The Tuki Suzuki - Toyota drivetrain, Samurai body
Started by 4RnrRick, October 14, 2007, 09:24:42 PM
crawlerdan
good stuff. i need to do something. im going to tear down my front end someday soon, and do bigger brakes, a rebuild, and i gotta do something about the arms and studs
4RnrRick
Got a bunch more little plates cut out and tacked onto the arms....
yeah - its probably overkill !
Then I fully welded them and threw them into the sand again to slowly cool them.
Then I started mocking up the 1.5" bore x 6" stroke PSC ram for hydro assist.
It also looks like I can re-attach the old armor slightly lower on the axle to help protect the tie rod and the hydro assist cylinder.
Ramrod
looks good, I was sort of thining of using some of those arms on my truck when I link it but was just going to run them stock.  Yours are sick but probably overkill for sure
Yota4life
The arms look crazy at a glance, kinda cool but at leased they wont break with all the extra steel on them....
Duffil
Quote from: Yota4life on January 23, 2008, 10:13:43 PM
nope, the knuckles will explode. :gap:
skipnrocks
Quote from: Duffil on January 23, 2008, 10:23:48 PM
LOL much better!!!   better to overbuild than be sorry!!!
WILLYNILLY
Gittinit
Your definately keepin the tie rod ends as your weak link, and with your limited space, thats a big plus. To top it off tie rod ends are fairly easy to replace on the trail.   :beerchug:
my favorite places:
http://www.flatnasty.net/
http://www.orvpark.com/
DTB
Quote from: skipnrocks on January 24, 2008, 04:38:34 AM
mines better :nana: the 21 stud mod.....patent pending
skipnrocks
Thats much better!!  If it wernt for the 800dollars of bolts and nuts on that it may be worth it!
WILLYNILLY
4RnrRick
DeadlyPeace
#341
Quote from: 4RnrRick on January 24, 2008, 07:24:30 AM
Quote from: TEAM RAMROD on January 23, 2008, 10:08:58 PM
Thanks - Thats the idea!!!
Definitely should hold, and a lot easier to remove then........
Quote from: DirToyBoy on January 24, 2008, 07:05:29 AM
I REJECT YOUR REALITY AND SUBSTITUTE MY OWN
Never let people think you're a horrible person and always keep the heart of a young child...
       ...I prefer mine in a jar on my desk.
3 CAT scans a MRI and some time with the shrink and it's comfirmed. I'm just not right in the head.
Global Moderator for www.ToyotaOffRoad.com
twistedtoy92
Jordan7118
I believe that's photochopped "for sure"  :wink2:
Rick, where is your drag link going to mount?  :headscratch:
EDIT: Now I remember - something about the FJ60 TREs that mount close the the end of the tie rod.
Shoyrtt
That belongs in the fontucky fab thread. :ha_ha:
http://www.sharetrails.org/
Talon84x4
Low & Slow 84 PU - http://board.marlincrawler.com/index.php?topic=31982.0
Central Valley Crawlers
4RnrRick
Last night I work on my hydro assist mount some with more cardboard, but I don't have any real progress to show.
I also decided not to use my exist 5 stud knuckles (bolt through grease plug location) which means I would have to add even more steel to the arms and just go with some ARP knuckles studs from FROR - so I got those ordered today...
I also found out that my existing 6" stroke hydro assist ram is to short for these OEM arms. I need about 7" of stroke - So I'm going to buy a new ram.....
Redbeard1
You could go with the D44 knuckle studs in place of the Toyota studs... little extra work to redo the taper but the studs wont break.. ARP makes them too I have beat on a set for years on  my Chevy  the only ones I ever broke were the stock ones.  :twocents:
If you dont stand behind our Troops... you can stand infront of them...
Project Pete==> http://board.marlincrawler.com/index.php?topic=43370.0
85 Toy: Built 22re, locked F, spooled R, 5.29's, R151F, MCO7 duals, Sky x-member 37 MT/R's on jack stands
__________________________________________
||____________||____________||___TOYOTA ___||
||____________||____________||_____________||
RIP Bobby Long
4RnrRick
I don't think D44 studs and cone washers with stock arms would be a good idea - the OEM arms just don't have the extra meat around the knuckle stud holes like a aftermarket billet arm has.
Redbeard1
Quote from: 4RnrRick on January 25, 2008, 03:02:29 PM
Good point... I'll shut up now!
RIP Bobby Long
4RnrRick
Got the hydro assist cylinder mount done.
Then I cleaned up the garage and starting mocking up the front end...
Doing this I decided to push the front axle forward another 1 1/2" for around 13.5" forward of stock.
Since the air compressor, motor mount, oil filter, exhaust down pipe and two piece front driveline brearing support all need to be on the passenger side, that just leaves no room for a upper link above the diff, so I'm going to have to do the unconvential thing and put the upper link on the driver side (non-diff side) - I got lots of room over there..
Oh and everything shown in the pictures is about at full compression with 1 3/4" between the bottom of the frame rail and the top of the axle tubes. That figures out to around a belly hieght of 16.5" with the 40" tires and full compression.
skipnrocks
Lookin good as usual!  The only thing I wonder about is the ability of the stock difcover to handle the torque from the hydro?  I know you like to overdoe things! Do you have any other plans to reinforce that area?
WILLYNILLY
crawlerdan
that looks over built to me, its not directly welded to the diff, itd welded to a plate and then to the diff, or so it looks.
so it appears as tough in that area rick has effectively doubled that wall thickness
Redbeard1
RIP Bobby Long
skipnrocks
Doubling the area where the bracket is only redirects all the stress to the first point that isnt double up, IDK iI think I would maybe suggest one more flat piece completing the bracket across the diff plate to the other side to send all the stress around the cover and into the meat of the diff. IDK since its just assist,  probably just parenoya from when I was an engenering student, we always had to moniter stresses and where it was being transfered too.
WILLYNILLY
4RnrRick
The diff will be fine....With how I did it, I'm redistributing the load to a larger surface area (weld wise) by plating the cover of the diff and then welding the tabs to that... plus its also tied into the mohawk in from of the ring gear.
crawlerdan
DeadlyPeace
Looking real good, great progress. Can't wait to see it rolling.
4RnrRick
Well the snow is falling again here, so I had to go play in it some. The wife is going to kick my a$$ for using one of her good bra's - but it was worth it!
skipnrocks
WILLYNILLY
