84 reg cab CO: HALT! Now an 85 Runner
Started by wakkjobb, October 11, 2009, 11:07:03 AM
wakkjobb
Page 11 brought to you by Pabst Blue Ribbon... "When you've got $2 and want a tall boy, Pabst is your beer!"  :beerchug:
I want to get pics too and measure for bumpstops... the shaft shop hasn't called and they are closed weekends so I'm hoping it's done Monday or early Tuesday even. I'd drive down in front-drive if I had to.  :hammerhead:
I may venture into the carb to lower the float tomorrow; I'm nervous since I've never dealt with a Toyota carb and I don't have a spare to practice on first. Also I hope I have the HAC hooked up right; I went off pics online and vacuum diagrams, with the few mods I've done it shouldn't stall out like it did on Eagle Rock.
See? It's out of the shop:
Here's what I've been working on today:
I need some piping to connect the air cleaner inlet to the fender area and maybe a screen with a splash shield on it for good measure. Then I have to be careful not to drive through really really deep water.   :gap:
>>Dan
Jakesteads
just cause its on 4wheels doesnt mean it moves on its own
I like Toyota
dezrik
Quote from: wakkjobb on March 19, 2010, 05:48:06 PM
I may venture into the carb to lower the float tomorrow; I'm nervous since I've never dealt with a Toyota carb and I don't have a spare[/u] to practice on first.
I know a guy :D
wakkjobb
Quote from: Jakesteads on March 19, 2010, 06:08:02 PM
Oh yes it does! Went next door and climbed the neighbor's big dirt pile... in front-drive.  :gap:  And of course, no pics. It was backed in for the longest time while I was doing the springs and now it's nosed in so it moves under its own power. Nyah.  :wag:
Quote from: dezrik on March 19, 2010, 06:11:04 PM
I know a guy :D
I'm thinking about it but saw a loose carb at the yard last time I was there. Plus a carb is $30 and I have store credit from a fender that didn't match. Note to self: 2wd and 4wd fenders are different.  :think:
>>dan
boggerunner
they look the same to me with a sawzall fit
and after 1 wheeling trip
wakkjobb
It was for another board member; he needs one in pretty decent shape. Mine? They're going to get cut, sawzall/cut-off disc/plasma, whatever.
>>Dan
wakkjobb
Picked up the CV-equipped rear d-shaft today; going to attempt slider install tomorrow with Jakesteads after a mighty breakfast from King's Chef Diner.
>>Dan
wakkjobb
Had to re-drill the t-case flange since the CV was from an early truck with awesome 8mm bolts; it's got the 10mm now. I welded a bit of reinforcement around the drilled area since the bolt holes are really really really close to the edge... seems to work so far. Hey, quick question/possible answer:
I pulled the t-case flange and gear oil dropped out; "that no good" I say. Does that mean the seal between the trans and t-case is leaking? If so, how the F do I fix that or do I just wheel it and fix it when I do duals?
More to the point; is this a bad leak/do I need to fix it ASAP or can it wait?
Also, the truck won't idle since I stuck on the HAC the other day. As far as I can tell it's hooked up right (but obviously not) but I can't tell what's wrong from pics online or vac diagrams. I even made a sketch when I pulled it at the yard but it's still funky. Anyone? Hint? Throw me a frickin' bone here!  :headscratch:
Tomorrow should be slider-day and/or bed-rail day; here's hoping I can get my POS to idle.
>>Dan
wakkjobb
Duh, pics!!  :beerchug:
Stop staring at my shaft:  ($115 with new tube and balance)
1979 CV action, engage!
Mystery sealant on the flange washer... uh-oh:
Strikes 1,2 and home-run!
It's good...
What goes where for the HAC?
>>Dan
Volcom
Quote from: wakkjobb on March 22, 2010, 09:13:58 PM
Hahahahaha, I drilled my flange out to fit a CV as well.  I didn't add any reinforcement and have been wheeling it this way for 3 years now :D
84 4Runner
Marlin Dual Ultimate crawler
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
Jakesteads
my cv is better than all your CVs... naaannananananaa n
I like Toyota
wakkjobb
Quote from: Volcom on March 22, 2010, 09:46:36 PM
I spray-painted where the holes had to be and was scared at how close they were to the edge so... welder, deploy!
Quote from: Jakesteads on March 22, 2010, 09:56:50 PM
Yeah, but I have a winch and you suck   :beerwhack:
>>Dan
wakkjobb
Wow, I slipped to page 2; better update this   :cheese:
Today:
battery tray
lowered float in carb
fixed the auxillary accelerator pump
got HAC stuff sorted out (I hope)
picked a Taurus fan
made a winch hook hanger on the stinger
...and I scored a small ARB compressor for fixing a 76 CJ-5's ignition switch. The bad thing is the power wires have been cut really close to the body so some soldering is in the future. But it works; jumped the wires to a battery and it pumped right up.
