Re: Rotten Lime, The verdict is failure.
Started by zippo, November 23, 2008, 06:52:13 PM
timmaytoyota
nice attention to detail  :bowdown: that first scratch is gonna  :rivers: have your diamonds showed up yet :willynilly:
zippo
No! They are crazy slow with the shipping so it seems.  I should have atleat the rear this week sometime
If you see it, its for sale.
slower
sweet job man that thing is going to be sick!
never once have i ever wanted to see the reduce speed ahead sign so bad
zippo
#93
No diamonds yet. One day... I Hope! Going really slowly last little while. Mounted my vise finally! The stand is a little over built for that vise, but if it ever brakes i'lle get a Wilton. 4" Schedule 40 steel pipe with 1" steel flanges, bolted to the floor with 4 3/4" concrete bolts. Beef it's whats for dinner.
Started building my thirds, but the bearing separator slipped and popped the inner pinion bearing. Will have to wait till this week to get another one. It is crazy tight on the pinion. Even on my 12ton press Zuk  any words of advise? Cause I have 2 to set up I am just going to grab an extra inner pinion and just open the inner dia up so it's a slip fit not a press fit. Will save me TONS of time and the risk of messing the bearing again.
zippo
#94
I got my Diamond Axles. These things look awesome! weighing bout 90 lbs each. I can't even say how nicely they are! I started cleaning and fiddling with them all I can is WOW. Cleaning, paint, Assemble YAY!
Front Axle
Rear Axle
This flange is an inch thick!!! WOW!
SEXY!
Lots o' welding
This thing is massive and just looks awesome under my truck!
So I started looking at things and found this. The 25mm bearing contacts the axle with the smaller race. A little work with a metal removing tool and it will all be ok. Just something to keep in mind!
zippo
#95
Slow progress. Money Money Money. I found a new cab i'm going to use from an 85. Will save me some time in finishing the one I have.
I got my front diff set up with the help of Zuk and others. What a pain. Gonna go with a Nitro next time.
http://board.marlincrawler.com/index.php?topic=72610.0
Cleaned and painted my rear axle. Still need to weld on the shock mounts, perhaps I got a little ahead of myself. I need to get the shocks/PSC ram mounted before I start on the front. Good Times.
Spent a few hours cleaning. I love working in a clean garage!
zippo
#96
So I finished the list of all the crap left to buy. This does not include the new cab and bed. But other then that this is it! Only crap i'm a spendy f'er:
PSC Toyota Steering box   $530.00   PSC
Nitro 5.29Gear Set   $208.00   JT
Setup Kit    $153.00   JT
Solid Spacer   $19.00   Marlin Crawler
Flange x2 $35   $70.00   Marlin Crawler
Hube Cone Washer x13 3.29   $42.77   Marlin Crawler
Bump Stops x2 39.00   $78.00   Marlin Crawler
Backing Plate Eliminator   $20.00   Marlin Crawler
Spindle Nut Kit x2 8.50   $17.00   Marlin Crawler
Spindle Axle Bushing x2 34.21   $68.42   Marlin Crawler
Hub Dial O-Ring x2 3.17   $6.34   Marlin Crawler
Wheel Brearings x2 45.00   $90.00   Marlin Crawler
Drive Flange Hub x2 45.00   $90.00   Marlin Crawler
Gaskets   $50.00   Local
Longfield Front Axles   $700.00   LongField
80' Supra Calibrators x2 68.19   $136.38   SouthSideBrake/Local
Header 3rz   $368.95   LC Engineering
Exhaust System/Cat/Muffler   $200.00   Summit
991945ERL x3   $23.85   12mm 1.25 to -6 AN
818006ERL   $21.95   -6 AN 180*
804606ERL   $16.95   -6 AN 45*
SUM-230615   $57.95   15' -6 hose
Proportinging Valve Kit   $79.00
Brake Lines   $100.00
Oil Pan Conv   $250.00   Sky Manufactoring
PSC Tacoma 2.7 Pump Kit   $395.00   PSC
Hoses    $50.00   Local
Clutch Slave Cylinder   $29.00   Marlin Crawler
38" Toyo MT Tires x4 @ $400   $1,600.00
Drive Shafts Reworked X2 299.00   $300.00
John Doe
If you have a hook up on the supra calipers, pass it along. I have been doing a little bit of searching and havnt found squat. I want to get a set to run full float with a rear ebrake.
