84 reg cab CO: HALT! Now an 85 Runner
Started by wakkjobb, October 11, 2009, 11:07:03 AM
wakkjobb
Just 33s? I'll go last since I have a winch.
Jakesteads
I like Toyota
wakkjobb
Went to the yard and picked a few brake parts to get rid of the LPSV (or whatever) tonight; am going to follow this build:
http://www.4x4spot.com/proportioning.htm
and hope for the best. I'd still like to get a big bore master cylinder down the road but at least this is a decent start towards better braking. Also picked a day/night miror since mine is neither. There's an 87 2wd that has decent doors (and they're silver) if you've got the half-door itch, Matt...  :psss:
>>Dan
wakkjobb
LSPV is gone; have to bleed the brakes tomorrow. Still thinking about dropping the fuel tank to clean up the loose vacuum lines since I found a few more tonight. Am holding off on the hydro until next week just in case something decides to break/go wrong during the switch-over. Might get sliders on tomorrow too if I get up early enough  :ha_ha:
It's getting closer...  :driving:
>>Dan
wakkjobb
Got the tank out; guess what? I'll give you a hint:
It sucks!!
And it's starting on the driver's side as well:
Awesome...  what the hell am I going to do with this rust? It's insane! But on the plus side I got the vacuum lines taken care of and am going to get new rubber fuel hoses since these are old brittle factory goodies.
dezrik
That side of the Frame is thinner then the opposite side, Just cut it out make a cardboard template and weld in new steel, The main structure of the toyota from is the outer C not the Inner part.
Jakesteads
super lame ya sat im gonna overhaul my axle :pokinit: sucks!!!
I like Toyota
wakkjobb
Bet it sucks more in the cold...
I'm going to the yard in a few days for Chevy springs; then get/make some front hangers and check out double shackles for the rear. I'll also stitch in some metal after I hack out that little rust spot  :hahaha: . Maybe that had something to do with my death wobble, eh? Bat it didn't help the rust at all either. I'm surprised it didn't split the frame as bad as it was shaking!!
I am still in shock about that F'n rust.
:beer:
dezrik
Its a 26 year old Vehicle its going to have rust :D, stop complaining and get to work.
el picas82
were in co do u live ...me  in platteville
83 217000 22R :hammer:
wakkjobb
I can deal with rust but it's a shock to see it that bad. I have a 67 Chevy 4x4 that needed almost an entire new floorboard; rust is not a stranger to me at all.
I'm in Colorado Springs up in Black Forest to be specific.
>>Dan
Jakesteads
dan i have ur rear shackle mount dont do doubles i have 2 from the sky off road kit
I like Toyota
wakkjobb
I was looking at that on pirate; it got me confused... but then again that happens easily.  :headscratch:
I'd take a triple flange from ya too and whatever else you're getting rid of if you sell that Runner. Don't sell your Runner, nobody else goes wheeling around here and it's risky going alone!
It's too cold to go to the yard but their inventory shows about 10 88-98 GM trucks there so I'll be able to get 63s easy. It's the front hangers I'm trying to figure out. The FAQ Bible said CJ hangers, or 3.5x3.5x1/4", or 3/16" box tube; bet I can make something at school for this. We'll see... eventually.
>>Dan
dezrik
Jake, your 4runner is badass, Id buy it if i had the cash, Will you take Payments :D
wakkjobb
I started on the hydro tonight; got everything undone except the box since it's WELDED TO THE FRAME!!!!!  :punish: What else... re-did the negative terminal end and ran a second ground to the engine, cleaned off the sliders (they were oily...), drank a beer or five and stared  at the IFS box in disbelief. Another thing I noticed was the bumper bracket on top of the frame is hitting the steering box; I'll notch/cut/trim it when the box is out.
Oh, and get this: even though the box is welded to the frame it still had 3 bolts on it; a 17mm, a 15mm and a 9/16" nut and bolt. The 17mm goes into the frame but is stripped out... super awesome fun time action time is here!  :shake: And the torque bar was chopped off but the frame mount is still there. Dang it, if you get rid of something get rid of ALL OF IT!!!!
Crap!
