***CODY'S RUNNER*** *REDEMPTION**
Started by *** YELLER ***, October 19, 2008, 07:41:25 PM
0 Members and 8 Guests are viewing this topic.
brockbuilt85
Quote from: ** YELLER ** on January 31, 2010, 05:30:46 PM
can you take the fuel pump off...or outa the tank, I can take it to rich and have him test it
i can once i get the timing chain back together, matty came by and looked at it, said its probably a tooth off, so im gonna try that, then if its still poopy ill pull the pump.
When in doubt, skinny pedal!
Turd Box Build:
http://board.marlincrawler.com/index.php?topic=50894.0
*** YELLER ***
Quote from: brockbuilt85 on January 31, 2010, 07:04:15 PM
ok cool
except BACON
brockbuilt85
everything apart, now going in opposite direction
Turd Box Build:
brockbuilt85
the tax return will allow me to get a marlin rear bumper :woohoo:
Turd Box Build:
*** YELLER ***
except BACON
brockbuilt85
so it was suggested to me to bump the timing one tooth over, so i did that, it still runs sluggish(just like it did before :thumbdown:). i think im going to put it back to where it was, then see what happens. but it does start and seems to run pretty darn strong, so thats promising.
so now im waitiung for it to cool down before i take the valve cover off again.
i feel better now that i got it to start, and it was something stupid cause i was in a hurry and wanted to get it going  :hammer:
Turd Box Build:
Wermz84
Quote from: brockbuilt85 on November 16, 2009, 05:12:52 PM
it appears my brakes are working now, yay!
did a compression test
cyl 1- 115
cyl 2- 115
cyl 3- 115
cyl 4- 125
guess thats what i get for a hundred dollars
so, i know the timing chain needs replacement, if the timing is off because of a bad chain, would that affect the compression?
also, im looking at timimng chain kits with steel guides, are these any good?
any constructive input appreciated
and...... discuss :thumbs:
I'm sorry to say, but those numbers are very low.  They are supposed to be around 170ish, with the minimum being around 140.   On the bright side they are all within 14 psi of each other.
Did you poor a small amount of oil into the cylinders to see if it would raise the compression?  that was one of my problems 3 engines ago. :gap: checked everything, terribly slugish esp up hill.  all my rings were shot, and my valve seals weren't very good either.
Keep at it. Other work is looking good.  :twocents:
I like to Drive!
brockbuilt85
well, i got it all back together and its running better. it will have to do until i can do a total rebuild. as long as it gets me up to the rim im good. ill just borrow my brothers truck for longer trips, lol.
Turd Box Build:
brockbuilt85
well, i took it over to my parents house, and used the neighbors tree to straighten out the front bumper, now i gotta reweld and gusset it.
a lil fun with a stump
Turd Box Build:
brockbuilt85
things to fix
figure out whats wrong with my clutch, might have to drop the tranny, dont wanna because of the "b*std bolts" on top of the housing.
figure out why my breaks are soft, even after ive bled them (hope i just bled them wrong, i hate brakes)
currently working on cutting off the mickey moused trailer hitch that the previous owner crack head welded to the bumper mounts.
Turd Box Build:
brockbuilt85
no more getting stuck on rocks with my lame trailer hitch
a lil clean up and ill be good to go, i dunno how much of the original bumper monts are needed to mount a marlin rear bumper so ill keep all the original stuff for now.
Turd Box Build:
brockbuilt85
ok, so most of the old hitch is gone, hope its enough to put in my new bumper, if not i am gonna have to borrow a torch. new bumper on friday, i hope, happy me.
Question:
i was messing with my clutch:
here is what its doing-when the clutch is disengaged, it makes a rattling sound, when you barely press in the clutch, it stops. i crawled under it and noticed that when its disengaged, the clutch cylinder does not rest against the clutch fork. doesnt that have to be resting against the fork to keep a lil pressure on the bearing/fork assembly, hence the reason for my noise? some one give me an idea here.
also, i have bled my brakes twice, and the still wont work unless i pump them. they worked before i re built the front axle, but one of the lines to the calipers was pinched off. now with out the pinched off line, i cant get them to work right, so i thought maybe leaky caliper, but i dont see fluid. try to bleed it again? give me a clue
thanks in advance guys
Turd Box Build:
subbrat
brockbuilt85
I'm working on it. I have to torch some stuff off first. Hope to get that done tomorrow and have it on. If not tomorrow thursday for sure. I do have it in my garage. And it's pretty freakin sweet!:thumbs:
Turd Box Build:
ROCKO
hey cody,
what is your timing set at?
you say it runs real sluggist correct?
mine ran the same way and i bumped up the timing from 5 degrees to 18 degrees and it ran like a champ.
when i took it to get smogged i would just put it back to 5 degrees and it would run like crap but pass smog then back to 18 degrees
JUST ANOTHER ROCK CRAWLER....
with a lot of good stuff
F@$K CANCER
brockbuilt85
Quote from: ROCKO on March 09, 2010, 09:33:40 AM
hey cody,
its runnin pretty good now, if i got a real exhaust on it im sure it would be awesome. im not really sure what the timing is at, i know i need to prolly tweak it just a touch, idles a lil rough.
Turd Box Build:
brockbuilt85
Turd Box Build:
*** YELLER ***
except BACON
brockbuilt85
Turd Box Build:
*** YELLER ***
except BACON
for the price, planet audio isn't bad :P
brockbuilt85
Quote from: THK90 on March 18, 2010, 08:38:11 PM
and i got a refurb, so it was cheaper yet.
Quote from: ** YELLER ** on March 18, 2010, 07:57:32 PM
what speakers you gonna run ??
i have the zapco reds 6.5" speakers and components from the suby, and a memphis M class 12" that i bought from nate a while back.
im going to build a vented box to place over the amps (in the pic is where i am locating them) removable so i can put thje seats up, but when i have them down i will be able to cover them up and not worry about damaging them or putting stuff on top of them.
Turd Box Build:
brockbuilt85
Quote from: subbrat on March 19, 2010, 07:28:13 PM
Looks good.  :driving:
yea, its a tight fit, and as soon as i bounce the bumper off something im going to have to do some custom fabrication to ge the tailgate open again. i blame the crack head.
Turd Box Build:
brockbuilt85
Things to do before  holister:
Fix Front Bumper thanks yeller
Crossmember
Stereo
Load up and Ride
Turd Box Build:
brockbuilt85
Things to do before  hollister:
Crossmember
Stereo bump bump
Load up, fuel up and Ride
Turd Box Build:
brockbuilt85
almost forgot i need to beat down my fender seams so they dont mess up my tires any more
Turd Box Build:
MiniSimp
Quote from: brockbuilt85 on April 09, 2010, 03:51:20 PM
Sheet metal edging!
*** YELLER ***
except BACON
