DTB's ANGRY TREE HUGGER (Now pulling an angry pop up camper)
Started by DTB, January 22, 2006, 10:48:06 PM
DTB
Quote from: BLACKDOG on April 17, 2007, 06:13:06 PM
DTB, just weld some angle iron over the crossmember.  then you have a square mount to have the bolt heads rest against.  :thumbs:
I'm liking that idea..thanks BD...we'll see.. :gap:
BLACKDOG
Quote from: DirToyBoy on April 19, 2007, 02:02:38 PM
Thats what I'm going to do when I get around to it.  I drilled holes through it for bolts, and they just stretched the holes out.  little extra support, and a flush mounting surface for the bolt sems like it would help.
              -Ronald Reagan
DTB
Got a little work done yesterday......not enough hours in the day ya know?
Rear perches welded in
Steering box plate burned in. you can see where I had to cut out part of the rad. mount and a small section out of the body mount to clear the box
Measuring toe-in
Gittinit
looking good DTB! I had to clearance mu body mount the same way. Did you rotate the box up some for extra clearance? :thumbs: I can't wait to see this thing in person!
my favorite places:
http://www.flatnasty.net/
http://www.orvpark.com/
DTB
Quote from: gittinit on April 19, 2007, 06:09:42 PM
ya i did rotate it up a little. I figured out what im gonna do with the rear driveshaft for now. Im gonna make some spacers for the carrier bearing to lower it about an inch and I'm gonna shorten the stock rear shaft. After I dual case it I will run a one piece shaft  :biggthumpup:
Gittinit
Quote from: DirToyBoy on April 19, 2007, 06:21:40 PM
Good thinking! So how long till ya go duals? Are you still gonna be 4.88 with the swampers?
my favorite places:
DTB
Quote from: gittinit on April 19, 2007, 06:26:18 PM
Duals? not sure....i can only handle thinking about one project at a time...I would like to flat belly it when i do duals so we'll see about that....
moved up to Precision Gear 5.29s for the 36's   :yupyup:
Jud
"bout tree fiddy"
DTB
Got a little work done today...sorry no pics...
Got the ram tabs welded on the axle and tie rod, cut out the rear crossmember, finished welding in rear (had to drop the gas tank to weld the inside of the passenger spring hangar in the rear. I still havent decided what to do for shock mounts in the rear. I have a couple extra shock hoops sitting around so I was thinking I could cut the lower part of them off and weld to the inside of the frame on each side for vertical shocks. Then weld a bar connecting the tops of the shock hoops and doubling as a crossmember. Sound like a good idea? I wish I knew how to draw stuff on the computer...anyone know a website online where I can draw on pics? I dont have a paint program on my work computer here.....
dude,  weld  some 2x2  tube  between the frame rails
and send me those hoops  :slap:
DTB
Quote from: 79coyotefrg on April 21, 2007, 08:01:08 PM
haha thats what my buddy christian said too...he said HE wants them...
I like the idea of vertical shocks since I can build the flatbed around the mounts if needed. Here is a pic from Kaptains build up on pirate....pretty simple idea but I dont think there is enough support on the top of those mounts! A bar to tie them in or gusseting would be appropriate IMO . what do you guys think?
yea  they need to be  hooked together,   but  i  not sure  you'll get  the flex  you want  like that,  not without having a REALLY long travel shock
but  on my truck that round  crossmember  is  directly over the axle  so  my shocks  are mounted there from the factory,  but with the 2 inch body lift i could make a bracket  to raise  them another 6 inches  to  just under the bed floor
91 super yoda
Quote from: 79coyotefrg on April 21, 2007, 08:13:14 PM
thats the plan that i had, when i put rear springs on ill let ya know how it goes.
DTB
new trailer for the toy.it has a hoist with a warn winch on it! sweet...now i just need a tow rig...
BUBBA
you know,for a few dollars more you could have gotten a green one.
My budget beater
alwayzbroken
DTB
time to get to work :whip: :flamer: updates soon
man i LOVE that trailer  :love:
and a  engine lift  :woohoo:  MAN  i NEED  one like that :yesnod:
just imagine,  you can  go  to a junkyard  and  pull you're  own stuff  without killing your back  :eyebrow:
Gittinit
Your toyota is oficially a trailer Queen! :gap:
my favorite places:
Michael,  do you EVER  check your email  :eek:
alwayzbroken
I don't know if I would go anywhere near the junkyard with that trailer. It might accidentally get picked up by the magnet and crushed  :laugh:
Gittinit
Quote from: 79coyotefrg on April 24, 2007, 08:51:25 AM
About once a month....I guess its time. :hammer:
Quote from: alwayzbroken on April 24, 2007, 10:17:05 AM
Function over form! :gap:
my favorite places:
alwayzbroken
What are you gonna buy for a hauler now? I wonder say mid 90s 2wd dodge diesel with a 5 speed. About the best budget hauler you can find.
topar
*** YELLER ***
except BACON
DTB
I figured out why this build is taking so long its because i keep stopping to take pictures!  Its slower than 6.72's build :haha:
Ok so I think I'm pretty much done...just waiting on a shortened driveshaft to get out of the garage and flex it so I can mount the shocks.....
cut out the old crossmember in the rear. U can see the problem here
cut off the top of the tube on the bracket to just weld up to the new tube :idea:
Sleeved with 1 and 5/8th DOM
clamped tank and bracket up
voila! easy enough right? I will use this now as a good base to build the rear shock hoops (?) / mounts
welding ram tab on tie rod
dinner break
*** YELLER ***
except BACON
Duffil
DTB
its a mango crabmeat salad on cumin apple chips....girlfriend made it
Quote from: DTB on April 27, 2007, 07:01:59 PM
:puke3:
