84 reg cab CO: HALT! Now an 85 Runner
Started by wakkjobb, October 11, 2009, 11:07:03 AM
wakkjobb
I still have to sort out everything but you have first dibs. I'm trying to sort this out in my head of how it's all going to go down... I need one of those drilled flanges and an axle socket if you have a spare or four; this is going to be some kind of fun, I can already tell.
I think it'd be best to pull both axles into the shop and tear everyone apart and rebuild with 5.29/Detroit then sell the other stuff.
>>Dan
Jakesteads
ya i got a flange for u... and lemme check my sockets if i have a spare one ill hook u up....
do u need a triple drilled one or just the regular one? i have both either way next time im in the springs ill grab the bumper and bring that stuff down for u to look at... lemme check right now on the socket
I like Toyota
wakkjobb
#92
I'd like the triple drilled dealie; I was going to drill one out to make my own but I'd probably eff it up somehow. I'm good like that...  :shake_head: If you don't have a spare socket I may have a friend who should have one. I'll bug him tomorrow; otherwise the axles will wait. I'm still fighting the wiring but the battle is nearly over.
>>Dan
And photobucket is being a photobitc# now so I can't load pics just yet.
wakkjobb
I may do the axles this week, have to re-weld the exhaust, an oil change and seal the oil pan tomorrow; it's the only thing leaking! (so far)
Went up Mt Herman today and across to Rampart via 315; all at 10 psi. Aired to 30 at the Sinclair station in Manitou and my death wobble came back with a vengeance... which is how I broke the exhaust off. Luckily it was only a few miles from home so the open header wasn't too terrible to deal with; sure was loud though.  :shhh: I got a video of the truck flexing out; the fenders need a little trimming for sure. Other than that is was an uneventful outing; I want to start earlier next time, we left around 1 and got home around 7-7:30; just in time for FOOOOOOOOOOOOODDDDDDDDD!!!!!!!!!!!! :yumyum:
So I was wondering about my death wobble... could the rear shocks have something to do with it? They're mounted inboard at a 45 degree angle... or could having 30 psi in the tires be the culprit? I'm going to air down to 20 and see what that does, hope it helps.
Also when the hubs are locked (not in 4wd) it's a pain to steer but when unlocked it's fine. I'm guessing this is normal with lockers? I almost ran off the trail a few times because of this... it was kind of scary.
>>Dan
wakkjobb
So I pulled down the oil pan and found some plastic bits in it that were once a timing chain guide. Pulled the valve cover and found where those plastic pieces should live. Awesome. I'm torn about fixing this because the engine runs great and I don't want to put much (if any) money into fixing it since I have 3RZ dreams. Other than that... nothing leaks from the engine; there's a bolt on the t-case that leaks, but just a little. And the rear diff leaks from somewhere slowly... very slowly. Not a big deal, the fluid levels are good for now.
And I'll get pics soon; charging the camera battery.
>>Dan
Jakesteads
lockers cause u to steer like :pokinit: in the snow its even worse.....
dont fix the engine run it till it dies....
run ur air on road at 25 or less
on the trail if u lock 1 hub u can steer pretty good..... if u come to something hard lock the other hub.... those detroits might as well be spools
i got mine running but damn i got some leaks in that front diff
that is all
I like Toyota
Volcom
Quote from: wakkjobb on January 31, 2010, 07:35:40 PM
The joy of being locked in the front with no way to turn it off :)  Just wait until you are in Moab on the slickroad headed downhill with all the weight of your truck on the front axle you try to turn :D
Hydro assist will cure that.
84 4Runner
Marlin Dual Ultimate crawler
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
Jakesteads
u know my aussie front was never that bad and it seemed to be locked all the time... but then again it was in a HEEP
I like Toyota
wakkjobb
QuoteThe joy of being locked in the front with no way to turn it off... :)
I'd love some ARBs but y'know... they cost money and junk. Plus the truck came with Detroits (so I was told) but we shall see what's really inside in a few weeks when I get around to switching axles. The spare I got from Josh is set up for hydro, just need everything else. That's on the "to buy" list along with the 5.29/Detroit rear, it'll get done someday... eventually... maybe...  ::)
If my truck wasn't so tall with 4 point harnesses I'd hop out to lock/unlock the hubs, but even being 6'2" it's a good hop into the cab. And landing on the harness latches sucks a bit. I aired the tires down to 20 to see how that affects the death wobble... hope it goes away.
Today I cleaned the oil pan and valve cover, going to stick them back on tonight. Thought about painting them Chevy Orange "just because"... but I'm not because the engine is only getting maintenance money spent on it. It's running fine so I'm not touching it. Plus it got about 15 mpg last trip even being aired down to 10 psi most of the time.
And here's two videos of my flexing and fender testing:
http://www.youtube.com/watch?v=QYfPBrexDPU
...in 2 low...  :smack:
http://www.youtube.com/watch?v=jryaAbSH3gg
>>Dan
Volcom
Quote from: wakkjobb on February 02, 2010, 05:29:18 PM
Watching that video makes it look like you do have 4.7 to 1 gears in your t-case.
84 4Runner
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
Jakesteads
it flexs good..!!!
where was that ? i need to flex mine out to measure for bumps...
when we going wheeling :D
and ya at first i didnt think he did but he has 411 gears... so it makes sense
I like Toyota
wakkjobb
Good to know; I haven't done the whole "unhook rear shaft, spin engine and count output flange" like boggerrunner said to do. It'll be slower once I get the 5.29s in  :D and I still want a dual case set-up...
