Jrock's New Build
Started by jrock, July 30, 2012, 01:15:14 PM
22REBABE
Hahaha yeah that sounds like a good idea
jrock
Side note..., Paradise has some good buys if your close enough. Buddy of mine picked up a Taco with full widths and 38x15.5"x15" SSR. Needs a bunch of stuff though. I got my spare Xcab cab :) 1AM in Red Bluff and headed home. ETA = 5AM :(
fordh8r
Why did you get a spare cab? Didn't you just buy a complete truck?  :confused:
jrock
It came with the complete truck so it was free for me. I just needed to pick it up
Got home just before 6am. Dang.
superyota
Dang! You do more driving than I do! Lol. Trucks looking good. Icant wait to drive it!  :gap:
ABD Motorsports
#4475
www.placercountycrawlers.com
KK6QDW
jrock
Ha, your always on the road! I do the hard hauls.
This truck is being a pain. Windshields are expensive. I cut the 3" Magnaflow glass pack off. I plan to run a Turbo 2.5"
Quote from: jrock on August 19, 2012, 09:12:07 AM
So what ive been doing these last few nights is rewiring the t100 harness to work with a 85 steering column. They're a lot alike except on how they control turn signals and the number of pins they have. T100 has more pins but uses less wires when switched over to the 85 column.
And I have been trying to build a complete tilt wheel steering column from two other columns. I hit a wall without a steering wheel puller :(
Ive never used a steering wheel puller. take the nut off and wiggle.
John Doe
Quote from: THK Matt on August 21, 2012, 12:49:44 PM
I also will tap the end of the loosened nut with a hammer a few times. not enough to damage anything, just enough to get things loose.
jrock
jrock
I need to finish the exhaust but the 2.5" Turbo muffler is SO much better, quieter and throatier.
jrock
#70
Changed the rear shock hoop and made the rear shocks as vertical as I can for now. 5.5" uptravel and 4.5" down, i may change this around. It depends on how much down travel I can actually use. I also pulled a leaf out of the rear packs, it was sitting about an inch high. Now it's almost good. With gear itll be good.
jrock
Little bit of interference :( The bumps still have 1.5" left and the shock has almost 1". The dragline hits the spring with a 3/4 drop pitman and the TRE nut hits the frame bad with a flat pitman arm :( I don't want to lower the bumps any more because it'll ruin the ride, it'll practically be sitting on the bumps.
But the rear turned out well with 5.5" down and 4.5" up. I'm still needing to add a 2" spacer to the bump stops.
Dingman.
Quote from: jrock on August 21, 2012, 01:08:37 AM
Really?  I never find anything and i live here. Haha
jrock
Haha, strangely enough, that's what the people I bought from said too but my experience says otherwise :) I guess it's all timing and what your looking for
Dingman.
I suppose. Im liking your new truck by the way
jrock
mudaddict
what about notching the frame for the tre so you can run the flat pitman arm? i know we have done it on a truck or 2 here
I work At
All Pro Off Road
jrock
It wouldn't be only for the TRE nut, I would need to notch for the pitman arm too :( I'm thinking this is the way to go. Unless I can put the TRE on top of this arm.
Slolyfe
Looks like your spring is inverting too.
You'll never take me alive
mudaddict
Quote from: Slolyfe on August 30, 2012, 04:28:40 PM
i was just noticing that as well.
I work At
All Pro Off Road
jrock
Quote from: mudaddict on August 30, 2012, 04:35:47 PM
They are. The fronts are flat when the bumps hit. They invert about 1.5" to aid in uptravel, the rears go about 1". They've been like this for about 2yrs. Maybe this is why my AP 3" fronts are now more like a 2"... max. The rear MC 4" have a main leaf pulled to soften them and bring them down to about a 3".
jrock
#81
Put this here so I don't loose it. It's my truck at Azusa Canyon driven by the OG.
http://www.pirate4x4.com/forum/showthread.php?t=935185&highlight=
jrock
New parts.
Rear seat out of a Amigo.
Rear disks brakes out of a 95 Montero LS.
nisota
Lookin good nice bump check.
Oregon wheelin'
82' 2wd-4wd project
http://board.marlincrawler.com/index.php?topic=89180.0
jrock
#84
Pictures :) Everyone likes pictures.
superyota
I like it! Looking good buddy! How does that back brake work? Looks like its a combo drum ebrake with disk brake?
ABD Motorsports
#4475
KK6QDW
tgmaul88
jrock
Quote from: superyota on September 05, 2012, 11:16:40 PM
It is a combo, drum style ebrake, but I didnt bother with the ebrake yet.
jrock
Same drill, more pictures.
superyota
Wow! Looks good. Man your making more progress on your new rig in the last 30 days than I have all year! Lol. Looks good!
ABD Motorsports
#4475
KK6QDW
