Re: Rotten Lime, The verdict is failure.
Started by zippo, November 23, 2008, 06:52:13 PM
zippo
So I might have a line on a LC low boost "8-10 PSI" turbo kit and SDS engine control kit for the 3rz. This would allow me to bump to 250ish HP. Would this be good crazy or bad crazy or just f-en awesome.
If you see it, its for sale.
K.Lund
I'll throw in my 2 cents.  I have raced naturally aspirated, turbo, and supercharged 4 cylinder cars and personally I would only run naturally aspirated or supercharged engines for off-road applications.  Turbos have a peaky power band with little low end torque(unless they are very small and spool quickly) where as a supercharged or naturally aspirated engine has a linear increase in power and torque basically from idle on up.
1983 underconstruction
pumkin toy
Quote from: zippo on December 08, 2010, 06:28:59 PM
So I ordered my PSC hydro assist stuff, should be here in awhile. Will also be ordering my longs when I get paid. He is local to me so that will be no biggy. Getting close!
how much was the psc stuff?  and what parts did you order from them?  I'm trying to decide if i should go with them when i buy my hydro assist
97 4runner Limited
zippo
#153
The Trd 3rz supercharger for the 98 has some problems. A supercharger would be my first choice as well.
On the other hand a turbo charger has more boost potential.
i just ordered the ram so far, 200ish for the ram kit. If i were to get, the ram 200ish tapped box 300, highflow PS pump 300ish. PSC is the best in the induastry. i would never think twice about odering from them.
pumkin toy
so it was 200 just for the 1.5" x 6" ram?  or did that include mounting tabs and stuff too?
97 4runner Limited
zippo
pumkin toy
Quote from: zippo on December 12, 2010, 12:32:43 PM
yeah. ram, tabs, rod ends, and field hoses
thats a good price for all of that then!  I will most likely be ordering the same from them
97 4runner Limited
K.Lund
Quote from: zippo on December 12, 2010, 10:44:35 AM
True, you have more boost potential.  You also have more heat induction and more detonation potential.  Running lots of boost requires a lower compression ratio(less torque when off boost) or an intercooler to lower charge air temps in order to deter detonation and lower engine temperature, which also requires cooling air circulation (OK for the street but, not something you usually get on the trail).
zippo
yeah. the 3rz runs 9.5:1 with that 8 lbs would prolly be max. 91 plus octane a must. My plan is to run till it dies then on the rebuild run forged 8.5:1 pistons.
this is also a DD so the extra pep would be nice. And we all like mudding from time to time where HP is king.
the kit has a in cab boost adjuster also so on the trail i could tune it down.
But i agree with you. but a super charger is more $$ and has its own list of problems.
K.Lund
Just one more thing, on the price difference.  Don't let the initial cheaper turbo cost fool you.  Most of the supercharger kits come with a fuel management solution which has had many hours of testing in all climates and altitudes.  You will have to pay for this in dyno time to tune your system(you may want to check around for a quality dyno shop/tuner and check their rates).  Again this is just my opinion and you can take it with a grain of salt, just make sure you do lots of research.
I am really enjoying your build :thumbs: keep it up!
zippo
So I left work, at night in the rain, in my '06 Acura RSX-Type-S and I was like hmm seems to be pulling a little to the left and made a note to check my tires when I got home. I only live 20ish min from work.
Well while driving down the SR16 at 60 MPH it started pulling real bad and a bad vibration started. I traveled a few more miles until my exit and found a safe spot to stop. Holy crap, I knew the tires were needed replacing soon but never expected to see this when I changed the tire out with the spare!
Looks like I was right about it being low on air, and seems to have been favoring the inner edge. This is from the Koni shocks and eibach springs under the car and my failure to install a rear camber kit. However the drive side shows no odd wear? Weird.
Once aired down, something gashed it open like a pumpkin on Halloween.
Good two inches went all the way through. Holly crap! Good thing they were low profile.
So I found the little b*std and pulled it out. Screw this now I have to buy new tires!
zippo
Quote from: K.Lund on December 12, 2010, 06:36:29 PM
So I called around and found my line and price on the parts wasn't that great. But it got me thinking and I thought of something possibly even cooler and a quarter of the costs. Not sure if im going todo it or not, but if i do, it would be awesome!.
pumkin toy
Those tires look pretty rough!  thats a common sight for me though, I have owned lots of lowered hondas that dont have the proper parts installed to correctly adjust the camber.  Got anyhing else done to your RSX?  I love those cars and have always wanted one
97 4runner Limited
zippo
Just the Koni's and K&N intake. I love the car, it's fun!. The front it good to go with adjustment. The rear I didn't have the money at the time(the Koni's and spring was about 1k) and it kept getting bumped in the list of things todo cause it doesn't really effect the handling.
Peterbuilt84
Same type of tire wear happened to me in my wrx. The previous owner installed coil overs and just slammed it into the ground. Was on my way home from a parts when when I got a flat 45 mins. from home, really sucked.
zippo
It's only 1" lower the stock. Yeah some people do crazy things with them that make is super hard to drive on the street.
pumkin toy
sexy lookin car!  makes me really miss the silver s2000 i had
97 4runner Limited
TacoRunner
the S2000 is such an awesome car, I've only had the chance to drive one of those. Wish I had one.
www.4WHEELUNDERGROUND.com
[email protected]
zippo
Ordered my Longs, 20.625 short side 31.875 longside.
zippo
#169
I picked up my custom inners from Bobby Long today. I was crazy when i walked in his ship he had over 50 Longfield burfs just sitting on the table. CRAZY! Super nice guy!
mr.bungle
very nice build. can't go wrong with longfield, always a pleasure to deal with so far.
now lets see some progress  :biggthumpup:
minicrawlin
Just read your build. GREAT work man, huge props! Thing will be B E A utiful for sure!
If i had the cash i'd give it to you just to see this thing finished!! ha ha
the rocks Rock in South D SON!
zippo
So the brown trucks have made some stops by my house.
FROR ARP Hub studs. These are really nice.
Got some extra axle seals for my Diamond Axles.
FROR Wheel Studs. These are also nice though it takes it to a 1/2 Wheel Stud
My PSC Ram Super Nice. Now just need to figure out where and how i want to mount it to my axle.
minicrawlin
looks like you can change your title cuz now you know where they are! ha ha
Sweet parts man, looks like you got some good times ahead of you! I'm really looking forward to seeing this thing moving!
zippo
Me too! It's taking forever. It just seems everything else comes before this project. Not much more now!
pumkin toy
hey thats the same ram kit i am gonna get!  looks sick!
97 4runner Limited
zippo
#176
So I mounted my ram. Welding gummed up the threads need to run a tap through them.
zippo
#177
So here are some pics of my new sneakers. Sexy!
So I also spent some time redoing my garage entrance and built me a new work bench. It's much better then it was. 12 feet of open work space!
FRANKENYOTA91
So far this truck looks awesome. but the last few pages the pictures arent showing up. All it shows is the img code.
85 toy double extended cab pos wheeler bobby longs, welded front and rear, dual cases
89 4runner sas,  duals, the usual
81 toyota long box project
83 short box project
2001 Cummins 6 speed tow rig
Dingman.
im pretty sure the its because the img code has the width and height part in the beginning.. otherwise it would show up.
