Jrock's New Build
Started by jrock, July 30, 2012, 01:15:14 PM
zidaro
wanna see this bad boy out at koh!!
lets run a trail.
i'll be around the eaton rig #4509 hopefully.   garage 228
'87runner.
'10 Crewmax
'05 CRF450x
http://www.4wheelunderground.com/
TONIK- Mammoth Lakes
jrock
I should be updating this thread more. Lots going on. So, KOH was a blast, thou I didn't wheel nearly as much as I'd have liked. Spent a lot of time in the pits and Hammer Town. So many sweet rigs. Got lots and lots of ideas ;)
First night I went to Chocolate Thunder and rolled within 2 min of locking my hubs :P but got that outta my system. Later in the week we ran Wreckingball and I concurred my last years only winch point, the Waterfall. One-shotted it! Stoked hardly defines how happy I was. The rest of the week was mostly running around, nothing special.
As for the rig..... The week before leaving for KOH, my engine developed a knock. I called around, everyone said balance shafts. So out they came. And... knock is still there. So, bottle of Lucas and I'm running it for now.
Got home from KOH and within 5 min my front diff blew up. My backside carrier adjuster backed off and opened my backlash like 1/4"! I'm done with 5.29s! I'm throwing in stock 4.10s. While everything has been apart, I went ahead and rebuilt another front axle. Mine was bent, not surprisingly. Thanks to Smokeybeans for the trussed and gusseted axle ;) I put some final touches on it. Replaced the driver perch, fully gusseted the truss, cut off the passanger lower plate thing, shaved the drain plug, added an inspection plug, and will be adding an axle skid.
And welded up my new to me diffs.
More to come.
jrock
More stuff.
On its way..
jrock
Helped a friend and gave him my old 5" front shackles. I put my 5.5" back up front and threw some 6" out back. Thanks Stlrstlr. Finally got to mounting my 14"/12" shocks and man do they fit good. More up and down travel, and I won't be maxing them out. Should run really well.
And my truck is back on it own springs again, with the new front axle. Thanks again Smokeybeans.
MRHilux87
What Kind of rear axle truss is that?  I like it.
1987 4Runner.   3RZ.  SAS Duals 5.29 Elocker Rear Detroit front 35s... Hydro assist
2007 Cummins 6.7 DRW g56.  deleted EFI live.
2013 Ninja 1000
SOLD:
2006 Mitsibishi EVO 9.  347WHP runs 12.2s - Wifes daily driver.  Ducati 916 - track bike.
jrock
Quote from: MRHilux87 on April 24, 2014, 10:24:01 PM
RuffStuff
HogCanyonHopper
looking good Jerome. I am curious how welding that rear truss works/worked out. and do you have your rear springs inboarded? if so, how much and how do you like the flex? shocks vertical? that pup must be big by now  :thumbs:
jrock
Quote from: HogCanyonHopper on April 27, 2014, 02:11:58 AM
Welding the truss will take a lot of time. It'll be stitch welded in short sections. My rear springs are inboarded, something like 5.5" on both sides. The rears now match the front in spring width. And the flex it much much better. I can run a stiffer spring and since the axle has more leverage on it when articulating, it flexes easy. But I have a better weight capacity. Shocks are vertical and leaned forward.
The pup is big and so much energy. She minds really good. Couldn't have asked for a better pup :)
jrock
Finally did it. Took longer to get it to fit the Tacoma housing than it did to weld it.
zippo
That is the most welded, welded diff i have ever seen! Looks AWESOME!
If you see it, its for sale.
jrock
Haha, I have a tendency to break things, I didn't want it to break :)
jrock
1985CRAWLER
beef,
i like your shock setup as well :thumbs:
jrock
#314
Well this is shitty,
HogCanyonHopper
ouch. breakin stuff again I see  :_oops: . whats the plan now?
ImmortalYota80
Looks like those knuckle gussets didnt hold up too well! That sucks
1980 4x4 Pickup, 22RE Swap, Marlin Built G54 Trans, 35/12.50 Cooper STT's, 4" Alcan Front springs/F150 rears, Open 5.29 front, 5.29 E-Locker Rear, Rebuilt Axles, High Steer
Build:
http://board.marlincrawler.com/index.php?topic=94416.new#new
Tallchevy
Ummm...... did you know your camber is off just a little!  :hammer:
87 4Runner redo
1985CRAWLER
geeze!  :sheerterror:
looks like the ball ripped off.
i have an 85 housing in paradise ca area if you ever make it down here.
daniresch
 :yikes: OUCH!! how'd it happen???
jrock
Plan is to find another housing for MCR. The knuckle ball is split in half. I'm quite surprised, I've actually never seen this. Ive got an axle lined up local, it's going to last until I can get some beef under this thing.
TallChevy... ;)
What did this was a 4ft ledge I didn't quite see going 30mph. With a little hump at the bottom, it hit pretty good though it landed really soft. I can't wait to tear it apart and see what else is broke :(
brockbuilt85
wow i didn't realize how bad this was from the facebook pic, holy smokes!
When in doubt, skinny pedal!
Turd Box Build:
http://board.marlincrawler.com/index.php?topic=50894.0
jrock
Quote from: brockbuilt85 on August 11, 2014, 09:18:28 AM
Haha, yeah. She's broke!
Dingman.
Thats pretty wicked!!!
Quote from: jrock on August 10, 2014, 07:50:18 PM
When you say this ^^^ what are your plans?
jrock
d60 f/r with 6.17s :D
Some day :(
Dingman.
Yea, the only reason i did 60/14bolt cause i coupdnt keep toy diffs alive
jrock
I've had that problem too, but I since switched to 4.10s to save money and stop breaking. Now I'm worried about my outputs and input.
superyota
Dang!  You break more crap than anyone i know!  Lol.
ABD Motorsports
#4475
www.placercountycrawlers.com
KK6QDW
superyota
I see your pup's not a pup anymore.  Be good to see you at mcr.  Ride along with bill of he's coming.  And tell him to bring my KOH sweatshirt :)
ABD Motorsports
#4475
KK6QDW
jrock
Does he still have that? Haha. He's probably not able to go but I'll see. Otherwise I could be riding with another local Yota. It'll be down to the wire whether or not I get to go :(
