Toyota Chinook Build!! Mach 2.
Started by 4xChinook4, March 04, 2015, 09:10:40 PM
swilson
Scott Wilson - TLCA #5261
1966 FJ40 [sold] - Click for Build thread
1988 3RZ 4Runner - Click for Build thread
1964 FJ40 TBD
4xChinook4
So my engine makes compression (~150 ) across the board. But takes about 8+ stokes to get there. Burns oil, and I have white smoke coming from the pipe . Sometimes heavy some times light , but always there. Cant really tell what kind of culprit / job I'm looking at here. I'd be greatful for any help you can offer.
White smoke tells me head gasket. Also my mpg seems less than desirable
Sent from my SM-G960U using Tapatalk
Toyota + rv camper; you'll never need another car, you'll never need another home. = perfect
swilson
Someone will correct me if I'm wrong, but I think steam would tell you head gasket and white smoke is burning oil
1964 FJ40 TBD
4xChinook4
Quote from: swilson on April 17, 2020, 02:19:20 PM
I thought blue smoke was oil. .
I do have good bit of water dripping from the pipe too. Well after start up
Thanks for responding so quickly
swilson
Check for oil in your coolant.  Then do an oil change and look for water in your oil... Either of those points to head gasket or cracked head
1964 FJ40 TBD
4xChinook4
Quote from: swilson on April 17, 2020, 02:24:55 PM
Good point. They both "clean" in that regard but the oil is very dark.
Lewis Hein
Doesn't synthetic oil burn white? Are the valves seating well? Are the valve guides and valve stem seals in good shape?
Just a couple thoughts
4xChinook4
Quote from: Lewis Hein on April 17, 2020, 06:50:22 PM
I never knew that!. I'm talking with someone else. And he thinks its valves / guides.
I cant make sense of the water from tail pipe though. It's not just from start up. It hangs around well after . For the whole driving time
4xChinook4
Well I'm an idiot. Or some form of it haha. ! Maybe I'm not doing it right. But I just checked compression on all 4.  And was at 168psi on #1
175 #2
183 #3
180 #4
I took all plugs out. (Grounded the coil too)
Took out efi fuse .
Floored the pedal to open the throttle body
And cranked.
I took a video of the amount of strokes it took to get to these numbers , it was quite a bit.
And I also squirted in some oil in cylinder one. To see if it would make a difference with how quickly it built compression . It didnt make any difference  .
4xChinook4
But this is my exhaust all day long.  Building a puddle, &  puffin smoke.
4xChinook4
This was maybe 15 or 20 min. Later .
4xChinook4
These are the plugs, they all look about the same. Just put em in this January
4xChinook4
In other news though. Started the closet tear out and remodel. Past design was a bit smaller and open air/ no door . So you could access from either outside the truck or inside. This design. Will have a door. Since everytime I hit a trail, everything I had hanging would instantly be on the floor [emoji23][emoji1687]. . But the plan is this door will open both ways so you still can access from both inside and out side the truck
4xChinook4
All cabinet doors and drawers have push button knobs that also lock the drawers when they are in the closed / flush position
4xChinook4
Dont believe I ever showed the bench side of the truck.  Here ya go
4xChinook4
And bed form.
Its  6 ft x 3 ft
4xChinook4
Finishing touches . Finally coming in.
My idea for the closet is finally taking shape! I'll post some pics of that here soon.
4xChinook4
Finishing up with the closet construction
4xChinook4
The door opens both ways to access the closet from either in the truck. Outside of it .
4xChinook4
Some new flooring . Waterproof vinyl.
The hard wood hickory was great.  Thstvubhad inthere. But it got beat to death.
4xChinook4
Also. Been building this as part of the project list for years now.  Having a center console for the 1st time ever , in this trucks life! Ha.
It runs lever with the flooring.  Did this in Hope's to tie the cab to cabin in a better manor.
Will have a touch radio as well.
Maine reason honestly. Was to have a back up cam in this thing.
4xChinook4
Ceiling interior lights finally have power.
And ther center console is all trimmed out.
Feel free to give an opinion. Was goin back and forth with either 3 options.
1. Clear coat the pine trim
2. Stain it with the same Sedona red stain that's on the countertop edging and back splash. (You can see a sample I have there sitting on this side of the console)
3. Painting it. The same color as the rest of the trim and cabinets. The beige creme color
Lewis Hein
 I love this build! It makes me want to rush out and buy a Yoterhome and then go live in it somewhere cool  :driving:
franckic
I have one here
Sent from my Infinix X624B using Tapatalk
4xChinook4
Quote from: franckic on May 14, 2020, 09:31:25 AM
I have one here
Post a picture up! I'd love to see it! Dont worry about "jacking the thread" . I ain't sensitive bought that . Lol
franckic
Text me if you are interested it it(872) 215-3747
4xChinook4
Final LED light strip went in today on the passenger side of the camper. Its the same build design and look as the ones over the counter top.
4xChinook4
Well I made a rookie mistake.
I just ordered some new NGK wires.  And bought the 81-92 version.
Forgetting my distributor is the 93' -95 style.  With the clips that hold the wires plugs in.
If I ordered the 81 - 92 style cap . For my new wires .
It should fit right? On my distributor.  They're the same size . Just the way the wires connect is the only difference correct ?
4xChinook4
Finished up with the new coil and Multi spark ignition.
My old coil was out of spec .. so decided to upgrade a bit too.
4xChinook4
Cup holders are in. With the addition of the dual usb charging port.
This way we can keep the phone charging cords out of the way of the stick shift.
