91 4runner on the operating table-- Needing to sell!
Started by GONZO97, January 02, 2010, 08:54:12 PM
Joey88RUNR
If its not completly burned in, get it out and plate it in with 1/4" plate like what i did
LilGonzo86
if we use the torch and just recut it out.... im pretty sure we can just plate it after......wont be easy but its worth a try :therethere:
86bobbedtoy
I made one of mine a little off, and just filled it with weld, no biggie
I do plan on plating the bottom of the frame there tho
GONZO97
Quote from: Joey88RUNR on March 05, 2010, 02:04:08 PM
Its all completely burned in but the angle is off a decent amount im definitely going to have to chop it out and then plate it in order to make it strong enough....but this time im going to make sure it is perfectly straight i have no idea how it is that off since i used the jigs but oh well i guess you learn from your mistakes and ill make sure it gets done properly this time. I need to start doing my research on how to rebuild a front axle properly since ive never done it before i want to make sure i do it right...any info on this would be greatly appreciated. Thanks guys.
-Gonzo
1997 4Runner Limited 3" lift on 31 M/Ts-Traded
http://board.marlincrawler.com/index.php?topic=61054.msg749103#msg749103
1995 Xtended Cab SAS on 35's Dual Cases-Sold
1991 4Runner SAS on 33s RUF 63's in the back Bilsteins all the way around, 5.29s front and rear Detroit locked Front and Rear http://board.marlincrawler.com/index.php?topic=65180.0
1988 4Runner 3.0 V6--SOLD
http://board.marlincrawler.com/index.php?topic=97592.msg1086573#msg1086573
1996 Toyota 4Runner 3.4 V6 3" OME Lift Springs 33" Duratracs
The Build:
Coming Soon
GONZO97
Alright heres the news... spent all day yesterday cutting and trying to fix the shackle angles that were off... well i got it done.... its all even again... not the prettiest looking and stuff but itll hold up just fine.... now its time to try and figure out how to rebuild my axle lol i hear the first time is always the hardest
The Build:
Coming Soon
<MIKE>
i rebuilt my front 44 for the first time by using online resources only. there is a lot of info out there for toy axles and from what i hear they're easier to rebuild than domestic axles. should be fine.
1987 4runner
Dual cases, 2.28-4.7
Dana 60 Rear; Danna 44 front; 5.89's
249:1
GONZO97
Ive already looked up a few good threads and rebuild instructions... i would just feel a lot better if my cousin would be there.... my cousin... being 82juguete... but of course he is at cal poly and when he does come down hes usually busy so looks like the first time will have to be done alone...
The Build:
Coming Soon
<MIKE>
ya i know what you mean. just make sure to take your time and use the threads. you will find its not that hard and if you ever need to fix it on the trail at least you will know how.
1987 4runner
249:1
GONZO97
Yeah im going to... before i start im going to lay out everything and make sure i have everything i need before i start that way i can run to marlin and get all my stuff in order first.... im probably going to need a bunch of hardware and stuff since it was an axle that was already in pieces
The Build:
Coming Soon
<MIKE>
1987 4runner
249:1
GONZO97
Just gotta figure out what it is that i need first lol
The Build:
Coming Soon
<MIKE>
load it up in a truck and take it down maybe? be easy for them to figure it out for you. or post up a pic with all the parts.
1987 4runner
249:1
GONZO97
Yeah Ive been trying to get those front leafs in and fixed up before i dig into the axle but now since thats done ill be able to lay all my goodies out and see what i need to go pick up...prob do that tomorrow since im at school right now and get to go to work right after this
The Build:
Coming Soon
GONZO97
Well i think tomorrow is the official day that im going to try and get it done...hopefully everything goes smoothly i have a ton of research done i just hope im not missing anything....now its time to pick up the grease and oil for my diff....any recommendations and exactly what stuff to get? im going to autozone later itd be nice to know the name of what i need so i can just grab it real quick!
The Build:
Coming Soon
GONZO97
Not yet got it started and realized i needed my high steer so i went and got that today most likely ill get it finished tomorrow morning...ill post when its done
The Build:
Coming Soon
94pickup
Nice build man, way to keep at it. Rebuilding the axle is cake once youve done it the first time. best advice for that is take your time, use lots of grease, and make sure you get the seals and such in the right order on the inside portion of the knuckles. Also make sure to get all the studs tight. :thumbs:
82juguete
Ill post for you....  We ran into some weird issues today, and ive never had problems like this in the 2 or 3 axles ive rebuilt.  Then again, ive never used the big vented rotors so theyd work with later model calipers, so....
Anyway, did everything like usual and once i got the spindle, backing plate, etc on and seated the new races in the rotor, greased up the bearings and put it on, theres barely enough threads on the spindle to get both spindle nuts on.... i remember having a lot more threads on previous rebuilds.  We did torque it to 43 to seat everything, backed it off ,blah blah blah...
well we went with that, since technically we got the lock nut to barely snug up.... get out to the hub assembly and now the axle shaft cant pull out enough to get the snap ring on... so somethings gotta be off causing a clearance issue in 2 separate places....just cant figure out what it is.
GONZO97
Thanks nico was just about to post... any ideas ???
The Build:
Coming Soon
GONZO97
Alright guys well thanks to 82juguete we got the front end done i have a little bit of miscellaneous stuff to do still but for the most part its done and rolling! by the way its too tall for my liking so i'm going to take off that  :pokinit: body lift.... enjoy!
The Build:
Coming Soon
GONZO97
and just for the record the problem that we had earlier actually turned out to be the oil seal not seating properly once we took it apart again and made sure it seated properly everything went together flawlessly!
The Build:
Coming Soon
dk98
take off the body lift before you do the shock hoops
884runner 4.3 needs to be refereed
Jakesteads
I like Toyota
GONZO97
i would go wheel it....if it had an engine :/ and dk98 that body lift is coming off sometime next week .... Spring vacation!!!
The Build:
Coming Soon
Jakesteads
ya i got rid of my BL from a 2" to about a 3/4 best thing i ever did lol
I like Toyota
GONZO97
Pretty sure mine is a 3" lift....going to knock it down to right around 3/4 as well
The Build:
Coming Soon
82juguete
keep everything as is, get a flatbilled mulisha hat, mob it and pull some skunk haired beezies.
GONZO97
The Build:
Coming Soon
<MIKE>
lookin real good man. keep up the good work. x2 on the body lift removal. it will look perfect afterwords.
1987 4runner
249:1
joeycool00
Hey gonzo what was your setup on the brakes an rotors?
