Author Topic: Toyota Chinook Build!! Mach 2.  (Read 171019 times)
4xChinook4
  • Turtle Points: 22
  • Member since Dec '14
  • Toyota + rv = paradise
Re: Toyota Chinook Build!! Mach 2.
« Reply #660 on: May 17, 2020, 09:09:05 PM »
I can finally hold a couple nalgene's now.
Sent from my SM-G960U using Tapatalk
Toyota + rv camper; you'll never need another car, you'll never need another home. = perfect
4xChinook4 [OP]
  • Turtle Points: 22
« Reply #661 on: Jun 13, 2020, 09:37:12 PM »
So I guess theres a monthly limit for pic you can post using Tapatalk. But no big deal.
But there had been a lot at work so far for June. Heres some over all of the camper interior.  Which is pretty much finished .
The table does go down to become a bed. 3' x 6'2"
And lot of other hidden things . For example , the lids to both benches are also cornhole boards . The whole medicine cabinet swings out for a small hidden liquor cabinet behind it.
The closet door can open both ways to gain access from either in the truck or standing outside the back door.
And a few other odds and ends. But shes pretty much the finished product in these photos.
As I mention before. This is the 4th time I've torn out to scrap and rebuilt the interior since 2013.. each time trying to improve the design that preceded it. And I think this will be the last time I take on such a task.  Time to really enjoy it now
4xChinook4 [OP]
  • Turtle Points: 22
« Reply #662 on: Jul 15, 2020, 09:04:17 AM »
Thanks for the replies . Everyone. I know this might sound crazy. Lol. But in a year or so maybe 2. I kinda have the itch to want to remove and sell the whole chinook camper. And try my hand at making the truck into a pop top trekker .. thoughts?
4xChinook4 [OP]
  • Turtle Points: 22
« Reply #663 on: Aug 05, 2020, 11:10:22 PM »
hey guys! I'm trying to adjust my timing ( 22re) and with terminals Te1 and E1 jumped. The only way I can reach 5° BTDC is if the distributor is in the maxed out CCW position, which I know aint good. , I know once you "unjump" those terminals you should between 10 and 14 ° BTDC . But I don't.  Instead I'm at 6 and 10°  BTDC . I did recently install the CRANE multi spark system. But not sure that should effect or play a role in this issue.
Thanks for your help
emsvitil
  • Turtle Points: 7571
  • Male Posts: 3,561
  • Member since May '07
    • emsvitil's album
    • Buy me a soda
« Reply #664 on: Aug 06, 2020, 12:24:47 AM »
Did you remove distributor?
Might be off a tooth.
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
4xChinook4 [OP]
  • Turtle Points: 22
« Reply #665 on: Aug 06, 2020, 05:08:22 AM »
Thought bought that. But I havent adjusted or messed with my timing in 2 years .
I could see that as a problem for 1st rebuild or reassembly. .
And I dont remember this issue when I set it back then.
I'm still just trying to figure out the heavy exhaust cloud.  Which I know is fuel related . Not oil/ not coolant .
You can smell it .
And is a hard start when engine is already warm. Unless I floor the gas pedal while cranking. . Which makes me think leaky injectors.
emsvitil
  • Male Posts: 3,561
    • emsvitil's album
    • Buy me a soda
« Reply #666 on: Aug 06, 2020, 05:19:26 AM »
Your timing light may not like your multi-spark and is confused.
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
4xChinook4 [OP]
  • Turtle Points: 22
« Reply #667 on: Aug 06, 2020, 05:25:54 AM »
Thats a great guess.! And I emailed LCE about it too. We'll See what they have to say.
4xChinook4 [OP]
  • Turtle Points: 22
« Reply #668 on: Aug 22, 2020, 12:53:59 PM »
Well I'm still trying to figure things out . But here's the update
TPS from Autozone was junk. Both the original and the replacement. The idle circuit (bottom 2 prongs) never closed or gained continuity.
So got a genuine OEM . And worked great.
But still trying to figure out the timing issue.
Its not the multi spark, here's what I've figured out though..
That magnetic pick up in the dizzy. Will only line up with the 4 tooth rotor . When i have it maxed out CCW position.
 Also this is the closes i can get to 5* BTDC
In the maxed out CCW position. .
So I physically cannot get any earlier .
I'm thinking stretched chain perhaps??
But this chain was put in 3 years ago. So not old at all.
Basically I cannot advance any further.
Also cam gear dot does line up @ 11:45  . And the cam itself is at 12:00 . When crank pully is @ 0*
So its not "off a tooth" .
Any ideas?
emsvitil
  • Male Posts: 3,561
    • emsvitil's album
    • Buy me a soda
« Reply #669 on: Aug 22, 2020, 08:12:41 PM »
Pull the distributor out, and put back in aligned with a different distributor tooth.
