The Tuki Suzuki - Toyota drivetrain, Samurai body
Started by 4RnrRick, October 14, 2007, 09:24:42 PM
COToy91
How short is that rear driveline going to be? Are you going to use a CV back there?
4RnrRick
Yes - I'm planning on building a CV rear shaft, also.
The distance between the pinoin flange and T-Case flange at full compression is:
Front 25 1/4"
Rear 26 3/4"
If I built the drive shafts to the correct length (24.75 fully compressed) - I should be able to swap them front to rear! Well thats the plan but I haven'y cycled the rear yet to see if it doable. If its not - I will just make/buy a driveline spacer so it will work.
Jordan7118
Quote from: 4RnrRick on March 16, 2008, 08:08:09 PM
It's all about interchangeability!  :grad:
COToy91
Looked shorter in the pictures, anyways good plan. Any reason for running coil overs and not air shocks?
4RnrRick
Quote from: ColoradoToy91 on March 16, 2008, 08:30:51 PM
I wanted the dual spring rate and remote reservior capablities which AirShocks don't have. Got to remember that this is not just a rockcrawler - but a general use 4wd which includes: Snow, Sand, Rocks, Mud, Trails, Prerunning......
Although - I might have to run airshocks in the rear because they are more compact.
TheCookieMonster
those link mounts are baller :bowdown:....cant wait to see this beast on the trails :yesnod:
twistedtoy92
4RnrRick
twistedtoy92
4RnrRick
No, my own private shop with more room than a small two car garage, so I could actually have some real equipment.
twistedtoy92
TIMS89CRAWLER
oh my this thing is bad ass for sure... the links look f-ing sweet as all of your work does bro...
www.choptechfab.com
www.myspace.com/choptechfab
CHECK THE BUILD
COToy91
Quote from: 4RnrRick on March 17, 2008, 07:37:54 AM
What brand are you going to run Fox, Kinig, Racerunner? I thought that air shocks were in a way dual rate due to the adjusting or both nitrogen levels and oil levels, but i am prolly wrong. Are you going to run any kind of limiting strap?
4RnrRick
#734
I already bought the 2" SwayAway RaceRunners with remote reserviors for the front.
From my understanding airshocks are NOT dual rate. However they do have some progressive rate spring qualities to them. and don't seem to be linear like a coil spring. Anyways - I choose coilovers and BillaVista just finished this killer tech articles that I still need to dig in and read.
The Coilover Bible- Part 1: http://www.pirate4x4.com/tech/billavista/coilovers/Part_1/
The Coilover Bible- Part 2: http://www.pirate4x4.com/tech/billavista/coilovers/Part_2/
For limiting straps my current plan is dual winches with in-dash controls......
Front: Warn HS9500i
Rear: Warn M6000
Made a heavy wall rear CV shaft tonight. Front shaft is 24.25 fully compressed. Rear shaft is 26.25 fully compressed. I wanted to make them both the same length, but its just not feasible with stock toyota parts and I thought a 2" driveline spacer was a bit much. But I did find out with some test fitting that in an emergency I could run the shorter front shaft in the rear - I would just have to limit my droop (easy to do with a rear winch), otherwise it can seperate. I'll probably just make a square shaft for a spare that will stay in the trailer.
COToy91
4RnrRick
Pinoin angle at ride hieght is about 17 degrees.
4RnrRick
And this is how I'm gusseting up the axle link mounts.
man the angle at the flange on the Tcase... is steep at ride height.
gnob
hold this. . .
twistedtoy92
4RnrRick
Quote from: ImaHoToy87 on March 18, 2008, 09:13:26 PM
Not really since I'm using a double cardan joint... 17/2 = 8.5 degrees per u-joint. I didn't measure the angle at full droop, but its probably about 25 degrees which I think was about a degree or two from the CV binding. I've ran these joints at 14 degrees with no issues and don't expect any here.
Matty
great work as usual.  im looking forward to seeing the rest of it come together.
TBS
I'd like to know a few more details on your drive shaft assy. Like what size tube you used  and how to set up your dial indicator apperatus if you've got a minute.
4RnrRick
ROCKO
JUST ANOTHER ROCK CRAWLER....
with a lot of good stuff
F@$K CANCER
Quote from: 4RnrRick on March 19, 2008, 07:36:06 AM
i knew you had it figured out, just had to check. :thumbs:
4RnrRick
Found my new rear diff inspection / fill plug at lunch today. Its a #16 SAE weld-on bung and hollow hex plug with o-ring. I got it for about $15 from a local hose and coupling store.