>>Dan
Jakesteads
I like Toyota
wakkjobb
That ARB compressor is like $300 from what I can find.
Nyah
wakkjobb
Here's the compressor; I've been trying to find specs for it but no luck yet.
Cut wires for the fail... :down:
Stuck some rebar on the stinger for the winch hook; I think it's better than wrapping it around and winching it snug/tight:
I did the 'float-lowering' wrong since the fuel level is above the sight glass, whoops.
>>Dan
dezrik
Jakesteads
we need to plan a trip to moab.... we have to im dying to go
I like Toyota
wakkjobb
I don't have enough coin to go to Moab; it's the same feeling I get thinking about Vail and Aspen (neither I want to go to).
I may have fixed my high-idle problem; there were a few things wrong with the carb:
-choke plate was loose
-someone (me) had the HAC lines all wrong
-stock float level sucks
-mixture screw was almost all the way out
Still want to get a second carb to rebuild while I drive this one; took it out for a quick snow-bash today... y'know what's funny about snow? You can't really turn in the deep stuff.
Tree: 0
Bumper: 2
>>Dan
wakkjobb
Finished the cold air stuff; need to take off the fender to see where I have to add baffles for water protection after this stunt:
:haha: :haha:
http://www.youtube.com/watch?v=0zBBo6sQJDk
:cheese:
>>Dan
COToy91
I have a spare ARB compressor that needs to be rebuilt, but the lines for power are longer. You can have it if you want it, same one you have
wakkjobb
Sure, I love spare/free parts. Would 2 of those be enough for OBA or should I pull an A/C compressor I saw in the yard from an 80-ish Volvo. Dang thing is HUGE!
COToy91
Quote from: wakkjobb on March 28, 2010, 05:39:35 PM
That is why there is something wrong with the one i have, They get way hot when pumping for a while and then die. I would get a york and be done, I love mine.  You can run air tools or whatever all day as long as you keep it oiled with 10w30
COToy91
Just pay attention to what side the suction is on if you are laying it on its side in a bracket
wakkjobb
#324
I may get that Volvo's comp since I read somewhere the early Volvos came with the better/bigger Yorks. I've read a lot about OBA set-ups but haven't jumped into that project yet; I want to get a bigger alernator before I do much of anything else. Here's what I've found that looks pretty good to me:
http://www.kilbyenterprises.com/oba-scem.htm
I'm also getting a fuse block from 12voltguy.com to run the extra electrical stuff to avoid burning down the truck.
wakkjobb
Quick nit-wit question:
Since I have a forward shhift t-case (that I was told has 4.7s), can I just stick it behind another forward shift case for duals?
Or do I absolutely have to find a top shift to run duals?
I'm trying to avoid extra work/money if my case has 4.7s in it already. :headscratch:
COToy91
Quote from: wakkjobb on March 29, 2010, 12:31:20 PM
The crawl box can be forward or topshift. Rear case must be topshift. In the FAQ on pirate is a cheap way to conver without have to swap in top shift shift rails. Ill see if i can find it
wakkjobb
Awesome... guess I'll pull a forward shift case next time I'm at the yard--after this summer/wheeling season, that is. I do want/need to replace the rear trans seal since the t-case has started to leak from its output seal. At first I thought, "I didn't fill it THAT full... did I?" I didn't. Now I'm super glad I drilled that flange since I didn't notice it leaking before. I don't want to burn up my trans before/during a trail ride. To the Marlin Store!!  :burnout:
A (Tuesday--HA!) question regarding tire balancing. I've read about those DynaBeads and checked their site for info and all that. Since they list the amount/weight of beads to use, couldn't I just use BBs instead of buying the DynaBeads? Maybe they have some special coating that's better for the tire rubber or something... I dunno. I'm a total cheap-ass/broke so wherever I can cut costs, I will.
Quick Draw
Most people do use BBs.  I bought some though and then found that I would have to pop the bead to put them in, because they certainly weren't going in the valve stem with the core pulled out...  I was really hoping it would be easier than that.
'80 Pickup, 5VZ-FE engine, A340F transmission, Marlin gear drive adapter, Dual Ultimate transfer cases, 5.29 gears, Detroit rear/Lockrite front locker, 37" Goodyear MTRs, XRC8 winch, custom tube bed and armor