This is up Rampart Range (starting at Balanced Rock side) before the shooting range; it's short but as you can see it has some good dips/drops to check flex. There's a little hill that can be climbed; I was worried about failing and not having someone to help out if I got stuck/rolled etc. I munched the fenders some; guess what's getting chopped off next?  :flamer:
I was thinking of wheeling this weekend if you're not going to watch the "BIG GAME"; I'll put off the axle swap until after I go next time.
>>Dan
Jakesteads
i could maybe go sat... i really need to get it over to emissions to get titles and tags and all that lets see if i get that done this weekend....
I like Toyota
axled89
that;s a pretty cool road to flex on.    :biggthumpup:
i love oregon wheelin.
wakkjobb
Thanks, it's only about 300 feet long but it does twist things up pretty good. I was scared when the tires nailed the fenders the first few times; sounded really bad.
Got the oil pan and valve cover on tonight; no leaks so far. I want to wash off the old grunge to keep an eye out for new leaks; if they pop up at all.
>>Dan
Suz
Oh really? Instead he makes the 5'6" girl do it, where I almost need a running start to hop back in. hehe
Matt - Let's go on Saturday! You live in an emissions county? yuck, for testing. yay, for the air. I read almost that entire emissions thread, have you checked it out yet? Probably don't have anything to worry about though. I mean, "It was nice"... ;-p
Jakesteads
we could maybe do sat... i think im gonna come down friday and try to get the cage in... shouldnt be too hard.
ya my truck just past emissions with PO in sept... so i think im good i found tires to use so tomorrow is D day
I like Toyota
wakkjobb
School is today and tomorrow is community service from 9-1 so in the afternoon is best for caging goodness. I still have to stitch the exhaust back together and that's it; I'm ready to wheel again. Hopefully with less death wobble this time... tires at 20 now.
>>Dan
COToy91
they are going to wear really quickly at that pressure
Jakesteads
dan i got the cage in.... we just need to weld it some..... is it still cool to come tomorrow and wheel sat?
I like Toyota
wakkjobb
He's at school right now. I will answer for him, yes! Let's go early if we can. I made some granola bars just now, we're going to pack smarter this time~
Jakesteads
correction suz... im not coming tomorrow i just used my my drilling skills to get the cage in so i dont need to weld it.... lets plan early sat...
I like Toyota
wakkjobb
QuoteThey are going to wear really quickly at that pressure
I'm not really worried about it since I'm not driving it a ton; no plates/insurance etc yet... so if I run 30 psi what can I do to get rid of the wobble?
QuoteCorrection Suz... I'm not coming tomorrow, I just used my my drilling skills to get the cage in so I don't need to weld it.... let's plan early Saturday.
Okay, that gives me more time to tune the truck. It's amazing what a difference hooking up the vacuum advance will do... the metal vacuum lines were all broken so I replaced the damaged section with regular vacuum hose. Where do you want to go Saturday and when? The Mt. Herman trail we took is just a trail that ends up at Rampart Range; not a lot of actual wheeling to do... mostly driving and avoiding idiots.
There's always Eagle Rock...  :eyebrow:
>>Dan
COToy91
Quote from: wakkjobb on February 04, 2010, 05:32:36 PM
>>Dan
i max them
wakkjobb
I'll take it out tomorrow and see what pressure works best; we know 30 doesn't work. I'm still wondering about the rear shocks; they just don't look quite right to me. I see cutting and welding in my future...  :love: They're inboard but at the top they're on opposite sides of the shock mount bar... as in the left shock is on the front side of the axle and bar and the right side is on the rear. It seems off... I don't know.
Tonight I got the exhaust stitched back together and hatched a plan to mount the lights in front. I still need to get a coupler for the stainless header to the mild steel exhaust pipe, I want to be able to take the header off without having to cut stuff. I also found out I have Pro Comp springs; another guy on PBB posted pics and they have the same part numbers as mine do. Funny, the kid told me they were Marlin springs...  :bull crap: I wonder what else I'll find out later on down the trail.
>>Dan
wakkjobb
Chopped off the rock "sliders", going to stick them on the bed to make anchor points/tie down bars. Got one light mounted up front; the other met up with a wrench and lost...  :_oops: , stuck the rear panel back on the bed, oil pan is still not leaking and I have to get some exhaust repair/wrap stuff as a temporary patch between the header and exhaust pipe. I should be getting the flanges next week-ish... then no more broken/leaky exhaust!!
And getting hyped up to wheel tomorrow; should be decent weather.
>>Dan
Jakesteads
I like Toyota
wakkjobb
I'm packed... just got to get fuel and a shovel and I'm ready.  :wave:
wakkjobb
Finally got photobucket to cooperate; here's a big-ass picture update, enjoy:
Frame rust and previous "patch":
De-rusted:
It went all the way through... awesome:
Super Patch, 1/8" plate:
Swiss cheese for a floor:
Cut out:
wakkjobb
More:
Floor repaired and undercoated:
Cab corner:
This wire was connected to an ignition-hot AND grounded, no wonder it burned up:
Floor done and carpet in:
Back together with 4Runner seats:
