***CODY'S RUNNER*** *REDEMPTION**
Started by *** YELLER ***, October 19, 2008, 07:41:25 PM
brockbuilt85
Quote from: *** YELLER *** on February 20, 2012, 11:14:27 AM
got one in the shop if ya want it :thumbsup:
really? i was probably going to get 2 cause i think its the same as the rear? have not looked into it that far yet...???
Quote from: Slolyfe on February 20, 2012, 11:40:26 AM
Broke the Zerk off huh?
the cap is gone, c clip must not have been in it correctly i suppose? good thing its been in the garage since the con haha. :eek:
Quote from: fordh8r on February 20, 2012, 11:38:08 AM
Go high tech and just weld it in there! DUH! :slap:
your so right! what was i thinking?? :hammerhead:
When in doubt, skinny pedal!
Turd Box Build:
http://board.marlincrawler.com/index.php?topic=50894.0
Kaiser
I love the way your runner looks, not too overdone. Just an awesome cruiser/crawler
brockbuilt85
Quote from: Kaiser on February 22, 2012, 02:54:03 PM
thanks! its really more of a polished turd :thumbs:
Turd Box Build:
brockbuilt85
polished my turd a little this afternoon:
before
after
Turd Box Build:
brockbuilt85
OK!
so i have to get a new vehicle (the blue runner is giving up the ghost) and i have a desicion to make. A frind of mine has a early 90s 12 valve cummins 4x4 he wants to sell, under 150k miles, it is a salvage because he hit a dear and messed up the body, but its been fixed (cab replaced paint etc.) its a clean truck, but i dont know what he wants for it just yet
OR.....
Im eyeing a 2005 tundra 4.7 V8 work truck with under 70k on it.
http://www.modestotoyota.com/preowned/index.cfm/action/view_2005_toyota_tundra_4wd_reg_cab_work_truck/vehicle/5TBKT42105S460396/#tools
i do want the towing power of the diesel, but i dont want to drive it around as my daily driver. and from what i have read, the tundra will tow what i have just fine as long as i can find the proper trailer (which i have found a few). also a little leery of buying a 20 year old vehicle (thats what i have now haha).
Input appreciated. :thumbs:
Turd Box Build:
brockbuilt85
got me a tow rig :bling: and also fixe my front drive line last night, now its on to the motor mount bolts :yikes:
Turd Box Build:
brockbuilt85
haha, maybe if i get some time this weekend
Turd Box Build:
brockbuilt85
has anyone had an issue with their steering stabilizer leaking oil? looks like min is or something is dripping on it making it look like it is, but i dont see a drip spot. and i have not started the truck in a while, just fount a puddle of oil on the ground, cleaned it up and then next time i came out another smaller puddle........
doesnt smell like motor oil.
Turd Box Build:
fordh8r
Nothing dripping directly above or near it? It could be leaking. There is oil in those. :yesnod:
brockbuilt85
its got a pretty good dent in it, but it just started leaking, dent has been there a while, i cant see anything directly above it that is leaking, there are some areas of moistness, but not enough to look like its dripping. and even then its not directly above it. will i need a stabilizer to do hi-steer? if not ill just leave it, if so ill buy a new one.
Turd Box Build:
fordh8r
There's no reason to say that you'll "need" one but you might want one anyway. It's always a good idea for a 'streeted' rig. If anything, you could always remove it and set it aside to see if the oil leak follows it. :gap:
brockbuilt85
Quote from: fordh8r on March 28, 2012, 10:45:51 AM
true that. i should rip it all out and put that hi steer in anyway........ :gap:
Turd Box Build:
fordh8r
brockbuilt85
did some more work on the OBA, cant get the damn thing to work. i think i got a bogus switch from ARb, so i emailed them, hopefully i can get a replacement for free.
Turd Box Build:
fordh8r
Quote from: brockbuilt85 on March 30, 2012, 09:01:03 PM
Did you already check fpr power "in" and "out" of the switch?  :headscratch:
brockbuilt85
Quote from: fordh8r on April 01, 2012, 07:55:03 AM
well i have power on the acc wire. now that ive thought about the relay might be bad too.there is a red wire that should have 12v when still plugged into the switch terminal and switch set to on, but nothing is there. i was going to switch out the swotch with one my brother had but i guess he doesnt have that system anymore. the compressor works with direct power and when i switch the switch to on there is a draw on the system (volt gauge drops). hopefully i can get an answer from them soon. then i can move onto the tank.
Turd Box Build:
brockbuilt85
but to answer your question i did not have power on the red wire with system on, so maybe thats my problem
Turd Box Build:
fordh8r
Do you, by chance, have a diagram of your installation? This could make it easier to diagnose your problem if we can point at the same things even if we called them something different.  8)
If you draw one up, number each circuit or connection so we can point out each place for checking your system for a proper troubleshooting.  :thumbs:
brockbuilt85
i do have the diagram, this guy is basically it.
right now i have nothing hooked up to switch one or two, just the iso switch. (would that be a problem?) the red yellow wire (acc) has power. the red wire should have power when switch is on and spade is connected to the switch, but i dont have power in either position. hence my thought process that the switch may be bad
Turd Box Build:
fordh8r
Looking at that diagram, I would say to disconnect the Red wire from the switch (or near the compressor, whichever is easiest) and then , with the switch in the ON position and known voltage at the Red/Yellow wire, check for voltage at the spade terminal of the switch (or the Red wire itself near the compressor where you disconnected it) If you don't have voltage at either of those places then I would say the switch is no good.  :yesnod:
brockbuilt85
will do sir! your guidance and knowledge is always appreciated!
Turd Box Build:
fordh8r
No es problemo!  :bandit:
Another thing you could do is to just connect the Red/Yellow wire to the Red wire and see if it turns on. That would just bypass the function of the switch and if it is the switch that should make it work. Problem confirmed! Or you may have to move on to the next step in the troubleshooting process.  :beerchug:
brockbuilt85
i thought about doing that but i thought i would consult other sources before i just started connecting wires together haha :yikes:
Turd Box Build:
brockbuilt85
anyone have opinions about towing with a tow dolly?
Turd Box Build:
fordh8r
brockbuilt85
Turd Box Build:
brockbuilt85
i have some extra wheels i could throw on the rear and obviously disconnect the drive line. just trying to keep weight down is all, thought it might be an option
Turd Box Build:
fordh8r
brockbuilt85
would it being locked in the rear have issues?
Turd Box Build:
