Toyota Chinook Build!! Mach 2.
Started by 4xChinook4, March 04, 2015, 09:10:40 PM
helipilot77
you dont run the 22r in its best torque range because you want to get more mileage but you are going to swap aengine in thats almost twice as big ?   :headshake:
btw,  I get 17mpg from my heavily modified 22R driving like I stole it.  http://www.youtube.com/watch?v=9VX1AFhpOck
4xChinook4
I mean no disrespect Glenn, and I have been driving the 22 are between three and 4000 RPMs consistently. And I do appreciate the more power gain it gives me. However the gas mileage I do watch it drop.  And perhaps the difference with yours to mine is your running pure gas and I am running ethanol from Conoco and Shell. But in any sense here's some pictures.
Sent from my iPad using Tapatalk
Toyota + rv camper; you'll never need another car, you'll never need another home. = perfect
4xChinook4
The new paint color from lowes. The quarter panel came out decent but the hood looks kind of trashy.
You can see we're the lines went on heavy and think and then thin. This was with a $15 gun from harbor fright. And $10 quart of valspar at lowes
4xChinook4
And remember how I said that friend of mine would give me his 350? Well regardless of what I decide to do with it. here it is, it's mine. :)  I got the starter, alternator, flex plate/flywheel, new fuel pump, distributor, spark plugs and wires, and tomorrow or sometime this week I will be getting the Holly four barrel 600 carb. :greengrin:
4xChinook4
also got one of her strips sanded off.
4xChinook4
Oh and a friend last night and gave me one of his welders! It's just a mig flux core. BUT I COULD NOT BE MORE GREATFUL!
Quote from: 4xChinook4 on September 07, 2015, 09:40:08 AM
Looks like it would be good on gas...  ;)
I am not a fan of that paint color, but it's not my truck.........
time to toss in that 350 and be done with it..... generally, I like ford engines better, just because I am a ford guy, and I think you should stick to the same brand motor that your truck is... but at this point...... just toss in the 350 and be done.....
haha, this truck isn't that bad actually... and it was in a music video ;)
4xChinook4
Bye bye chinook.
Been sanding and prepping all week for try number two on the paint. Got rid of that valspar crap. And retraced my steps. To get ready for some real automotive paint.
4xChinook4
Check out all the different colors the chinooks been since 1977. Looks like it was red and gold originally.
4xChinook4
New primer to repair my mistake with the attempt of bringing it to bare metal for that valspar stuff.
4xChinook4
Also fixed the rust at the bottom of both passenger and driver doors.
4xChinook4
I'm also thinking away from the green and going with the original Toyota beige.. But in one of these 2 schemes.
4xChinook4
But keeping the brown stripe idea.
And black durabak under tone.
LittleSteve
Quote from: helipilot77 on June 22, 2015, 04:58:51 PM
It takes a big breaker bar and a new nut. You just have to force it off. I don't know of any way to un-stake it.
Quote from: mudmaster on June 23, 2015, 07:27:55 AM
With a hammer hit a small chisel between the nut and sleeve to bend it back and then remove the nut.
Theres a cold chisel you can buy, i will endeavour to find its correct name, that is an odd shape. When i find out i will let you know.
In reality though the nuts are not hardened much, get a piece of 1"x1/4 flat thats 2' long and drill two 3/8 holes in it to match the driveshaft hole centers in the pinion flange, then let rip at the nut with a breaker bar and a shallow 30mm socket. DO NOT OVERTIGHTEN THE NEW NUT, DOING SO CAN OVER CRUSH THE CRUSH SLEEVE. Which will affect the backlash between the pinion and ring gear causing premature wear, noise and possible gear failure. This is why pinion solid spacer kits are key to serviceability especially on an overland vehicle.
Refusing to fit in or comply.
Easy is not worth anything.
LittleSteve
Put it in a Prius....
Jason E.
