If you're going with Chevy 63's the front spring hanger (bolt center line) should be 11 inches forward from the stock hanger position. This should place your rear axle in the stock location. Then you can place those rear hangers pretty close to where you have them positioned in your pic...maybe slighty rearward more depending on the shackle angle you're looking for.
OH! Almost forgot... for the best (and cheapest option) also use the stock Chevy 1/2T U-bolts and spring plates as your U-bolt flip kit. The bolts are 5/8 and fit the Toyota axle perfectly. The U-bolts are bigger than any other option out there for this.
let me know if ya want someone to watch ya I get bored LOL
leave the leaf in, most of the builds are for trucks and 3 leafs are to soft for Runners . . . trust me
Was that from a 1/2T? Maybe just run it and see if you like it first. If you don't then pull a leaf.
soooooo i have a main leaf, then 4 leaves, then an over load......
Is it all together and sitting on the ground?
Started by runninout General 4WD Discussion
Started by early_morning Toyota Pickup/4Runner Tech 1979-95
Started by Thomas P Parts For Sale
Started by SR5Yota « 1 2 ... 5 6 » Project Research and Build-Ups
Started by wyomingben New Member Check-In!
