Project BoostedRunner, SOLD
Started by pumkin toy, January 12, 2009, 09:37:34 PM
pumkin toy
97 4runner Limited
pumkin toy
Got some work done on my rear fenders last night.  Thursday Tim and I completely cut out the rear fenders flush with the floor. Last night I pulled my rear wheels off and did some work on the frame.  I welded up a couple of the factory holes and cut off the ugly stock bump stop brackets.  I cleaned up the frame and got it ready for some paint.  Then I moved onto the rear fenders.  I rolled a piece of 1/2" square tubing at work to use for the inside edge of the framing.  I got those all fit up then I cut some pieces of 1/4" rod and tacked them in for support.  I got some cardboard cut out as a template for the sheetmetal.  I'm hoping to get bothe fenders completely covered with sheetmetal today.
97 4runner Limited
swapped89
Gixxer Jon
Hillcrest Crawlers
_________________________________
||_________||_________||__TOYOTA_||
||_________||_________||__________||
http://board.marlincrawler.com/index.php?topic=67011.0
twistedtoy92
hell yeah!!!!  :yesnod:
wish i had the time and money to work on my runner.....  :down:
pumkin toy
I really havnt spent much money on it at all lately.  Its all been time!  I did find a lightly used Warn 8000lb winch for 300 bucks today!  I'm going to pick it up tomorrow :clap:
97 4runner Limited
pumkin toy
here are some pics of today's progress.  I got the majority of it done. I still need to cut a few more pieces and fit them in so the fender is completely closed off from the rest of the body.  Then I am going to smear a bunch of that seamsealer all over everything and probly spray it with some kind of undercoating to seal it all up!
97 4runner Limited
pumkin toy
more
97 4runner Limited
TheCookieMonster
sick. that looks good. how much more clearance did you gain from that ??
-Matt-
nice job on the fenders, some clean work. i did the same thing to my runner, gained so much clearance. no more annoying rubbing of the tires, plus its just a unique look cuz not that many people go that far with the runner fenders. only downside is unlike crunching a stock fender on a rock or tree where it just dents and stays intact.. now with this done if you hit anything major that nice fender you spend all that time on goes to :pokinit: really fast. if i were to go back, i would have put some tubing running along the outside of the fender to protect it. i remember doing all that work to make it nice and then first trip to rubicon it got can opened on a rock. just though id give you a heads up while your still looks perfect.
pumkin toy
Quote from: TheCookieMonster on April 03, 2010, 08:40:21 PM
thanks dude!  the top of the wheelwell is about 2.5 inches taller than stock.  So far I have trimmed about four inches out of the rear fenders from where they used to be
97 4runner Limited
pumkin toy
Quote from: -Matt- on April 03, 2010, 09:08:12 PM
thanks alot!  yeah i'm not sure what i'm going to do as far as body protection yet, hopefully I can keep from bashing it in right away.
97 4runner Limited
peacesells
Nice work man! those tubs came out really nice, I might have to do something similar, tires rubbing peeled mine apart over the last few weeks. How thick is the sheetmetal?
this my man lysol, fresh out the joint
NITE KRAWLERS
NIce brah!! Super killer work dude and mad props dawg! So ya planing on sheet n the underside or wat man??
pumkin toy
Quote from: peacesells on April 03, 2010, 09:36:07 PM
thanks bro!  I used 18 gauge sheetmetal.  Its a great size to work with, its flexible but still pretty strong after its welded in.  A 4x8 sheet was only 35 bucks
Quote from: NITE KRAWLERS on April 03, 2010, 11:26:01 PM
thanks dude, yeah i still have a few more pieces to cut and put in.  the underside back by the tail lights will all be sheeted in
97 4runner Limited
85yoter
SNOW WALKER
WOW man you've got some mad fab skills! Keep up the good work! Your yota is one of the baddest all toyota rigs in the country. The whole build is super clean.
By the way, your engine will easily handle 14lbs of boost. If you don't already have one, get your self a boost gauge and turn up that boost controller! The difference between 10lbs and 14lbs of boost is addictive.
1986 4Runner turbo sas high pinion,E-locked 4:88's,taco rear Detroit locker,22ret forged everything,
duels mc07-r10 cut 42's.
46&2
peacesells
Quote from: SNOW WALKER on April 04, 2010, 10:50:42 PM
Just gotta make sure you add fuel to match!
pumkin toy
thanks alot dude!  I already have a boost gauge and I do have a manual boost controller in one of my boxes of stuff downstairs.  I might have to hook it up one of these days.  I'm just concerned about reliability if I turn up the boost.  I mean it has plenty of power now, and I'm not building this rig so I can race it!  I just dont want to blow a head gasket or somethin stupid like that.
Quote from: peacesells on April 05, 2010, 12:37:44 AM
yeah thats the other thing too, I need to do some research on the supra forums and learn how much boost my engine can handle on the stock fuel mapping
Quote from: fortysixandtwo on April 05, 2010, 12:33:06 AM
Nice work on the fenders man. Looks great!
thanks alot guy!
97 4runner Limited
Jakesteads
tight fender action dude... u should take sheet metal to replace the crappy plastic panels in the back too.. it would match your fenders too!!!!
I like Toyota
pumkin toy
Quote from: Jakesteads on April 05, 2010, 06:58:39 PM
yeah I was thinkin about doing something like that, maybe incorperating some storage areas back there too
97 4runner Limited
SNOW WALKER
#1103
I keep forgetting I'm 4,600 ft above sea level here in Montana. My stock injectors are fine at that boost level. I had to tweak the afm to stay out of the fuel cut off though.
pumkin toy
i'm about 4200 ft above here in Rapid City.  I cant adjust the afm on my engine, so that really isnt an option for me
97 4runner Limited
Jakesteads
Quote from: pumkin toy on April 05, 2010, 06:59:44 PM
just like the stock side storage just use your old panel as a temp then add a metal box in the rear quarter panels.... keep your toe ropes and spare birfs in or something.....
I like Toyota
pumkin toy
Quote from: Jordan7118 on April 05, 2010, 09:09:07 PM
How did you get the radiused bend on the square tube? Looks good!
we have a tubing roller at work, Its an awesome machine!  Can build some pretty custom looking parts with it.  I will probly be using it to make some of the pieces when I build my cage.
Quote from: Jakesteads on April 05, 2010, 09:12:05 PM
Good idea!  I will have to look into doing that.
97 4runner Limited
pumkin toy
I went and got my Warn M8000 winch last night.  Picked it up for 300 bucks! :banana:   heres a pic
97 4runner Limited
swapped89
Nice score on the winch! I got the same one. :thumbs:
