disturbed: :acclaim:
Yes, :)
jrock
Before:
Quote from: jrock on January 26, 2011, 06:02:37 PM
After:
And if you can notice, my skid plate hangs down lower now. I whaled on it for 15mins with a BFH to straighten it out. Worked good too. Its now the proper shape  :disturbed:
superyota
i still want to be able to drive it down the road and not get hasseled by 5.0.
ABD Motorsports
#4475
KK6QDW
Peterbuilt84
How much do you think you would need to take out to be flush with the rear of the frame? Any idea?
Bob is looking good, keep up the progress  :gap:
jrock
A few weeks ago I installed a pair of 4xInovation solid motor mounts and a solid t-case mount on the rear case. They work great. No movement at all in my shifters and no more slop in the driveline.
BUT, now I have terrible vibe and rattling in the cab :(
superyota
Quote from: jrock on March 15, 2011, 03:30:16 PM
what skid plate?  looks good. ready for some touch up paint.
ABD Motorsports
#4475
KK6QDW
jrock
Quote from: Peterbuilt84 on March 15, 2011, 03:32:23 PM
Flush? Let me check.
jrock
Quote from: superyota on March 15, 2011, 03:33:29 PM
White duct tape :) I'll make a racing stripe until I can get to Mike's paint booth :)
jrock
I believe you would take out 7".
Peterbuilt84
Quote from: jrock on March 15, 2011, 04:32:59 PM
Thanks!  :beerchug: I was looking at taking around 10" out, but haven't been able to measure.
Where there any problems you ran into with the bob? Anything you'd do different? Looking at bobbing my bed soon so I'm looking for pointers. Yours looks like it came out good btw.
superyota
how did you cut the inner bed panals?  did you measure them afterwards or cut the bed and panals all in 1 shot with a long blade?
ABD Motorsports
#4475
KK6QDW
YOTA yota
Quote from: jrock on March 15, 2011, 03:33:17 PM
i got dave'z solid mm and two stock t-cases mounts. Got tired or the vibes put the stock mm back in and ripped a stock one snow wheelin two days later.. Solid mm's it is..
jrock
I'm waiting to see if the vibs reduce over time. I talked with the 4xInovation guys at KOH. They said they should soften over time and reduce vibs. The bushings are much larger than Dave's Offroad. We'll see what happens.
I had a loose bolt through my stock mounts to prevent separation.
jrock
Quote from: Peterbuilt84 on March 15, 2011, 05:00:43 PM
Things I did wrong, I ground too much off when trying to level the welds  :hammerhead:  and I should have measured more to notice my shackles would be behind my tailgate with a 14" bob.
Tips?  :idea: Start with a clean straight bed!  Cut straight. Start with the top of the bed and work your way down when reassembling. I made sure the top of the bed was perfectly flat and straight. Then I welded the top of each side, then straightened and tacked my way down. I didn't even bother with the bed floor until I had finished the sides  :dunno:
Quote from: superyota on March 16, 2011, 08:09:03 AM
I cut most everything with a cutoff wheel and finished with the sawzaw using the cuts as guides. I cut the back off first.
Peterbuilt84
Thanks for the tips! I made some half doors a while back so I learned from those a few things about welding sheet metal. A bed bob seems a little more difficult though.
