CTENG_TowRig: The Beastmaster has gone to a new owner.
Started by CTENG in KS, June 12, 2007, 11:35:02 AM
CTENG in KS
yeah, never got above freezing all weekend.  I don't mind metal work in the cold...but turning bolts gets tough.  Can't feel your fingers...hard to get them to thread.
Jud
That thing is PIMP! I love the "cowboy Cadillac" sticker on the gooseneck hitch!
"bout tree fiddy"
CTENG in KS
brainlessfool
Hummmmmmmm , I think your A/C is to big for that tiny motor.
Duffil
CTENG in KS
Tell the freezing rain to stop then...I ain't going out in that.  I bought the rest of the nickel and dime stuff I need...ready to go run the vacuum lines and start her up...but nooooo.......
CTENG in KS
It's alive!  ALIVE!
Got everything all cleaned up, vacuum lines on, new blue breather filter, etc.  Got all excited...and she coughed out a big plume of "oops AJ got some coolant in the cylinders" and settled into a high, but even idle.
Kinda forgot how loud it is!  :thumbs:
Didn't spend any time tuning cause it was dark by the time I lit the fire, maybe this weekend between snow storms.
Cheesemaker
 :thumbs:
I see you found an air cleaner small enough!
Duffil
i thought that thing didn't allow for tuning? what needs to be adjusted on it?
CTENG in KS
Idle, fuel mixture, timing...also the accelerator pump has settings.
unclejpl4x4
CTENG in KS
Duffil
out of curiosity (nevermind the cat) what is above the engine bay?  What I'm getting at is maybe you could cut out that section of sheetmetal, build a little recessed area so you could fit a larger air cleaner and be able to run the spacer?
CTENG in KS
It would open the interior to the engine bay leaving me with a Santa Anna wind constantly coming through the dash.
notajeep
Yeah that's one of the bad things about the Ford's that long nose puts the air-cleaner right under the dashboard unlike Chevy and Dodge which is more inside the doghouse which gives you a little more room to work with. Not much but a little.
CTENG in KS
It is in the 40's today so I am gonna go out in a bout an hour and see if I can rig up the throttle cable and maybe crank her up again.
CTENG in KS
Well, it isn't as pretty as the Predator, but at least it won't leak fuel.
Should be nice tomorrow,hopefully I will get her running.
unclejpl4x4
CTENG in KS
This thing kinda pisses me off though...it has TONS of adjustments!  AAAARG.
unclejpl4x4
brainlessfool
Quote from: CTENG in KS on January 04, 2008, 03:58:41 PM
just makes it more fun!   :yesnod:  carb's are like wemens, lots o ways to twik um.
some better than others, some don't work for :pokinit: just have to find what makes her happy!  :willynilly:
Redbeard1
If you dont stand behind our Troops... you can stand infront of them...
Project Pete==> http://board.marlincrawler.com/index.php?topic=43370.0
85 Toy: Built 22re, locked F, spooled R, 5.29's, R151F, MCO7 duals, Sky x-member 37 MT/R's on jack stands
__________________________________________
||____________||____________||___TOYOTA ___||
||____________||____________||_____________||
RIP Bobby Long
CTENG in KS
Still having issues as evidenced in my other thread about the 460.  I am blowing ignition modules.  Don't know why.  Perhaps a wiring problem which is a scary thought given the state of the wiring in that truck.
With all the work you've done to it recently check to see if you've pinched a wire somewhere and grounded it out. Plus since it is as old as it is there may have been a bare wire that wasn't touching that with all that work done now is.
CTENG in KS
That is what I am thinking.  I ordered up a manual with wiring diagrams.  I am going to start culling out the crap that PO's have installed and cut open the wire looms.  Time to inspect and replace what is in bad shape.
Redbeard1
if it is the module that bolts to the distributor be sure you give it a liberal coat of dielectirc grease i have seen fords eat thos things like candy because of that...
RIP Bobby Long
CTENG in KS
Duffil
Quote from: CTENG in KS on January 21, 2008, 04:54:24 PM
No, it is a separate fender mounted box.
yeah, we used to sell the :pokinit: outta those things over here, but the trucks aren't as popular as they once were.  I have several customers who still keep a spare behind the seat though.
