The Tuki Suzuki - Toyota drivetrain, Samurai body
Started by 4RnrRick, October 14, 2007, 09:24:42 PM
Quote from: DirToyBoy on April 15, 2008, 08:15:35 AM
Not worried about those gettin smashed out rick?
it doesnt stick out past the tires :dunno:
4RnrRick
Not really...
I would break the LED brake/turn lights on Quasi probably once every 6 months. but those were about 24" behind the rear tires. I would never even touch the back-up LED's on the corners of Quasi. and these ones are actually a few inches IN FRONT of the back edge of the tires. I really doubt I will have any issues. And if I do in that rare case, I'll just pay another $8 for one down at Napa. Its better than $25 for the LED ones I ran on Quasi.
fatt_matt
Jeep
Phazertwo
92 xtra cab, with some stuff...
Quote from: yotabj on October 30, 2006, 10:01:02 AM...why buy when you can build?
4RnrRick
Mounted up a 1.5 gallon fire extinguisher (recently pressure tested to 330 psi) for my OBA Tank. Would have been nice if I could have got my old 3 gallon tank in under there, but there just wasn't room.
Then I re-arranged my garage to get the sami tub in a better position to get the sheetmetal work finished up on that. First was to clearance the the back of the drivetrain tunnel and the e-brake cable mount removed.
Then I got the driver side all sealed up.
And tunnel capped off the back of the tunnel.
TIMS89CRAWLER
 :bowdown: thats nice sheet metal work man!!!  :yupyup: looking good
www.choptechfab.com
www.myspace.com/choptechfab
CHECK THE BUILD
TIMS89CRAWLER
what rotors did you use on your rear disc setup :dunno:
www.choptechfab.com
CHECK THE BUILD
Phazertwo
Got an expected date for it to be under its own power?
PZ
TIMS89CRAWLER
www.choptechfab.com
CHECK THE BUILD
4RnrRick
Quote from: timsyota on April 21, 2008, 08:32:41 AM
Sky Brackets, MonteCarlo Calipiers and Chevy Rotors
Quote from: Phazertwo on April 21, 2008, 04:25:09 PM
PZ
Some time in 2008............ I hope!
Quote from: 4RnrRick on April 21, 2008, 07:27:18 PM
is that all you need to convert the rear?
4RnrRick
Got the passenger side all sealed up - I only need to cut out the removable panel from a piece of metal for the front driveline access.
4RnrRick
Cover made....
Then I painted the inside with good old spray bomb (Dark Gray Rustoleum).
4RnrRick
Got the firewall and under carrage cleaned up and painted.
KDXSR5
The Samurai is looking sharp! The floor turned out really nice. :thumbs: I hope I get to do a frame up build on one of my trucks some day...
Duffil
hmmm why the paint? I figured you were gonna bedliner it.
TIMS89CRAWLER
 :bowdown: all that floor work came out beautiful man! :biggthumpup:
www.choptechfab.com
CHECK THE BUILD
4RnrRick
Quote from: Duffil on April 23, 2008, 08:57:57 PM
When bedliner gets dirty its just turns a funny grey brown color... with paint atleast you can clean it.
KDXSR5
They make smooth herculiner from what I understand. I think I saw them paint a truck with it in Peterson's 4wheel and 0ffroad a while ago. Its still bedliner material, but it does not have the bumpy stuff in it. I am going to try it out on my new truck once I get it running.
I looked, and can't find it right now, maybe it wasn't herculiner. I will look into it more later.
Quote from: KDXSR5 on April 24, 2008, 08:10:38 AM
if you take the roll on kind and roll it wil a smooth roller.... it will be smooth... the roll on kind... the reason its "bumpy" is the roller they give you... gives a texture.
DTB
Quote from: HO on April 24, 2008, 08:24:48 AM
Actually the reason it is bumpy is the anti-slip material in it (usually rubber or sand) The stipple effect comes from the roller. They do make smooth bedliners too. Durabak makes a sweet product   http://www.nonslipcoating.com/   ...sorry kinda off tropic
BigBs84
That floor looks factory, love your build, good job Rick :thumbs:
Build it wright-wind it tight
   High-N-Tight offroad
http://board.marlincrawler.com/index.php?topic=45027.0 My truggy build
twistedtoy92
Your work KICKS ASS!!!!! I really wanna see that badboy crawlin!!!
KDXSR5
Quote from: DirToyBoy on April 24, 2008, 08:32:42 AM
I think Durabak was the one I was thinking of, thanks DTB! Yes off topic, sorry.
70 Cam Guy
Quote from: KDXSR5 on April 24, 2008, 02:19:10 PM
I don't mean to continue the hijack but this has to be the article in question
http://www.nonslipcoating.com/smooth-durabak.htm
Thanks!  I am going to try this stuff in my bed and I'm thinking about doing the wheel wells and paint along the sides below that body line.
It might not be Rick but I seem to always get ideas or learn something new in Rick's thread  :biggthumpup:
KDXSR5
Quote from: 70 Cam Guy on April 24, 2008, 10:05:58 PM
THATS THE ONE!!! :thumbs: Dark Grey is where its at.
