***CODY'S RUNNER*** *REDEMPTION**
Started by *** YELLER ***, October 19, 2008, 07:41:25 PM
0 Members and 6 Guests are viewing this topic.
brockbuilt85
The good news: no fuel leak! :thumbs:
The bad news: noticed the front knuckles are leaking. Yay!
Also it appears I need a new rear driveline
Womp womp
List to get back o the trail:
Bleed brakes
Fix air lines
Get new drive line
Put passenger seat back in
Maintenance:
Front axle seals
Torque all bolts
Check fluid levels
Clean up wiring
Extras:
Jerry can holder
Lights
To buy:
Tires
Wheels
When in doubt, skinny pedal!
Turd Box Build:
http://board.marlincrawler.com/index.php?topic=50894.0
brockbuilt85
Bleed brakes :thumbs:
Fix air lines
Get new drive line
Maintenance:
Front axle seals
Torque all bolts
Check fluid levels
Clean up wiring
Extras:
Jerry can holder
Lights
To buy:
Tires
Wheels
[/quote]
Turd Box Build:
brockbuilt85
ok, got a price on a new rear drive line, 130-200 depending on the thickness of tube i want (up to 120 wall) i was thinking about going with thicker tubing but was not sure if that would have adverse affects on the other components. thoughts?
Turd Box Build:
Rockcrawlintoy
Should be fine. I ran .095 wall I think and it held up pretty good.
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
brockbuilt85
Fix air lines- currently chasing down Leaks and looming
Get new drive line
Maintenance:
Front axle seals
Torque all bolts
Check fluid levels
Clean up wiring- slowly working o thus as I go
Extras:
Jerry can holder
Lights
To buy:
Tires
Turd Box Build:
brockbuilt85
Got the pig out I the sun today and rinsed off two years of shop dust. Also cleaned up the shop and gathered some parts to sell.
Turd Box Build:
OVRAROK
brockbuilt85
So the front axle knuckles have grease slowly coming out of the bottom, I'm guessing sitting for two years in a shop that freezes and heats up has kinda liquefied it enough to settle at the bottom and seep out? Thoughts on this? It doesn't have axle oil in it, just bright red clean grease.  It's a pretty fresh rebuild.
Turd Box Build:
WINGMAN
never wheeled a runner is there a big difference in the body roll
brockbuilt85
Quote from: WINGMAN on July 16, 2016, 04:07:34 PM
I've never wheeled a truck, so I can't compare. But these are much more top heavy.
Turd Box Build:
brockbuilt85
Get new drive line-sent off yesterday to be lengthened
Maintenance:
Front axle seals- going to torque everything up and see how it goes
Torque all bolts
Check fluid levels
Extras:
Jerry can holder-starting mock up on this
Lights
To buy:
Tires and wheels
Turd Box Build:
brockbuilt85
Get new drive line-sent off yesterday to be lengthened picking up today
Maintenance:
Torque all bolts
Check fluid levels
Extras:
Lights
To buy:
Tires and wheels
oh and wire this AUX port for this bad boy
Turd Box Build:
brockbuilt85
Warning: this topic has not been posted in for at least 120 days.
Unless you're sure you want to reply, please consider starting a new topic.
oops!
not much done on this, i did get a new battery and an actual genuine battery holder!
also upgraded my tow rig:
Turd Box Build:
brockbuilt85
Last weekends little outing
Turd Box Build:
brockbuilt85
Add brackets to springs to prevent fanning
Fix hood latch support
Maintenance:
Torque all bolts
Check fluid levels
Extras:
Lights
To buy:
Tires and wheels
Turd Box Build:
brockbuilt85
List before hollister:
bump stops
Maintenance:
Torque all bolts again
Check fluid levels
Clean up wiring- slowly working on this as I go
Extras:
Lights
To buy:
Tires and wheels (lol)
future major maintenance:
motor front end and pan re seal
Turd Box Build:
brockbuilt85
#1127
Maintenance:
Check fluid levels
Extras:
sway bar?
Lights
To buy:
Clutch
Rear main seal?
Turd Box Build:
brockbuilt85
Figured out why my lights were not working half the time, crap switches! Hopefully these will be better, they look better already!
Turd Box Build:
Tallchevy
Rock lights? The switch look more like boob lights!  :rofl2:
87 4Runner redo
brockbuilt85
Quote from: Tallchevy on January 19, 2018, 01:50:20 PM
I mean if they happen to light up some boobs it's a bonus
Turd Box Build:
brockbuilt85
So stupidest thing happened, the radiator sprung a leak while sitting the the shop!  :tantrum: must have gotten frozen, but it had antifreeze in it so im not sure.... :dunno:
walked into the shop and there was coolant on the floor. im going to put water in it and see where the leak is and then take it to a local radiator shop and see what they can do or its about $200 for a new one :crossed:
i also have one up in the shed i was going to take in and have them look at to see if the could repair it as well.
Things to do:
Repair/replace radiator
Maintenance:
Check fluid levels
brake line brackets for backing plat eliminator
Extras:
sway bar?
Lights
To buy:
Clutch
Rear main seal?
Turd Box Build:
brockbuilt85
Things to do:
Repair/replace radiator- put in an old one I had in the shed, see how long it will last, hopefully till the summer when I can get a new one
Maintenance:
Check fluid levels
Extras:
sway bar?
Lights
To buy:
Clutch
Rear main seal?
[/quote]
Turd Box Build:
brockbuilt85
used an old radiator i had up in my shed, so far so good, might be good enough to go to la grange in april then i can buy a new one down the line before the round up
Things to do:
Repair/replace radiator- temporarily fixed, need a new one eventually
Maintenance:
Check fluid levels
Extras:
sway bar?
Lights
To buy:
Clutch
Rear main seal?
Turd Box Build:
Unclejarhead
brockbuilt85
Nothing new to report. She needs some lovin
Turd Box Build:
