A New Whatever - MCR14 Break in.
Started by Wermz84, May 07, 2007, 10:32:25 PM
John Doe
Well at the rate you got your engine up and running it will be weeks before we see vids.  :hahaha:
Wermz84
Quote from: John Doe on September 28, 2008, 04:20:00 PM
:rofl2:   I swear it will be sooner!
I like to Drive!
John Doe
Wermz84
Thanks guys.    I think i just broke my photobucket.  :yupyup:
I like to Drive!
BLACKDOG
              -Ronald Reagan
John Doe
Quote from: Wermz84 on September 28, 2008, 04:26:45 PM
You've always got an excuse.
Duffil
Wermz84
I like to Drive!
Wermz84
#700
Proof Bitches!   :laugh:
hang on technical difficulties.  haha
<embed width="448" height="361" type="application/x-shockwave-flash" wmode="transparent" src="http://i206.photobucket.com/player.swf?file=http://vid206.photobucket.com/albums/bb53/Wermz/WermzCrawl/EngBld1/mov02904.flv">
http://s206.photobucket.com/albums/bb53/Wermz/WermzCrawl/EngBld1/?action=view&current=mov02904.flv
Since I obviosly don't know what i'm doing when it comes to direct movie linking.    :hammerhead:  here's both options to the same movie.
I like to Drive!
John Doe
Wermz84
I like to Drive!
John Doe
I'm impressed! Nice looking engine too.
So when are we going to get pics of your new helper?
Wermz84
So with this LC Cam I cannot get it to idle below 1100, even with the dristro turned all the way.     :headscratch:
I like to Drive!
*** YELLER ***
Bro thats so cool congratulations     now I better get my ass to work huh
except BACON
Duffil
Quote from: Wermz84 on September 28, 2008, 07:08:18 PM
sounds like you could be a tooth off on the dist timing. make sure your choke is opening up as well.
Wermz84
Quote from: **YELLER** on September 28, 2008, 07:15:24 PM
You Better!    :whip:     and thanks.
Quote from: Duffil on September 28, 2008, 07:20:17 PM
I Double triple checked that.  But I will again!  thanks.
I like to Drive!
Duffil
so did you take it around the block yet? how does it run?
fordh8r
Wermz84
Quote from: Duffil on September 28, 2008, 07:42:56 PM
Tomorrow :crossed:   I still need to fill the Diffs back up with Oil, plus my two front tires are almost flat; so I have to fill them.   :D
:woohoo:
I like to Drive!
Wermz84
Quote from: fordh8r on September 28, 2008, 07:54:01 PM
So when is the "Maiden Voyage"?   :biggthumpup:
Soon!!!    I'll let you know when I plan a hollister Trip.  :yesnod:
I like to Drive!
fordh8r
Duffil
OK so how about your vacuum lines? your truck is carbed, so there is a vacuum line going to the choke breaker. It receives vacuum after a PVS opens.(truck warm)
Wermz84
Quote from: Duffil on September 28, 2008, 08:03:31 PM
I followed the diagram on my hood, so i think i got it all correct.    Did your's idle correctly with this cam?   :headscratch:  but you also had the adj cam gear, i didn't go with that.
I like to Drive!
Duffil
yea dood mine idled fine. well...as fine as can be for a carb that equates to a 5gallon bucket with a hole in the bottom on top of my manifold.
something has to be off/incorrect/FUBAR/you fucked it up. :gap:
did you check for vacuum leaks?
Even with my cam gear, I set everything in the stock position, ran the engine and broke it in, and then after it was OK I pulled the cover and set the cam gear at 10*.
Wermz84
I'll double check tomorrow after work.   I do think i heard a small vacuum leak  (shsss)
And yes, I'm sure i Fubared', fucked something up.   suprised it didn't burst into one big fireball.  :hahaha:
I like to Drive!
Blingn
Wermz84
hey, your digging through my Photobucket!   :yupyup:
Here is another one.  yup, your's truly makes a dorky apperance at the end.   :shhh:
http://s206.photobucket.com/albums/bb53/Wermz/WermzCrawl/EngBld1/?action=view&current=mov02910.flv
Forgot to mention, its at 5deg fefore tdc
I like to Drive!
Wermz84
Fixed the small vacuum leak at where the wing nut (replaced wing nut) holds the top air filter cap on, backed the Idle up screw out.  It is now down to a ruff 900 rpm.
I like to Drive!