- 1989 Toyota 4runner ( 22re, Dana 44, Sterling 10.25, 4.10, Family Rig in Progress) http://board.marlincrawler.com/index.php?topic=98687.msg1099361#msg1099361
- 1996 Toyota Land Cruiser (E-locker, Old Man Emu Lift, 33's, and Armor)
- 1996 Ford F250 7.3L powerstroke (Flat Bed, Manual, 2wd on 33,s)
- (SOLD) 1979 Toyota 1st Gen pickup 22re swap(http://board.marlincrawler.com/index.php?topic=94183.0)
Dippin' , Spittin' , Truck Gittin' , God lovin' son of a Motha Fucka.
When In Doubt, Throttle Out. Because in the End, Its a Yoda Thang     - Brandon Jako
R.I.P. Brandon Jako! Ill see you on the flip side!
Mytattootears
Man 2 years since post, I need to see up dates, I just bought a 76 chinook and I need more inspiration
4xChinook4
Hello, is this thing still on??
Sent from my SM-G920V using Tapatalk
4xChinook4
4xChinook4
So I tried to put all pics in relevant order.. but donor truck is a 93.. through the crank arm in cylinder. 3. Busted two holes out of either side of the block.... but fuel Injection and starting was still solid.. it's a 2wd. And the left overs are for sale.. fyi.. rather sell the whole truck to get rid of it. (Tires not included) .. but anyway, there's about 3 harness es in the 93' truck.. engine/dash/ and alternator-headlights (atleast that's what I'm calling it..
So you don't really need to alter much of anything on the engine harness nor the alternator headlight harness. I also updated mine to now have the newer better alternator with the internal regulator that came stock with the 93'. The most snipping of wires happens I the dash harness.. which, once it's all said and done .. only leave the
purple check engine light wire
. The Black/Orange "Engine Fuse" wire
Ignition switch wires minus the ACC.(I kept mine since I didn't want to mess with my Accessories on my truck.)
A few good grounds the White/Black wire
Alternator-Charge Warning light wire, yellow wire.
And swapping fuel lines.
To go.. new size pick up line in tank 5/16" .. in line fuel pump..
Finish exhaust with 2 o2 sensors now.
Fyi a 2wd 3rd short bed tank fits in a 4wd 1st gen short bed. Bolt it, I've been told. However I have a long bed 1st gen.. so if anyone want an EFI tank... I got one.
redneckcustoms13
Yes sir. The tank I have in my 83 that is efi swap is running a 3rd gen rg cab short bed tank. Bolts in... but did have to space the back side down about an inch or so
01 double cab hunting truck
06 tacoma street truck
4xChinook4
Quote from: redneckcustoms13 on March 27, 2017, 05:35:35 AM
Perfect.. there you have it folks.
Any body want the tank, or 22r intake with a Weber?
4xChinook4
She's licenced,  and legal now, 1st place I take her.... Arby's..   that was yesterday,.. today, extremely light wheeling, to 'break her in' ..
4xChinook4
Also,  I gutted to inside. We got some undesired rain and hail , here in CO. So it soaked all the interior , thankfully when I built the interior it DID have, I painted the subfloor in oil based paint, and I pull up the soggy carpet, and the subfloor wood and paint weren't even effected. So that felt real nice.👌
4xChinook4
So I got allot of pictures going on, but over the past week, I worked the combination switch, new one from a yard, but then re greased all springs and detent balls, and cleaned the old dirty grease out of there.. also started the install for those sexy sr5 gauges. New speedo cable,
And 2 great tips!!!
A block plate for the egr on a 22r motor, makes for a GREAT steering wheel puller.. it's the same dimension across, where you thread the bolts in to pull it.
And if your horn doesn't work but your hazards do, then it's probably the connection of where the horns spring connector slides on the back of the steeringwheel .(haha, definitely not the official terms sorry) but I just took a blade, and scraped to see shiny new metal.. put it all back together..and WORKING HORN!!
