Toyota Chinook Build!! Mach 2.
Started by 4xChinook4, March 04, 2015, 09:10:40 PM
4xChinook4
I Had that before,  but I just plugged the air cleaner hole  and put a blue breather vent on the valve cover.
Why do you say I need that?
Toyota + rv camper; you'll never need another car, you'll never need another home. = perfect
4xChinook4
So I was able to take some of my Saturday  and get some things for this girl. Intake and exhaust  gaskets.. paint, oven cleaner, and pine sol. Here she be.
4xChinook4
4xChinook4
Oven cleanered, and first side, 1st coat.
4xChinook4
Here's a better shot of the brown. I'm really dig'n it :greengrin:
4xChinook4
And by the way, could I use my 20r vavle  cover ?? or would something not line up, or is the 22r rocker assembly too tall. ? And could I use my 20r valve seal. ?
Quote from: 4xChinook4 on April 25, 2015, 08:35:21 PM
valve cover maybe but I think that year motor has a taller rocker assembly but you can try
valve stem seals??   same size stems.
yea that purty blue filter will never pass smog and it lets blowby get all over the engine. yea it looks cool but NO.
4xChinook4
No, the rubber ring that seals the valve cover to the head. Sorry should have been more specific.
H8PVMNT
Nice brown!  That things gonna be a brown beast!
– Steve McQueen
4xChinook4
Haha ya thanks bro. I'm really liking it. And I'm not going to lie your tan of your 22r was the inspiration more or less to my color. Going for a "quieter" motor look. Kind of like it belongs in the trees and less On the street. I'm going for maybe a tan valve cover and oil pan. Kind of like yours. H8PVMNT . Not sure if I'll pain the intake though. Maybe just give it a good clean. Soaking it in pine sol right now.
H8PVMNT
In ended up using am '84 intake because it has the "hot plate" for cold starts.  I soaked it in some pretty strong parts washer solvent but the pine sol I used on the first intake did a WAY better job.  I might pick up some more pine sol if I haven't installed it by payday.
– Steve McQueen
4xChinook4
Is that what that thing is?  That's mounted under but sits inside the intake?  kind of a cylinder that would be right underneath the carb. I thought it was a sensor of some sort.  I'll have to look into how to wire that. I imagine  it doesn't run full time does it?
H8PVMNT
Yes that's it.  I guess is gets 12V on cold starts under a certain temp.  It provides a hot surface to bounce the air fuel off of since gas doesn't like to stay atomized below a certain temp.  It has some sort of mini-computer or relay that turns it on and off.  I think it could be wired to a switch easy enough since your early harness wouldn't have the stuff for it.  It has one power wire to it and grounds through the intake.
– Steve McQueen
4xChinook4
I almost wonder, if I could just wire 12v to a switch in the cab. And just turn it in and off as I please? Or would this be a big No No?
H8PVMNT
I don't see why not as long as you remember to shut it off. If it works good on my 4runner I might wire one like that om my '80 as well.
– Steve McQueen
4xChinook4
When would I know to turn it off though? Once I see the temp gauge start to move off the bottom maybe ???
emsvitil
Just need a relay and a temperature switch..
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
4xChinook4
4xChinook4
Also will my 20r thermostat  housing swap over? I've read about the mating faces being different or somthing. Does anybody know?
Quote from: 4xChinook4 on April 27, 2015, 02:19:59 PM
should swap right over
usually only run into trouble with that when putting a 20R head in a truck that had a mechanical fuel pump.
84_yota_4wd
I forgot i have a housing i can send you bud, Dont forget new spark plus those were some old old ones i through in there when i took it out to keep the holes pluged.
Marlin Crawler
Developers of the longest lasting and most successful
Toyota Transfer case, Transmission, and Differential products on the planet
(888) 94-CRAWL / 888-942-7295
4xChinook4
4xChinook4
Quote from: 84_yota_4wd on April 28, 2015, 09:15:18 AM
Ya I'm going from one mechanical fuel pumped motor to another.
Quote from: 79coyotefrg on April 28, 2015, 01:02:28 AM
H8PVMNT
– Steve McQueen
Plainview
#325
No, it won't work.  I haven't read this whole thread yet but I'm assuming you're talking about putting the 20R thermostat housing onto a 22R intake, right?
See my build thread for details:   http://board.marlincrawler.com/index.php?topic=98717.0
The 20R and 22R clock the opening in the intake differently and the flanges are slightly different.  Even if it would seal properly (which it won't), it'll be aimed way off towards the passenger side.  A 22R thermostat housing shouldn't be too hard to find...?
'84 Xtra Cab Project:
http://board.marlincrawler.com/index.php?topic=100651.new#new
Parts Wanted:
- Un-cracked dash pad (do they exist?)
4xChinook4
Yes guys, hello sorry I've been up in Glenwood  for the last 5 days or so.... and welll... SHE RUNS!! a few hick ups along the way. Like needing to get bolts for the underside of the intake manifold, and that heater had a stripped and broken bolt. (For the record I broke the bolt, but trying to loosen it/take it out ) and then plug up a few water ports on the Manifold. And yes big scary was that thermostat housing swapping over from the 20 R to the 22 R . And I am happy to say it did fit and sealed. it was very close, and it did shoot the neck way out to the passenger side, but at the end of the day it did its job fine. drove it home the full 170 miles, with no sign of a. however my battery did die in town when in Glenwood, just went to Autozone picked up a new battery and drove home no problem.
LET THE ADVENTURE CONTINUE!! :greengrin:
4xChinook4
Plainview
Good job!
I'd keep a close eye on that thermostat housing to intake seal.  I can believe it sealed, but it's definitely not the right shape so isn't making full contact all the way around.  If it was my rig, I'd be keeping my eyes open for a 22R housing to swap in.
Dig the khaki/tan colored valve cover and brown engine!
Parts Wanted:
