***CODY'S RUNNER*** *REDEMPTION**
Started by *** YELLER ***, October 19, 2008, 07:41:25 PM
0 Members and 25 Guests are viewing this topic.
fordh8r
 :biggthumpup:
Quote from: brockbuilt.85 on July 04, 2014, 09:57:42 AM
Hella to the yes it was! Thank you for your knowledge friend! :bowdown:
Glad I could help for whatever it was worth.  :biggthumpup:
fordh8r
You betcha! Glad I could help.   :beerchug:   Now get your :moon: to MCR, would ya?  :slap:   :cheese: :ha_ha:
brockbuilt.85
Ya I downloaded the tap talk app but can't figure out how to link it to my existing profile lol, oh well.
brockbuilt85
#993
Possible idle fixes Fixed!
PVC valve
low coolant level
dirty idle screw
vacuum leak
Clogged small coolant hose
Adjust valves
Check plugs/wire/rotor
Replace motor (ha)
Problems that will prevent me from going to the round up:
Trailer brakes over heat going down hill gonna break up my trip or drive the crawler part ways
Truck doesn't run that great (has trouble Idling and wants to die) fixed!
Things to do before round up:
Finish rear and install rear bumper
Jerry can holders for rear bumper
Re wire winch/replace (tommy how did you wire yours is there a disconnect somewhere?)
Fix motor idle/try to make run better the car gods have smiled upon me!
Remove top?
Sign up for round up
Get time off work
Tighten everything down
Change oil
Fix/replace cb radio
Swap out sub
Replace turn signal
Mount second fire extinguisher
Put on Tube doors?
Go through tool boxes and make sure everything is ready
If all goes according to plan I may have an extra seat or two, maybe bring my doggie!
Sell this pile and get a land cruiser(right after I hit the lotto) maybe next time
6 weekends till round up!!
When in doubt, skinny pedal!
Turd Box Build:
http://board.marlincrawler.com/index.php?topic=50894.0
brockbuilt85
PVC valve
low coolant level
dirty idle screw
vacuum leak
Adjust valves
Replace motor (ha)
Trailer brakes over heat going down hill gonna borrow a trailer
Finish and install rear bumper
Remove top?
Get time off work
Change oil
Swap out sub
Replace turn signal
Put on Tube doors?
5 weekends till round up!!
Turd Box Build:
*** YELLER ***
if ya need help with anything let me know :)
except BACON
brockbuilt85
Dave I'll let you know, I will need help lifting the bumper to install
PVC valve
low coolant level
dirty idle screw
vacuum leak
Adjust valves
Replace motor (ha)
Finish (needs paint) and install rear bumper
Remove top?
Get time off work
Change oil
Swap out sub
Replace turn signal
Put on Tube doors?
4 weekends till round up!!
[/quote]
Turd Box Build:
fordh8r
So yer going to MCR then?  :thumbs: :woohoo: :beerchug: :wiggle:
brockbuilt85
Out with the old frowny face bumper...
Turd Box Build:
fordh8r
brockbuilt85
That's as far as I got tonight lol
Turd Box Build:
fordh8r
*** YELLER ***
call me when ya wanna get the big dog mounted buddy
except BACON
brockbuilt85
Well it's a little closer, took care of a highly annoying window rattle. Also got it a bit closer for bumper attachment. But I was also lazy most of the day and hid from the heat, haha
Turd Box Build:
brockbuilt85
:eyebrow:
It doesn't fit exactly the way I want it and I will have to keep in mind my departure angle from now on, but there will be so much more room for activities inside now!
Turd Box Build:
brockbuilt85
Turd Box Build:
brockbuilt85
#1006
PVC valve
low coolant level
dirty idle screw
vacuum leak
Adjust valves
Replace motor (ha)
Jerry can holders for rear bumper not going to happen before round up
Remove top? not this time
Get time off work
Change oil
Swap out sub
Replace turn signal
Mud flaps
Put on Tube doors? going to go full doors
If all goes according to plan I may have an extra seat or two, going in Tahoe side mid morning/day Thursday
1 1/2 weekends till round up!!
I'm looking good and on schedule!
Turd Box Build:
brockbuilt85
  My god damn hard line on the passenger side brake caliper freakin' broke! For no reason at all! All I did was turn the damn thing around and it started puking fluid!
This may be an issue. I ordered new ones and I have a friend who could probably fix it but he is out of town till Friday.
:smack:
Turd Box Build:
1985CRAWLER
brockbuilt85
Turd Box Build:
brockbuilt85
PVC valve
low coolant level
dirty idle screw
vacuum leak
Adjust valves
Replace motor (ha)
FIX MY GOD DAMN BRAKE LINE!!!
Re wire winch/replace started this, hard part is done, just need to finish
Get time off work
Change oil
Swap out sub
Replace turn signal
Mud flaps
1 weekend till round up!!
[/quote]
Turd Box Build:
brockbuilt85
PVC valve
low coolant level
dirty idle screw
vacuum leak
Adjust valves
Replace motor (ha)
FIX MY GOD DAMN BRAKE LINE!!! looks like the new ones are on the way, and I might have someone to fix the old one worst case
Get time off work
Change oil
Swap out sub
Replace turn signal
Mud flaps
Turd Box Build:
fordh8r
I expect to be at the trail head around noon or 1 if the ride up is uneventful. Then just air down and head in. If you can spare the time I'd like to go in with ya.  :beerchug:
If anything, you do know where we plan on camping, right?
brockbuilt85
We are going in about that time possibly. Leaving morning time and towing with a gasser, lol.
Turd Box Build:
fordh8r
Ok, well, if we see you then we will go in with you. As far as I know we will be in my rig solo and I would prefer to not go alone....buddy system and all. You know.  :cheese:
brockbuilt85
Quote from: fordh8r on August 13, 2014, 06:39:16 PM
Pm me your cell, I'll make sure I'm there when your there, we shall make the voyage together :gap:
Turd Box Build:
fordh8r
brockbuilt85
delivery confirmation puts my brake lines on my door step :yupyup:
:thumbs:
Turd Box Build:
brockbuilt85
Getting down to the wire, looking good! Gassed it up, running great, just kind of drifts at 50mph, but not too bad, don't plan on going much faster than that
PVC valve
low coolant level
dirty idle screw
vacuum leak
Adjust valves
Replace motor (ha)
FIX MY GOD DAMN BRAKE LINE!!!looks like the new ones are on the way, and I might have someone to fix the old one worst case
Get time off work
Change oil
Replace turn signal
Mud flaps
Turd Box Build:
brockbuilt85
Getting down to the wire, looking good! Gassed it up, running great, just kind of drifts at 50mph, but not too bad, don't plan on going much faster than that (realized my tire pressure is still low from the last wheeling trip, that could contribute to drift lol!)
PVC valve
low coolant level
dirty idle screw
vacuum leak
Adjust valves
Replace motor (ha)
Get time off work
Change oil
Replace turn signal
Mud flaps
Put on Tube doors?
gassed up and ready to load up my camping gear and put it on the trailer! :thumbs: :gap: :willynilly:
3 days till round up!!
Turd Box Build:
