***CODY'S RUNNER*** *REDEMPTION**
Started by *** YELLER ***, October 19, 2008, 07:41:25 PM
brockbuilt85
Quote from: fordh8r on January 05, 2015, 01:59:01 PM
Is it all together and sitting on the ground?  ??? :snapshot:
no we got the spring on, i need some longer ubolts, and to remove a leaf, then weld up the hangers. as soon as i get my parts ill continue.
1. replace brake line with longer one
2. remove leaf from each side and see where it sits
3. weld up brackets
4. bolt axle to leaf springs
5. hook up drive line
6. (hopefully without taking the roof with me) drive out of shop
7. shock placement
8. bump stops
When in doubt, skinny pedal!
Turd Box Build:
http://board.marlincrawler.com/index.php?topic=50894.0
fordh8r
Thought you was gonna just leave the 5 leaf set up amd see first. Is it because you plan on just reusing your existing u-bolts? :headscratch:
brockbuilt85
Quote from: fordh8r on January 05, 2015, 03:35:47 PM
I got a ubolt flip kit from Dave for free and they are too short for that spring pack, and the 5 leafs give me way too much lift in the rear from what we alas way the mock up, so I'm going to bring it down to 4. I don't think I can keep the 5 leafs on there and get it out of the shop due to ceiling clearance haha
Turd Box Build:
brockbuilt85
Turd Box Build:
brockbuilt85
Turd Box Build:
brockbuilt85
Turd Box Build:
brockbuilt85
Turd Box Build:
brockbuilt85
Turd Box Build:
Jud
 :twocents:
Quote from: brockbuilt85 on November 28, 2014, 12:37:23 PM
So this is finally happening! I've seen so many different suggestions as to where to place what it will make your head spin. Any suggestions? Right now it's about 4 1/2". I have a 6" rear shackle, it's sky's kit. They have a small write up saying it should be at 2-2 1/2" but that would require taking out the existing hangers which I'm going to do anyway, but I need to disconnect it all to do it. Just wanted to get some ideas from people here.
I have always mounted the sky rear hangers right where you have them and they have always worked good for whatever rig it was on. I usually just add the extra length of the Chevy's vs. stock Toyota's and move the front hanger up by that much (putting the rear axle in the stock location)  :twocents:
"bout tree fiddy"
fordh8r
brockbuilt85
busy cleaning up that yard. might be able to get back to it soon. need to take springs back out and pull the leaf. while they are out ill weld up the hangers. need to replace brake line. i need to figure out what to do for my upper shock mounts still, i got some lower ones that are made for the contour of the axle.
Turd Box Build:
fordh8r
Quote from: brockbuilt85 on January 15, 2015, 09:50:20 AMi need to figure out what to do for my upper shock mounts still
Make some like the ones I made for the Devil Dog.
*** YELLER ***
except BACON
MRHilux87
Never seen those shock mounts. I like it. The more yotas I've had and rear suspensions I've done, the less I lime the upside down v design.
1987 4Runner.   3RZ.  SAS Duals 5.29 Elocker Rear Detroit front 35s... Hydro assist
2007 Cummins 6.7 DRW g56.  deleted EFI live.
2013 Ninja 1000
SOLD:
2006 Mitsibishi EVO 9.  347WHP runs 12.2s - Wifes daily driver.  Ducati 916 - track bike.
fordh8r
Quote from: MRHilux87 on January 15, 2015, 06:37:35 PM
Thats probably because they are hand built one-off custom mounts. Thanks! Compliment well received. :)
*** YELLER ***
sorry for the thread jack Cody
MRHilux87 START ON PAGE 10  the shock mounts start there and some other cool stuff
http://board.marlincrawler.com/index.php?topic=82525.0
except BACON
brockbuilt85
Quote from: fordh8r on January 15, 2015, 10:41:55 AM
I don't see me buying a plasma cutter in the near future.......
Turd Box Build:
*** YELLER ***
Quote from: brockbuilt85 on January 15, 2015, 09:03:35 PM
a torch will do the trick too
except BACON
fordh8r
brockbuilt85
Turd Box Build:
fordh8r
You could always make a trip out my way with materials in hand.  :beerchug:
brockbuilt85
what are the dimensions on those things, steel thickness. i think i have some 1/4" flat plate, 4" wide i could cut some chunks out and mold them. my brother might have bought a plasma cutter ill look into that as well.
Turd Box Build:
*** YELLER ***
Quote from: brockbuilt85 on January 16, 2015, 10:54:31 AM
I have a torch set up if ya need it bottles are empty but its available
except BACON
*** YELLER ***
or if you sell parts of that link kit, you can use some of those shock mounts and call it even :)
except BACON
brockbuilt85
3 link kit may be sold complete, it didnt have shock mounts with it anyway ill look around in my parts bucket there might be stuff i can use, i dunno. ive got a ways to go before i get there anyway haha. would like to have it on its ruber again before i should need those
Turd Box Build:
fordh8r
I believe they are 1/8". Plenty strong in a double shear set up like they are. 1/4" is a bit much but will work just fine.
brockbuilt85
since its bought and paid for i will make it work, just will be extra beefy haha
Turd Box Build:
brockbuilt85
Ok here is the list for the current project:
1.Weld hangers in
2. Mount springs
3. Replace and Bleed brakes
4. Mount shocks
5. Mount bump stops
6. Box in rear frame
7. Install gas tank
8. install seat
9. Test drive
Need to buy one shock tab (have the rest), 4 ubolts and hardware.
Next project:
1. replace shocks
2. Replace shock mounts on axle
3. Replace clutch
Need to buy clutch and pressure plate, shocks and shock mount.
Spent some time today assessing things and cleaning up the shop to get if back to square one, like to work in a clean organized space where I know my tools are where they are supposed to be. Cut off the old hangers yesterday (most of I them anyway, still some remnants).
Turd Box Build:
brockbuilt85
Shop flooded tonight, project to be delayed some......😞
Turd Box Build:
brockbuilt85
got some shop time today and finished welding the brackets on for the passenger side and a little frame reinforcement
i also remembered that i have a problem with the fule pump bracket, any suggestions? i looked into buying one but was told that they dont make them for my truck (gave them my vin).
Turd Box Build:
