OVRAROK. My 87 4runner
Started by OVRAROK, July 11, 2014, 04:04:18 PM
SqWADoosh
Is the plan to run the hose out the side windows?
I have a 60ft hose, when the top is on, ill just open drivers door, I'm making a molle bag to store hose, it will attach to my trasharoo :sly:
SqWADoosh
Quote from: ovrarok on December 09, 2015, 02:51:31 PM
Reason I ask is because I have loved the positioning of mine being on the more aft angled bar. Runs out the back window and with my coiled hose reaches all 4 tires with ease.
Quote from: SqWADoosh on December 09, 2015, 03:41:39 PM
main reason is my old smittybilt c02 sat in that same spot, and I always pack everything the exact same every time, if I moved it I would have to rethink location of every other item
SqWADoosh
Quote from: ovrarok on December 09, 2015, 04:36:59 PM
LOL that is true you had your system down pat!
1985CRAWLER
Come snow wheelin up here sometime Dave !
Quote from: 1985CRAWLER on December 09, 2015, 08:28:24 PM
that's what I'm preparing for, just wanted to make sure I had air to air up
1985CRAWLER
If you arnt doing anything this sat morning roll up here I plan on going wheeling , would be cool to show you around here
just found these on Cl, great price, went to pick up, met this Russian guy, by the name of Sergei, what a cool dude, here's his website www.life-adventure.com. would have liked to sit around a campfire and hear his stories
Sent from my HTC One_M8 using Tapatalk
84_yota_4wd
The door panels are very impressive bud, Great Job.
Marlin Crawler
(888) 94-CRAWL / 888-942-7295
Quote from: 84_yota_4wd on December 15, 2015, 09:13:14 AM
you ever need a set, just let me know mitch
84_yota_4wd
Thanks I need some new doors in general, When I first started here I had the factory doors that were in great shape. Then I started my truck in gear one day and well Long story short there went he doors.
Now I have crappy non sr5 doors. That are not in great shape.
When I get my Sr5 doors I would love a set.
Marlin Crawler
Quote from: 84_yota_4wd on December 15, 2015, 09:29:05 AM
when your ready let me know, Ill give you a great deal
Quote from: liveoak on December 15, 2015, 10:40:08 AM
i think you need to make a long story long. I've started my truck in gear many times and my doors never disappeared or got damaged in any way  :headscratch:
I have started a vehicle and drove backwards a few feet, the door caught the post of a 4 post lift....... oops
84_yota_4wd
Hahahah, well I just started here and Marlin had been working on my engine.
I came out after my shift and it was parked with the hood up in the back.
I was curious to see if it sounded any different, so I went to start it up.
I had just come from working on big rigs for several years and its a cardinal sin to leave it gear as if someone standing out side the truck starts it i will hurt someone or something. So I did not check to see if it was in gear  :hammerhead: and started it while standing next to it. It fired right up and took off ended up pining me between the fencepost and the truck. Luckily I popped it out of gear while I was pinned. It bent the door around me but somehow it did not hurt me.
Now I have some really crappy non sr5 doors that leak. Always check your Stick
Marlin Crawler
got a little at the house
Tube bender showed up
twistedtoy92
sweet! how much did that run you?
Quote from: twistedtoy92 on January 08, 2016, 04:37:58 PM
It set Santa back 745, I have another 1" dye coming for my welding cart that I need to make when the Miller 211 arrives
Nation
the milller 211, and my 300 amp magnetic ground
got my bottle
mdtrail-toy
That magnetic ground is sweet :bowdown:
redneckcustoms13
Man, was Santa good to you or what?!
01 double cab hunting truck
06 tacoma street truck
Dwill817
That first gen grill is AWESOME!   :yesnod:
erict716
How did you do the transitions from the door panels to the window? Curious if you kept the piece of rubber from the old panels or scrapped it.
Quote from: erict716 on January 11, 2016, 04:22:05 PM
if your referring to the door panels I made, they are for an 84
So I got my bender squared up and burned together, going to the powdercoater tomorrow
helipilot77
