0 Members and 16 Guests are viewing this topic.
@DirToyBoyhey...DTB nice work just a questionyou mount the power-Steering Box with a Plate or without
its not actually mounted yet. its just mocked up with the c-clamp to drill holes. Yes, I will be using this to plate it.
thanks u know what is funny is that you guys are my only source of info....everything I have learned so far I learned from the intardweb
We all know the merits of a drill press, but after doing 2 boxes myself, I don't see how it would be easier to use a drill press for this. It doesn't take more than an hour to do anyway.
brake lines on outside.IFS steering shaft for the replacement. OR cut and sleeve it... be sure to do a bunch of plug welds b/c it's your life
I'd just cut it out and replace it... the xmember y'know.make it your own beyotch.nice rig btw
Quote from: MR_DIY on Apr 15, 2007, 02:18:56 PMI'd just cut it out and replace it... the xmember y'know.make it your own beyotch.nice rig btw the gas tank mount is attached to that crossmember though i suppose i could cut the mount off and weld it to a new relapcement tube...dunno i was just looking for an easy answer...i know there never really is one lol
i used some 1x.120 wall hrew tube and drilled some holes for a plug weld and then welded the whole thing up Drwe
I ran my lines on the outside on my 81, that's where they were anyways, and all (except very old vehicles) have 2 piece steering shafts so that when you have a frontend collision it will colapse instead of pushing into your chest killing you. They are held in place by a pin that if you remove the pin it will allow you to extend it out.
The third gen trucks have one piece steering shafts with the accordian that collapses in an accident. That will work DTB. That is what I did except I added my extension on the other end of the shaft.Why do you need to cut out that crossmember in the back? My shock hoop fits easily behind the round crossmember.
You need to add exhaust to the to-do list also.
Where can I get one of those cool 2 bulb florescent drop lights?
Started by RockToy New Member Check-In!
Started by toybuilt Rig Gallery
Started by DAWGTOY Toyota Pickup/4Runner Tech 1979-95
Started by DTB « 1 2 ... 6 7 » Project Research and Build-Ups
Started by brainlessfool Chit Chat Camp