>>Dan
Volcom
Make sure you brace the area under the steering box.  That sucks the PO welded the steering box to the frame  :slap:
84 4Runner
Marlin Dual Ultimate crawler
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
wakkjobb
I read some tech pages and getting plate steel is on "the list" for today/early next week. Would the Marlin IFS box kit work or should I just stitch some metal on the frame?
Since the box is welded on I thought about cutting it off with the chunk of frame it's attached to. Not the entire section, just the outer part that it's actually welded to. Bad idea?  :dunno: Figure it'd be okay since I'm going to weld in beter steel to mount the box to.
>>Dan
Jakesteads
just take a angle grinder and go to town u will prob poke some holes in the frame... you can just make your own plate motor pretty easy.... if you have the steel .... i wouldnt take the entire frame out
I like Toyota
Volcom
Don't cut that frame out in the area around the steering box.  That area takes a ton of abuse from the big tires and steering them.  Just add some 1/4" plate like this under the steering box & on the inside of the frame rail.  I just bought a kit since I was on a time crunch but it would be easy to make them.  Make sure you fishmouth the ends so you don't have vertical welds on the frame.
84 4Runner
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
wakkjobb
Okay... what's bad about having vertical welds on a frame?  :dunno:  I may break down and get the Marlin box mount kit since Home Depot only has 2" wide 1/4" plate and the steel place I go to sells it in huge chunks and charges $20 per cut.
I'm starting the cutting process; it should be extra fun since the welds are mostly bidrpoop consistency. I wonder if I could chisel the thing off...
>>Dan
wakkjobb
Got the box off; it wasn't too much "on" to start with. 1 cut-off disc and some grinding and it was off. The frame's cracked by the bole holes though... what a surprise. Anyone want an IFS box with slight weld damage?
Quick Draw
Go to K&K Surplus at around I-76 and 88th. kksurplus.com  They have lots of scrap they sell for 50 cents/pound and if they don't have it in scrap, the new is reasonable.  And they charge $5 for a cut.
EDIT:  Now I see you're in the Springs...so nevermind.  But do some searching.  There has got to be a K&K equivalent down there...  Or it may even be worth the drive.
'80 Pickup, 5VZ-FE engine, A340F transmission, Marlin gear drive adapter, Dual Ultimate transfer cases, 5.29 gears, Detroit rear/Lockrite front locker, 37" Goodyear MTRs, XRC8 winch, custom tube bed and armor
Jakesteads
sweet ive been looking for scrap metal in DENVER good call quick draw
I like Toyota
Volcom
Quote from: wakkjobb on February 20, 2010, 05:58:03 PM
The shear effect.  It's easier on the frame to have a fishmount or angle cut.  Plus it's easier to weld something at a 45 degree angle compared to straight up & down.  The weld puddle is hard to control on a vertical weld.  Notice how far I had to move the box forward.  You might consider doing the same.  I had to cut the front fishmount off of the frame brace so I had to weld it vertical.  It's just recommended to have an angle.
This is the way you want your tie rod / drag link to line up, parallel
84 4Runner
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
wakkjobb
My steering is pretty parallel now; should I move the box forward anyways? The frame cracked around the bolt holes anyways... but that should be fixed with a Marlin kit and welding; right?
>>Dan
el picas82
nice  to know ill have to check kk surplus out .... i just spent $300 some angle,  tubing a  and a sheet of 1/8 ... in greeley :hammer:
wakkjobb
Box welded to frame:
Box de-welded from frame:
The stripped bolt I was going to cut decided to come out with the cut-off disc:
Frame cleaned up:
Dang shop's a mess:
Diego, the gearhead dog:
Tore apart the old front axle; what a greasy fun time!
For Sale:
>>Dan
wakkjobb
Hey, I have a retarded question: Should I run a stabilizer once I get the hydro installed?
Other than that, no new progress or the Rust War.  :thumbdown:
>>Dan
And buy my axle parts already! :bat:
Jakesteads
dan i know how to fix your problem.... cut the entire back end off and make a truggy!
I like Toyota
COToy91
Quote from: wakkjobb on February 22, 2010, 06:17:04 PM
>>Dan
nope, no point
