Project BoostedRunner, SOLD
Started by pumkin toy, January 12, 2009, 09:37:34 PM
0 Members and 20 Guests are viewing this topic.
pumkin toy
Quote from: NITE KRAWLERS on March 20, 2010, 09:05:10 PM
Sick gas tank bob man, ha ha! Bob n it all!!!Nice photo opps to brah!
yeah brah!  bobbin tanks is where its at :snapshot:
WELCOME TO PAGE 36!!   :driving: :rara: :cheer: :bananaguitar: :banana: :bananasplit: :bananajumprope: :horseride: :woohoo: :drunk:
97 4runner Limited
any 90+ V6 truck/4runner will have the dual diaphram booster and shud have the 1" bored MC.
NITE KRAWLERS
Quote from: pumkin toy on March 21, 2010, 09:34:46 AM
Holy wacked BRAH!!!
Sometimes life is a rock an we need a Yota to get over it an Chevy is like a rock so I'm over it!!!
pumkin toy
ha ha!  the smilies are so much fun sometimes!
97 4runner Limited
NITE KRAWLERS
I hear ya dude, some of them are so happy and jump n around and just stoked to be on the forum. those sons a!!!
Tacopride
#1055
Quote from: 86toyota on March 20, 2010, 10:11:40 PM
x2 night and day difference with the t100 BB mod! love it
Quote from: pumkin toy on March 20, 2010, 07:33:52 PM
thanks dude!  I did not use the MC from it.  I used a 1" bore MC from marlin.  idk for sure if the T-100 mc will work or not.  As far as the booster goes, it was a direct fit, no mods needed.  And yes it was a night and day difference.  I would highly recommend puting one on, you will love it
Thanks for the replies guys. I was wondering if any one would know if I could use the MC from that booster? Thanks
Jud
That front xmember looks sik. Your doing a super nice job on this thing. Props man!
"bout tree fiddy"
pumkin toy
Quote from: Tacopride on March 22, 2010, 07:57:39 PM
I would imagine you could probly use the booster too.  I'm sure the fittings are the same size
Quote from: Jud on March 22, 2010, 09:38:44 PM
thanks bro!
97 4runner Limited
NITE KRAWLERS
Ya gona have the tranny tunnel built before i get back dude??
pumkin toy
Quote from: NITE KRAWLERS on March 23, 2010, 10:25:53 PM
ha ha  I would like to!  thats my plan for this weekend
97 4runner Limited
Jakesteads
I like Toyota
pumkin toy
97 4runner Limited
pumkin toy
worked on the new tranny/t-case tunnel yesterday.  its pretty much done, I just need to make another piece of sheetmetal that will screw on top and hold the boots in place.  I cut the sheetmetal with a large enough hole to give me easy access to the shift covers when i need to remove them.  The top cover plate that I am going to make will screw onto that peice and cover up the access hole area.  First I needed to re-brace the main supportive crossmember on the body that the seatbelts and seats bolt to. So i peeled back the top layer of sheetmetal and welded in a piece of 1/4"x2" up and over the driveline to the other side to strengthen everything up.  Then I hammered the top layer of sheetmetal back down and welded it to the plate.  Then I cut out a peice of sheetmetal to cover the driveline area.  I spot welded it to the brace first, then hammered it down into place and welded it to the existing floor.  For the main tunnel I used 1/4" solid rod to frame out where I wanted the sheetmetal to fit.  Then I cut one sheet to cover it all.  I tacked it to the 1/4" rod all the way around and worked it down to the rest of the body and welded it up.  I ended up putting about a one inch weld every inch and a half all the way around the tunnel. Then I sealed up the rest of it with some 3M seamsealer I got from the body shop.  It turned out pretty good, not real pretty, but its functional and it will be covered with carpet anyways! :yesnod:
97 4runner Limited
pumkin toy
more
97 4runner Limited
pumkin toy
sealed up yo
97 4runner Limited
pumkin toy
thanks dude!  I will post some more pics when i get the cover plate and boots done
97 4runner Limited
89sastoyo
you should build me one. I have done mine twice and didnt like either of them lol sheet metal is to meticulous for me..
89 extra cab stock on 1 tons.
92 2wd DD
first gen cab
Check out the build.
pumkin toy
Quote from: 89sastoyo on March 28, 2010, 06:31:07 PM
ha ha, probly not man, I hate doing sheetmetal!
Quote from: THK90 on March 28, 2010, 06:39:55 PM
Lookin good K-Leb!
they call me C-murder
97 4runner Limited
89sastoyo
for sure yeah sheet metal blows. Im curious to see what you do on the top I was going to build mine similiar but I am most deffinetly stealing the idea of the thicker stuff by the u joint.
92 2wd DD
first gen cab
pumkin toy
Quote from: 89sastoyo on March 28, 2010, 07:30:50 PM
Well for the top I'm planning on cutting out a cover plate that will cover the access hole for the shifters.  This plate wil have holes cut in it that are just large enough to use the shifters full range of motion without hitting it.  That top plate will also have the rubber shift boots attached to it.  I am just going to use self tapping screws to hold the top cover plate on, so if I ever need to pull my shifters and their top plates out, I can just un screw the top plate and I will have plenty of room to get at everything.  Yeah I would deffinately reccomend puting in the 1/4" plate up over the driveline. For me it will serve two purposes- if the driveline fails at high rpm's, the thicker material will keep it from ripping through the floor- and it also adds the necessary strength to the main brace that the seatbelts and seats bolt to.
97 4runner Limited
NITE KRAWLERS
Looks sick dude! I'll be over in a bit wit the stick's yo!!!
pumkin toy
did some more work on the tranny tunnel monday.  I got the top cover plate cut out at work.  I stuck some 1/2" weather strip onto the back of it and screwed it down.  Then I screwed down my rubber boots and modified the plastic piece that holds the leather shift boots.  I had to weld a couple tabs onto the cover plate so I could attach the plastic section to it.  Turned out pretty good!  I still want to get my rear heater re-installed and functional, but it is not on the top of my priorities list.  I am hoping to get my new rear fenders done this weekend.  Here are some pics
97 4runner Limited
pumkin toy
with the leather boots, I want to get new leather boots made, and I also need to get one made for the second case shifter
97 4runner Limited
pumkin toy
thanks dude!  should look pretty good when i get all the carpet and interior put back in
97 4runner Limited
95SAS
holy crap you bobbed it!!!!!
SICK! tranny tunnels nice too.
1986 extracab, SAS 38.5's Locked Duals, truggyfied, beadlocks
1988 2wd bagged and body dropped 3'' with a healthy 22r....
my build
http://board.marlincrawler.com/index.php?topic=35602.0
pumkin toy
Quote from: 95SAS on March 31, 2010, 09:01:28 PM
ha ha!  did the bob a while ago.  thanks dude!
97 4runner Limited
bigarms23