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
4xChinook4 [OP]
  • Turtle Points: 22
« Reply #670 on: Aug 22, 2020, 09:44:47 PM »
Thanks for the suggestion. I wish it was that simple . Because I been trying that.  But then its TOO far ADVANCED.. where I would have to Max out the Dizzy in the CW  position to even get close .
4xChinook4 [OP]
  • Turtle Points: 22
« Reply #671 on: Aug 22, 2020, 10:32:35 PM »
Also i feel I should say. That it does start, run and accelerate smoothly,  its just the timing is like too retarded to advance enough to 5* . And the idle is a little bit rough. You wouldn't even notice it, unless you open the hood and watch the engine slightly shack/ stutter
Lewis Hein
  • Shoutbox Ban
  • Turtle Points: 273
  • Member since Feb '17
  • Trying to equal the wonderful one-hoss shay
« Reply #672 on: Aug 23, 2020, 05:24:46 AM »
Silly question, but.... Is the notch on the harmonic balancer pulley lined up correctly? Is the scale it reads against the correct part and in the right place?
4xChinook4 [OP]
  • Turtle Points: 22
« Reply #673 on: Aug 23, 2020, 06:21:13 AM »
No silly questions here bro! I want to say yes by how obvious that should be. Plus being that when the notch on the pulley lines up with the 0*  on the oil pump, the cam is also at 12 o'clock .
But ill take a few pictures later .
helipilot77
  • Turtle Points: 1018
  • Male Posts: 1,727
  • Member since Jul '12
  • Seattle, WA
    • My build thread
« Reply #674 on: Aug 23, 2020, 01:38:34 PM »
I have had this exact same problem before and the distributor was off a tooth. Pulling it out moved the adjustment from maxed out to centered. play with it a bit. pulling it out should allow it to move half the adjustment.
4xChinook4 [OP]
  • Turtle Points: 22
« Reply #675 on: Aug 23, 2020, 01:57:45 PM »
Dang well... perhaps thats the story. . If it is ive been running around with the Dizzy off half a tooth for 3 yrs. ..
Buts shes started and run very smoothly this whole time?
I feel like you would notice it though in the performance, if the tooth was off. No??
helipilot77
  • Male Posts: 1,727
  • Seattle, WA
    • My build thread
« Reply #676 on: Aug 24, 2020, 09:23:34 AM »
No. You wouldn’t notice it because the adjustment slot is allowing you to time it “close” to where it should be. Shifting the dizzy over a tooth will put the adjustment in the center of the slot and allow you “dial-in” your timing.
4xChinook4 [OP]
  • Turtle Points: 22
« Reply #677 on: Sep 06, 2020, 10:38:45 PM »
So this is my timing with the dizzy rotor inserted at the 12 o'clock position.
With the crank set at 5° BTDC
and the TE1 & E1 jumped
And a picture of the dizzy itself to show It.  being maxed out in the CW position.  In order to get this close .
If i spun the dizzy CCW while like this its advances even further
4xChinook4 [OP]
  • Turtle Points: 22
« Reply #678 on: Sep 06, 2020, 10:42:35 PM »
And this my timing. When the dizzy is inserted one tooth to left or CCW of 12 o'clock.
With TE1 & E1 jumped
Along with a pic of the dizzy and now maxed in the CCW position of its range. If I spin any more CW it retards itself to far.
4xChinook4 [OP]
  • Turtle Points: 22
« Reply #679 on: Sep 06, 2020, 10:51:11 PM »
I know y'all might be thinking . I'm accidently skipping a tooth when I adjust the dizzy from one example to the other.
But I dont know how else to say this .
Other than I am being extremely meticulous when I pull out, adjust, slide back in. Where I am still sliding the faces of the gears to be sure I'm slipping from one slot to the next.
I'm stumped.
Because the truck idles decent, not perfect, not great, but decent .
emsvitil
  • Male Posts: 3,561
    • emsvitil's album
    • Buy me a soda
« Reply #680 on: Sep 07, 2020, 01:08:17 AM »
Have you verified that TDC mark is actually TDC?
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
4xChinook4 [OP]
  • Turtle Points: 22
« Reply #681 on: Sep 07, 2020, 06:03:37 AM »
Great question . And yes ,by spinning the crank to 0° . And pulling the Valve cover to look @ cyl 1 rocker arms Are loose.
And the cam is in 12 o'clock with the timing mark on the cam gear @ the ~11:45 mark.
.hence why I am stumped
Fyi I have the PDF of the FSM . So this is what I'm following.
With the crank @ 5°BTDC "insert at the 12 o'clock position" let the rotor swing back CCW "
Then align the pick up sensor in the dizzy with the rotors.
 But that won't actually happen.
Lewis Hein
  • Shoutbox Ban
« Reply #682 on: Sep 08, 2020, 09:57:49 AM »
I am a little stumped.  Do you have a different distributor you could try? Has the block or head been decked?
