shackle tech ?
Started by Phazertwo, October 28, 2006, 08:11:33 AM
Phazertwo
I am trying to make new shackle's for my budget SAS.  How thick should they be, and why? looks like marlins are about 3/8ths.  I cut some from some extra 3/8ths I found laying around, but they seem kinda thick.  They are going to 6in from eye to eye, with 1/2in between the edge of the hole and the edge of the radius on the shackle.
I don't just wanna know what you would build them outa, I wanna know WHY!
TIA
PZ
Quote from: yotabj on October 30, 2006, 10:01:02 AM...why buy when you can build?
havik
for what it is going to cost to make them your self.(time and money) i would just order some up from marlin. i went the do it your self rout and ended up just ordering a pair. marlins are cheap, proven and wont rust.
my  :twocents:
got another 85 runner. build coming soon!!
yotabj
3/8 steel would be fine....Why does it seem too thick... I built mine for just the cost of bolts and nuts and have 30 min. of time involved...why buy when you can build?
'84  Truggy EFI swap ,5.29's Detroit,welded,Dual Ultimate Cases,22re,3 in. downey,4 in.Marlin Front springs on back  114 wb ,39.5 Rockers,30 Spline Longs
alwayzbroken
30mins? :headscratch: ??? Did you use a plasma cutter? Cuz you can't cut 3/8" anything that fast unless you have a major sized bandsaw. I made a set and it took all afternoon with my bandsaw. It took about 30mins for each cut!
yotabj
steel was free from scrap yard it was 2in wide ...All I had to do was cut to lenth and drill the hole ....I have a friend that owns a machine shop..so cutting it and drilling it was no prob.....guess i shoulda mentioned that :hammer:
alwayzbroken
I gotcha. I was assuming you were cutting them out of 3/8" plate like I did and I would rather have just bought them for 6$ each when I was done. If you had a 2" wide piece it would be simple.
Phazertwo
I work in a machine shop, so its all easy, I just work on them during lunch, and breaks.  3/8ths it is!
PZ
Phazertwo
alwayzbroken
Why waste your time with the sawzall and grinder when you can buy :gap: JK
sidewall2000
Quote from: alwayzbroken on October 30, 2006, 10:16:20 AM
<----- laser cut all 8 pcs in 3 minutes... tops!
85 Runner, Fullwidths 44/60, dual 5:1's (488:1), locked, 40" Iroks
www.HillHoppers.com
www.Toys-4-Fun.org
gotrocks
plasma and it takes me all but of maybe 30 mins for a finished pair
Hyena
i built mine at school in about an hour.  used 2''x3/8's flatbar and cut them with a torche.  and they are like 10 inches long too.
yotaboy79
10 min tops holes and all, used the iron worker at work and just sheered of some 3/8x2 fb and layed them out and punched them
this is starting to turn into a competition
gotrocks
oh yeah well.....
n/m I'm done I don't have anything to say
Phazertwo
I guess I am slow because I am at like 45min right now, and I only have them cut out.  I still have to radius them and drill the holes.
oh wait this thread was SHACKLE TECH, not HOW FAST DID I BUILD MY SHACKLE!
MiniSimp
Took me about 30 seconds to order mine from AllPro :greengrin:
Phazertwo
Quote from: MiniSimp on November 03, 2006, 08:06:55 AM
and i bet its 12 in LONG!
MiniSimp
Actually 5.5" eye to eye and pivots side to side 30 degrees. :greengrin:
Phazertwo
sorry, saw this and I had too!
MiniSimp
 :talkingn: That's great!
Another picture saved in the "Forum" file. :thumbs:
alwayzbroken
What size drill bit is used to drill the holes? I just want to go buy one rather than figure it out if anybody knows already. Thanks.
MiniSimp
On mine, one end is 5/8" the other is 9/16"
Get both and you'll be covered.
alwayzbroken
Quote from: MiniSimp on November 16, 2006, 12:24:24 PM
That is for the johnny joint rear shackles I assume that is why the two are different sized. Thanks Mini
