Toyota Chinook Build!! Mach 2.
Started by 4xChinook4, March 04, 2015, 09:10:40 PM
H8PVMNT
I kind of want the weber for experimenting on an engine I am building next year but I won't be in the market for a while.  What do you need for it?
– Steve McQueen
H8PVMNT
I don't think I've ever seen a working horn on a 1st gen :).
– Steve McQueen
DAWGTOY
when the little brass spring loaded thingy gets so worn out that it will not work
anymore you can use a 22 caliber shell casing and slip it over the remaining brass
and make the horn work again. done this several times and it works like a champ.
if its too long just cut it off till it'll work.
1983 TOY SHORT PICKUP .35/12.50S EXO CAGE HOMEMADE BED CAMO PAINT, REARS UP FRONT CHEVYS IN THE REAR, 4 WHEEL DISK, CABLE LOCKER REAR, LOCK RITE FRONT, 5.29GEARS FRONT & REAR.BOBBY LONG 30 SPLINES 9500 lb WARN WINCH. DUAL
T CASES WITH 4.7 IN THE REAR. THANKS MARLIN
4xChinook4
Quote from: DAWGTOY on May 25, 2017, 10:24:17 AM
that's gold !! If it ever dirties up again.. I'll be remembering this !
Sent from my SM-G920V using Tapatalk
Toyota + rv camper; you'll never need another car, you'll never need another home. = perfect
4xChinook4
Quote from: H8PVMNT on May 24, 2017, 03:26:03 PM
Not sure I understand, are asking what is needed for making a Weber run & perform?
All I needed was the vacuum lines to the distributor , gas line, and electric choke.
4xChinook4
Alright I'm a little stumped here.. So yesterday, for the wheeling trip.. I got HORRIBLE GAS MILEAGE . Up to the trail.. I'm it's only an hour from my place,  and I already almost lost half a tank??? Any idea's,  the truck is running very strong , and smooth and healthy sounding..
Not really sure, but maybe the ford e2000 fuel pump is too high a pressure, ? So when the injectors open, they are putting out more fuel than needed?
Or I didn't have an air filter so maybe,  the MAF is reading A LOT of air flow, so the computer is putting more gas in to the ports, to match the air?? I know that may sound way left feild , but this my 1st EFI.. and I know it's all sensors , and you don't really have an mixture screw,
And I should be getting better mileage , period , only upgrades are a LCE mild cam and header, and 2" 1/4" exhaust .. (which really both those should help right?
Any idea's ??
4xChinook4
Horrible gas mileage after EFI swap
Mudder
Any codes? I got bas gas mileage after mine because of a issue with the Knock Sensor.
emsvitil
Is the cold start injector leaking or always on?
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
skid
O2 sensor working?  Temp sensor?
Sent from my SM-S978L using Tapatalk
Diggin a hole with plastic
90 ext cab toy, short 40 Iroks, detroit and diamond, mco8-r10 duals with twin stick, 4.7 gears and 30 spline Longs/hub gears-studs
4xChinook4
Check engine is not on.... it comes on when 1st turn the key over.. then start it.. then it turns off.. So I'm assuming it works . So no codes.. also I don't have a knock sensor... I looked around the block and head for one from the donor truck.. and I never saw one !
4xChinook4
Quote from: emsvitil on May 25, 2017, 09:24:50 PM
Good place to start actually.. how would I go about checking that?
4xChinook4
Quote from: skid on May 25, 2017, 10:20:30 PM
I see what your saying, I think, temp sensor not working, the 5th injector won't turn off .. right?
skid
Quote from: 4xChinook4 on May 25, 2017, 11:38:39 PM
Wasn't  my initial  thought, but possible. I  was thinking if the computer thinks the engine was cold, the fuel mixture would be richer using more fuel along  the same lines.
  To check the cold start inj., you need to remove  and see if it's stuck open. If you can blow through it unplugged it's stuck open. If closed, reinstall leaving he electrical connector unplugged. With engine hot and running, check for power and ground at connector with a volt meter.
4xChinook4
Alright. Consider it a test for later today, and I should not be wanting to find voltage at the 5th injector connector, with the engine hot and running . Right ?
emsvitil
Quote from: 4xChinook4 on May 26, 2017, 06:55:49 AM
correct
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
pretty cool build. right on buddy!
4xChinook4
I've been buisy..  I separated for a few reasons.. 1st.. was for paint so they can get the paint the whole camper.. including the middle area between truck and camper.
Also would like to do some better supports for the nook between the truck frame and the floor.
4xChinook4
Also suspension kits? No lift.. just for a very smooth ride? Solid Adel front and rear.
Recommendations?  Or where I should start looking
emsvitil
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
helipilot77
Quote from: emsvitil on May 28, 2017, 11:25:02 PM
Old Man Emu
I second that. They are affordable and ride way better than most you'll get about 2" of lift out of them. Get the CS009F A&B for the front. A&B is left and right. . They will give you 110-240 lbs of extra load carrying capability. For the rear springs get the CSR010R which will give you 550 lbs of increased load carrying capacity. You will also want 2x of the OMESB5 front spring bushings and 2x of the OMESB6 rear spring bushings. The new springs are a thicker pack and also need longer U-bolts. To do the job you should get 2x of the OMEU52 and 4x of the OMEU53 :thumbs:
http://www.arbusa.com/uploads/PDF/accessorizeYourRig/toyotaHiLux.pdf
4xChinook4
So the rear..... air bags ? Or nah?
4xChinook4
By the way, that post is gold for yoterhome info !!! :thumbs: thankyou heli
H8PVMNT
Quote from: 4xChinook4 on May 25, 2017, 02:22:42 PM
No what I am trying to say is how much $$ do you need for it? :)
– Steve McQueen
H8PVMNT
Oh and I second or third, whatever on the Emu.  You can't go wrong with it, especially for a low lift on a truck that gets used as a truck.
– Steve McQueen
4xChinook4
Oh yeah sorry buddy, that thing is gone.. sold it a few months ago. :/ ..
4xChinook4
Still haven't taken the time for addressing that fuel consumption issue.. but this pic here is YEARS IN THE COMING ! FINALLY.. paint time.. dropped her at Maaco today.. hope it comes out as great as I ever dreamed! Shoot! I can't wait! Haha,
Here's a weird fact though?.... talking to them, said he'd prefer not to paint the camper.. something about old fiberglass being too porus and the paint shows alot  of the imperfections in the age.. ??..  anybody know about this?
4xChinook4
Fyi.. that's not me in the pic .. younger bro
Quote from: 4xChinook4 on May 30, 2017, 10:15:01 PM
True.
4xChinook4
Right.. well I got a rough idea on a quote from a fiberglass shop that does that kinda stuff like "re-gelling" old fiberglass...
$6000+ !!!!
Please someone tell me there is a cheaper option that I'm not seeing?
One cool thing is though.. the guy in that owns the fiberglass shop said.. I come buy and learn how to do everything I want to, and then go do it myself ... maybe🤔
