CTENG_TowRig: The Beastmaster has gone to a new owner.
Started by CTENG in KS, June 12, 2007, 11:35:02 AM
CTENG in KS
yes...but I can't get the hoist in that way either...engine too far forward to get the hoist up to the carb mount.
unclejpl4x4
van moters are put in befor the body is drop on.  only wayout is 2 sawzall the front
Tool Pimp
Quote from: unclejpl4x4 on November 11, 2007, 06:58:12 PM
:nonono: you gotta drop them thru the bottom, usually requires pulling the front end off.
CTENG in KS
None of that will be happening to the Beastmaster in the apt parking lot!
CTENG in KS
It's so shiny...maybe I should polish it!
unclejpl4x4
i love the books/moives   did you hand pic them for the :snapshot:  :rofl:  j/k
CTENG in KS
No, do you want a pic with different books?
I have lots of books.  I have science ones, work ones, fiction ones...would the welders handbook be more appropriate?
unclejpl4x4
use a small mirror  and make sure ALL  the bolts  are out of the intake,  then  you can  pry it up  from the rear i think
i'll try and look at my van tomorrow  and see where  a good spot to pry it up would be
CTENG in KS
Here is a little look at how I am fixifying my ghetto Predator carb...
First a look into the fuel bowl with the fuel delivery "mechanism."
The float is beat and I am missing the fittings for fuel lines.  Gonna make my own so I can adjust the fuel flow a bit.
CTENG in KS
Here you can see the overflow tube...this also acts as a pitot tube pressurizing the fuel bowl.  I wanted to keep the pressure lower so I closed off a couple of the holes on the inside of the tube.  Don't know that it will have any effect, but worth a try.
Under $5 fix for the float...yep...JB WELD!
Then tapped the holes for my new "Fittings".
CTENG in KS
Now for what we have all been waiting!  Tomorrows project:  Get the distributor to move!
Out with the old crap...
In with the new crap!
KDXSR5
DTB
lol, is that really "new" stuff? or u just painted it to make it look new?  :talkingn:
CTENG in KS
The valve covers are the old ones with white ceramic heat paint.
The intake manifold is an Al Edelbrock unit I picked up off Ebay.
KDXSR5
I bet it is like one forth of the weight of the old cast iron one. Did you get a good deal on it?
CTENG in KS
$80
And it is prob less than 1/4 the weight.  The cast iron one is REALLY HEAVY.
FATTshack
KDXSR5
no, thats duct tape. If he would have used hi-temp duct tape it would be me-hi-can.
Duffil
unclejpl4x4
Doof
CTENG in KS
Lets start with the good news...
THE DISTRIBUTOR MOVES!!!!
Now for the bad:
Something weird happened to the white paint.  It is flaking off.  I wire wheeled the valve covers and wiped them down with lacquer thinner before paint so I know they were pretty clean.
Was it the weather?  Maybe instead of curing it was too cold and the paint froze??
DTB
whatever u do, aj, resist the temptation to eat the paint chips like u did as a kid  :talkingn:
CTENG in KS
unclejpl4x4
well AJ  maybe you should not get paint from the doller store
CTENG in KS
Its freakin $5 a can Duplicolor engine paint!
Carb is ready to go.
Got the fuel line fitting drilled out and plugged the bottom vacuum port.
Accelerator pump...not too complicated, eh?
Adjusted the float to work with my new fitting:
Open, float is down
Closed, float is up
Cover goes back on:
All done and ready to run!
unclejpl4x4
im just busting your balls
i do have 1 ?  why are U using a predator carb
