Chim at it again!
Started by chim, February 27, 2011, 08:58:22 PM
83 Crawler
ya i got the evap box, and i was looking at that kit, i dont wanna run the box lol, since deq is pretty easy to pass up here
chim
Engine is now running!!! Wahoo.. There were two wires that were wired incorrect and then the fuel pump needed to be wired a little different so it's alive!!
chim
Video quality is just ok, I will get a decent one this weekend.. It still needs radiator hooked up and alternator and intake... Lots to do :)
83 Crawler
sweet you work fast man, wiring that bad?
chim
Quote from: 83crawler12 on March 19, 2012, 09:28:18 PM
My buddy is a wiring champ and makes it look easy so I cant take credit. I will post some notes though when I am done but basically you need to identify the wires first and that takes the longest.
83 Crawler
If i pay your buddy think he would help???
chim
I can ask him... If anything I can get you my diagrams and highlight the wires that we used. It should be the same for the 3RZ side but body side would be different since you have first gen...
83 Crawler
ya i think be alot harder on my end
zippo
Nice. Glade to see its running. All that stuff look familiar? Weird!
If you see it, its for sale.
chim
Quote from: zippo on March 21, 2012, 02:20:13 AM
So far the swap has been pretty smooth.. lots of little stuff here and there that add up in time but it should be running this weekend! Although I will have to drive it to the exhaust shop on straight header!
83 Crawler
Quote from: chim on March 21, 2012, 07:41:58 AM
what shop you takin it to?
83 Crawler
and where you gett your bellhousing from?
chim
Quote from: 83crawler12 on March 21, 2012, 08:17:52 AM
I am not sure yet.. I made a sketch that I was going to send to a couple local places in Oregon City to get a quote.. I need to find somewhere as close as possible because I don't want to drive to far with open header.
chim
Quote from: 83crawler12 on March 21, 2012, 08:38:51 AM
It came with the swap I purchased from Zippo. W59 bellhousing
83 Crawler
o alright cool, jw, ill try and find one around here,
and theres a good place on 212 called get bent, i herd they do good work
toyotanner
Quote from: 83crawler12 on March 21, 2012, 09:38:22 AM
x2
chim
Quote from: 83crawler12 on March 25, 2012, 12:47:15 AM
Updates???
It's running! I drove it up the street yesterday. I think today we will spend a couple hours cleaning up then maybe sometime this week I will drive it to the exhaust shop and get that done. It's running straight header now. I will get a video up tomorrow with picture updates :)
83 Crawler
good you better, maybe next time your in town i can meet up and check it out?
chim
Quote from: 83crawler12 on March 25, 2012, 10:55:17 AM
Yeah that would be cool
chim
We decided to use the 22RE Fan so that the stock shroud would work without cutting... its a little smaller fan but since its in the shroud it should cool at least as good or better than the 3RZ with no shroud. Bolt pattern was the exact same as the 3RZ but the 22RE fan had to have the holes drilled out for the larger studs on the 3RZ side.
chim
Upper radiator hose is stock 98 Tacoma 3RZ hose with no cutting.
Lower radiator hose is 95 T100 2WD 3RZ. I trimmed one end 1.5" to have it clear steering joint. Fits great.
(Using 22RE Radiator)
chim
This picture is taken as a reminder to jump a couple wires. Runner would fire and run about 2 seconds then die... So the old Mass Airflow sensor was jumped in shrink wrapped up and fixed the problem.
chim
Stock 3RZ oil pressure sender would not work with factory oil pressure gauge. But the 22RE oil pressure sender worked like a champ.. just swap senders, splice the wire and go!
As a note: the volt gauge and temp gauge work fine with no mods.
Tach is not hooked up yet because I believe it needs the 10ohm resistor soldered in.. I need to find a pic of how its done.
chim
Then out of the blue we decided to throw in my add-a-leafs since I rub with my 37's.. I am also sagging in the rear with the 63's.. so I bought 2" add-a-leafs... now its level and should help with the rubbing...
Before:
After:
Before:
After:
chim
I'm hoping to take a day off of work this week to get the exhaust done. Then sometime this next weekend we will run codes on the engine before completely soldering all the connections and calling it complete!!
83 Crawler
Sweet man how big a differnce over 22re?
chim
Quote from: 83crawler12 on March 26, 2012, 09:08:43 AM
It's kinda hard to tell at the moment because I didn't want to rev it too much with the straight header.. it was just too obnoxious!