A side note about your hydro asst; Make sure you have a good cooler to go with it. That pump gets hot!
I love the thoroughness of your build.
zippo
Call Front Range Off Road. I know they have a stock of them. I happen to find some local, but if that falls through I will get them from them.
John Doe
Last I spoke with them they had run out. I guess they found some more.
twistedtoy92
Man I cant wait to see this thing done!!  :drool:
zippo
So I think I fixed the loading problem. I resized all the photo's down a few sizes. I tried to leave them large enough to get good details too. Enjoy! let me know if you have any problems!
Holy Crap Zippo! That is some insane and detailed work.
I am inspired!
zippo
#103
So I got the Rear 80% done. All it needs is the Diff, caliber, and axles shaft. I have the shafts in the mail. The rest is still at the store.
12" shocks in the Rear mounted inboard with Sky manufacturing
Full float rear, rear disk break conversion.
Got the front somewhat done. Welded the shock tabs on. 14" Shocks in the front. I still need to get the PSC assist ram
Tick Tock. One of these days....
zippo
#104
So I started the process of making break lines and fuel lines. I got them all bent in copper gotta take em to and have them bent in stainless and flared.
Also got it on all 4 wheels. This is the first time in over a year and a half!. Check that flex, 18 inches. with no problem. Also found a problem with the front leaf spring bolt hitting the axle. Took the axle pack apart and cut a little of the bolt.
Toymin8r
zippo
#106
Started the body work. I wish this part was faster. Why can't I just sit back and slip it some singles and have it strip itself? Thats what normally happens.
Using aircraft stripper and time is a pain in the ass. I was going to have it blasted, but saved myself tones of money.
redrocket93
This build is coming along nicely. Diamonds are sick. Good work.
polish the body!!!! DO IT :D make it like a mirror!
zippo
#109
The body work is going slowly. This is my first time doing all this by myself. I have most of it done and primed. Needs more blocking and work but it's getting there slowly.
Here is a pic of the HVLP gun i am going to use to paint it.
Here is the color. So far i am the only one that likes it. Anyone painters in the Seattle/Tacoma area wanna come and paint it for me? muhahaha
THATS SICK! Reminds me of the "S10 Truggy" Xtreme 4x4 did on SpikeTV
zippo
It a little bright green in the pic. It's a Volkswagen Raveena.
Yeah i like Xtreme 4x4 thought they bastardized the Toyota they had.
Quote from: zippo on September 13, 2010, 10:00:27 PM
Oh man I like the green though
They started back up on it!!!
1tons, links, full hydro and 49s i think.
2 episodes so far this year.
part 6 thios saturday i believe.
zippo
That is what im talking about. They put a 9" under it, GM crate motor and a 700R4. the only thing left Toyota is the cab :-/
Whats the point of having a Toyota and not have any Toyota on it.
chim
I like the paint color! Should look good with all the nice shiny black  :thumbs: :yesnod:
PBrown
91 reg cab sas, duals 4.7, 5.29s, detroits, 35s, bunch of marlin debt.
COToy91
This is a thing of beauty! Sweet paint color
86bobbedtoy
COToy91
zippo
Quote from: 86bobbedtoy on September 14, 2010, 08:10:45 PM
single stage?
Yes it's a single stage. Bought it local.
Quote from: COToy91 on September 14, 2010, 08:26:09 PM
What welder do you have?
Miller 180. I love it. It does everything I ask it todo.
