Toyota Chinook Build!! Mach 2.
Started by 4xChinook4, March 04, 2015, 09:10:40 PM
4xChinook4
I made a bad cut om y new wall. (That's why you see my new insulation behind. But what you do is cut a 4 x8' panelling sheet In half. Turn side ways to get the lines running vertical again. Then cut 2" off the bottom of each for them to fit in as a wall.. And ofcoarse don't forget the wheel well ...that peice of iron with the 2 bolt heads is just something to tie the frame mounting bolts together. Just a little peice of mind...
Sent from my iPad using Tapatalk
Toyota + rv camper; you'll never need another car, you'll never need another home. = perfect
4xChinook4
Now that "bubble warp junk". Well it's not junk if you use it correctly.. Since there is a type of heat that transfers through light ray (a.k.a. The sun) there is also a type of insulation for... Reflectics bubble wrap.. Sold at your local Home Depots and lowes... But for it to do its job. It must be visible so the light rays can touch it. However not too many people would want to have a shiny bubblewrap wall to look at every day that's Where the problem comes in ,once you hide it behind your wall paneling, it is no longer visible and basically turns into your closet installation of just a sheet of bubble wrap quite a waste of space more then anything now. So yes it has great affects but only when it is visible so the heat transferring light rays can "touch" it ,once it's covered it's completely useless.
4xChinook4
got out some old sink and bench guts now a before and after on either wall from left to right Getting ready to CUT IT OUT!!! a grinding wheel and a jig saw did it good.. First I took out the weatherstripping around the window and remove the window. Then following the left and right sides of where the window would sit I made that my line on either side to follow going down to make flush with the floor of the Chinook then just cut a crossed to finish up at the bottom.
4xChinook4
just screwed some old masonite to the floor to cover up the hole between the floor and CAD. And make a transition piece between the two. Then painted this along with the entire floor and oil base paint just for more peace of mind with water. Just in case.... then I invested into some of that nice under the carpet cushion however this stuff I'm using is made from recycled Nike shoes. About $.69 a square foot if I remember correctly. Well worth it and much more comfortable I can till then just playing carpet on the floor. then of course my carpet choice. Just something with a little bit of shag and the colorway I chose old-school kind of brown feel to match the walls and cushions
4xChinook4
I covered the whole floor in this carpet and then put the cabinetry on top
4xChinook4
no the parts of this billed as most excited for that had the idea from months was this bench designer came up with. It's wood slats spaced about four and half inches apart or so. With other wood slats that slide in between the stationary ones making my 6' x 2' bench Slide out. Two six-foot by 3 foot bed space. Made it with 2 inch angle iron for strength so I will not need a third leg in the middle to impede with storage space. I noticed there is no face to the bench I wanted to leave it open with such a small space as the Chinook to get in and out of your storage underneath easier and quicker. I've been sleeping on it the past few days very comfortable...
4xChinook4
and then just some other cabinets walls and counters that I've made throughout the project. Water pump works great for its age. With it being original. And also the radio just got wired in last night
4xChinook4
battery regulator for the solar panel. The radio face. And above it a kill/ignition switch to turn on and off the radio. Kind of like turning your keys on it off in your car...
4xChinook4
Now this is up to date. What do you guys think much cleaner than the first Chinook right.. :green grin;
4xChinook4
almost forgot. But here's a picture of the pass-through after I cut and wrapped it.. Bucket seats soon to follow
mudmaster
Time to go wheelin!
OVRAROK
I've been following thread, wow, what a cool rig, I wanna see some pics of this thing offroad
Slabzilla
'85 Xtra-cab, 4.5" Downey Off-Road lift, 12-15 KM2's on American Racing Baja's, Marlin's-4.88's & 4.7's, Downey Off-Road CAI, Marlin rear bumper & sliders
helipilot77
Nice work. Finally got some pictures! I would have recommended using rigid foam insulation. Poly-isocyuranate give close to an R value of 6 per inch where fiberglass batt your lucky to get close to 1 or 2 R value per inch depending on how well it's installed. Other than that I would say you need more shag carpet.  :love:
emsvitil
FYI on the bubble wrap heat shield....
It's considered to be a radiant barrier  (like the OSB panels you use to sheath your roof)
It doesn't need to see light,   but the aluminum needs an air gap to work
http://www.energyefficientsolutions.com/rbhow.asp
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
4xChinook4
Quote from: helipilot77 on July 23, 2015, 08:08:51 PM
ya I looked into rigid foam.. Good stuff and can't argue with the results. But so far I couldn't be more happy with what I got in it.  And if it comes to it, super easy to pull the walls off, and change it out.. :) but so far it's great!
4xChinook4
Plus for the price. Cost me $13 in total to insulate all the walls in there :green grin: !
4xChinook4
Quote from: emsvitil on July 23, 2015, 08:24:53 PM
thanks man, note taken. Maybe I didn't have it set up right. But in th past , I checked the air temp difference in it. This was in January I think? A pretty tolerable temp. Don't remember what it was , but was just light jacket weather. And with no furnace I had a 6 degree temp difference(Fahrenheit )... Not too bad for no furnace.
So I guess we'll see what I have now...
Yotaoverland
Super awesome rig! I'd love to put a Chinook on my '80.
1980 pickup LWB
22reperformance 22r
L-52 5spd
4.7 Tcase
Detroit Trutrac
4xChinook4
Quote from: colezombie on July 26, 2015, 04:01:07 PM
haha ya thats exactly what i did.. going to sand dunes next week. Ill see what pictures i can grab. :thumbsup:
Sent from my DROIDX using Tapatalk 2
4xChinook4
No pictures yet.. but barely used 10 gallons of gas. On a 275 mi. Trip.. ???  But always strive for 55 mph at 2500 rpms.. she was a PIG on any pass or uphill section.. only times i hung around 3000 rpms in between 3rd and 4th...
And yes i know these motors are good for 6500 rpm all day long.. but .. thats just where i like it... :)
Cheesemaker
I would recommend some stove board, or a form of heat shield behind the stove.  Don't want your hard work going up in a flame.
4xChinook4
Got it covered bro. I just finished welding on the old chinook bumper to the 80' frame. Looks much more complete now. Plus with the piece of mind knowing i have a bumper on her now.
H8PVMNT
Man you're really goin' after it!  Good job!
– Steve McQueen
4xChinook4
Well i took the steps and found a spot to weigh her. With half a tank. And me in it. Came out to 4990. Lbs. With no hood.
4xChinook4
She's quite the pig. But i did get half the fiber glass sanded tonight. Comes off like butter compared to the trucks paint. For both being original.
84_yota_4wd
Marlin Crawler
Developers of the longest lasting and most successful
Toyota Transfer case, Transmission, and Differential products on the planet
(888) 94-CRAWL / 888-942-7295
4xChinook4
Some once told me you need to sand the metal smooth. Like 220 grit smooth. Or else you see the 60 grit marks through the primer and paint? Any experience with what im saying?
emsvitil
If you roll on Rustoleum, I don't think you'll see the 60 grit marks..........
:yupyup:
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
4xChinook4
Quote from: emsvitil on August 22, 2015, 09:24:31 PM
:yupyup:
both primer and top coat? Or just primer?