4xChinook4 [OP]
  • Turtle Points: 22
« Reply #683 on: Sep 08, 2020, 10:08:41 AM »
Thanks bro.. No & No .  . I tried looking at other dizzys on Google images and see if there's any differences in my rotor and those . And I didn't find anything.
Fyi, incase anyone is thinking it. My TPS is adjusted correctly as well.
Lewis Hein
  • Shoutbox Ban
« Reply #684 on: Sep 10, 2020, 05:03:08 AM »
Okay, another long shot in the dark. Are your distributor cap and rotor OEM? Did the manufacturer somehow build them wrong? How about the ECM? Is it good?
4xChinook4 [OP]
  • Turtle Points: 22
« Reply #685 on: Sep 10, 2020, 05:22:53 AM »
Thats a great idea! I have Bosch cap and rotor.
Part #  03168
Part # 04159
https://www.amazon.com/dp/B000BZJ2TY/ref=cm_sw_r_cp_apa_i_fQHwFb3P2EMBN
https://www.amazon.com/dp/B000BZEDTS/ref=cm_sw_r_cp_apa_i_AOHwFbPZZCGV5
They seem right
Lewis Hein
  • Shoutbox Ban
« Reply #686 on: Sep 10, 2020, 08:32:21 PM »
Well.... I am running low on ideas. If I were you I'd be pretty tempted to get out the parts cannon and replace the Distributor cap and rotor with Denso parts, though I'm not hopeful.
One thought. Are you sure the Crane multi-spark system isn't causing issues? like, really, really sure? Is there a quick way to hook up a single-spark system to check your timing? Because the more I think about it, the more I wonder if that is the cause of your woes. You may already know all or most of the following, but for the sake of thouroughness I will write it anyway.
A timing light has a big copper coil that clamps around your spark plug wire. When a spike of voltage travels down said spark wire, this causes a little voltage spike inside the timing light's pickup coil, which is then amplified to trigger a transistor (basically a super-fast super-duper relay for this application) to make a bulb go all blinky blinky.
There is probably some amount of "blurring" of this voltage spike between being picked up and turning into a flash of light, some maybe intentional and some accidental.
What concerns me is that if you have three spikes in quick succession (because of a multi-spark system) these could well be "blurred" to look like one looong spark with an average position much later than the actual time of the first spark.
I suppose a timing light could even exist that detected not the spike itself, but the abrupt voltage drop at the end of the spike, with a very real possibility of giving poor readings on a multi-spark system.
I don't know the details of your multi-spark system, and I can't begin to guess at the details of what might be in your timing light that might make or break it's ability to read a multi-spark ignition accurately. But I would love to see what you got if you checked timing with factory Toyota ignition system or a multi-spark compatible timing light
4xChinook4 [OP]
  • Turtle Points: 22
« Reply #687 on: Sep 10, 2020, 10:28:11 PM »
Thankyou so much for working with me on this . And trying help troubleshoot this all. ! Honestly. It helps me wrap my brain around it all.. I'll give it a try
Sent from my SM-T510 using Tapatalk
4xChinook4 [OP]
  • Turtle Points: 22
« Reply #688 on: Sep 12, 2020, 12:10:05 PM »
A separate update. I have ordered 2 sensors that I realized were defective and 1 could be a real reason for my no start when warm issue.
Recently I found the Factory Service Manual for free PDF download online. And have been studying it and reading it hard core to try and learn about the EFI systems.
And learned that my "back woods repair" for the Cold injector time switch was not as clever as i thought . Since that sensor sends a Ohm resistance reading to the ECM . Its not really a on/off . Continuity/ infinite type switch.
Which is basically what I turned it into with my switch wired under the dash to CSI time switches plug.
So found an OEM sensor on ebay and that'll be here Tuesday
And learned that the Ohms for my O2 sensors are supposed to be between 5.1 and 6.3 (I believe this to be the heater circuit of the sensor)
Well my second, downstream was at 13.3. So I ordered a new one aswell.
I've read that the heater circuit isn't very critical, but im kinda tired of neglecting an issue and trying to find a "cheaper route" like I did with the Wire of CSI time switch.
helipilot77
  • Male Posts: 1,727
  • Seattle, WA
    • My build thread
« Reply #689 on: Sep 12, 2020, 01:01:27 PM »
Never heard that expression before but I love it!
The distributor drive gear has 13 teeth on it which would make each tooth about 27.6923077° Apart. If you think that is about what you are getting then I am stumped too.
Last post Mar 24, 2006, 04:22:32 PM
by Plowking
Last post Jun 19, 2009, 10:41:23 AM
by kletzenklueffer
Last post May 19, 2015, 09:02:23 AM
by BigMike
Last post May 19, 2015, 09:06:03 AM
by BigMike
Last post Aug 30, 2016, 10:06:11 AM
by H8PVMNT
