My 84 extra cab is gone. Tacoma build now.
Started by Hyena, November 21, 2004, 12:25:12 PM
gotrocks
Ramrod
i could round up that ball for you I bet
Hyena
I only need one ball.  thanx!
Ramrod
is it just the one that goes on the output shaft?
kiyul4130
sounds like you have plenty of ball options. this thread turned really gay, really fast.
-kiyul-
ECV 7-11
KYOTA FOREVER
gotrocks
Ok I found everything you need.  PM me your address.  If you cover shipping I'll send them your way.
Doof
Quote from: kiyul4130 on October 09, 2008, 06:40:05 PM
:rofl2: hahaha
i was going to say ill go look for my :pokinit: also if nobody got you the ball and bearing
Hyena
got hella people saying they have them.  and i have 2 of everything, just nothing that i need!
Hyena
well i gotthe parts i needed from Dain (inyourownsummerami) and got the cases back together and installed today.  seats, and belts are in also.  extended the front driveline, clocked the new piece a little to take out the slop.  beveled it and put 3 passes over it.  it should be good.  drilled out the rear t-cases flange and driveline flange to 3/8's and put some 3/8's grade 8 bolts in there.  should be stronger then the 5/16's grade 5 bolts i had in there before.  just need to fill it with gear oil and put the shifters back in and that job will be done.  also got the wheel hubs on friday so i mounted the rotors on them.  still waiting for the caliper brackets to show up before i can put it together.  hydro lines and fittings should be here on the 15th.
Doof
nice... way to go big with all that little stuff so its not a worry down the road to much
TIMS89CRAWLER
I like that skid plate setup I need to rig something like that on mine...good work
www.choptechfab.com
www.myspace.com/choptechfab
CHECK THE BUILD
kiyul4130
very nice. cool to see some things getting done.
-kiyul-
ECV 7-11
KYOTA FOREVER
Hyena
#2562
coil overs will be the next big purchase.  looks like i need 18's for the front and 14's for the back.  F-O-A seems to have some pretty sweet prices these days.  i can get 4 coil overs with reservoirs (no springs) for a little over $1000.  springs will be another $600 if i buy them new.
gotrocks
18's up front.  WOW your going to have a ton of travel.  I can't wait to see how you shoe horn those in there.
Hyena
ya, its wierd.  at ride height i have 31 inches between the two points i want to mount the shocks too.  with 5 inches of up travel that leaves it at 27 inches compressed.  F-O-A says there 18 inch shock is 26.25 inches eye-eye compressed which is pretty perfect for me.  and i won't have to cut the hood!  i was running a 16 inch air shock in the back but i did lower it an inch or two so i guess i will have to step down to a 14.
gotrocks
Like I said I can't wait to see this.
slorunner85
what shocks are you gonna run? (brand)to lazy to read more.
'85 4ruggy linked ft and rr
42"iroks
pro rock 60 arb
14bolt spooled
5.13
marlins dual ultimate
inmyownsummerami
Quote from: slorunner85 on October 13, 2008, 10:21:24 PM
He's gonna run coil-overs
WHITE WHEEL ROCK CRAWLERS "If your wheels ain't white, they ain't right"
:greengrin:My 1st Gen. Toyota SAS (2wd to 4wd) :greengrin: (In Progress)
RIP "Goody Goods" My DDW Brother
kiyul4130
18s, jesus. you wont use all the droop on those though. youll bind up the front driveline long before that. damn a G for 4, thats really good. well 1600 fully loaded is great. keep it up. cant wait for us to get back on the trail. where do you think it will be around Feb. thats when the snow is pretty good here.
-kiyul-
ECV 7-11
KYOTA FOREVER
slorunner85
42"iroks
pro rock 60 arb
14bolt spooled
5.13
gotrocks
kiyul4130
Quote from: slorunner85 on October 14, 2008, 10:49:34 AM
BRAND?.... i got the coil over part.
Quote from: Hyena on October 13, 2008, 10:17:24 PM
F-O-A says there 18 inch shock is 26.25 inches eye-eye compressed.....
its right there!!!!
-kiyul-
ECV 7-11
KYOTA FOREVER
kiyul4130
whats going on for halloween?
-kiyul-
ECV 7-11
KYOTA FOREVER
Hyena
not sure for halloween.  pat might come down this way.
got the caliper brackets today, but theee top caliper pin won't go in on the drivers side because it hits the back part of my highsteer arm.  i am going to take the arm to work and try and bend it up to clear the pin.  hopefully the ram will still mount to it after i bend it.  :(
Doof
what about milling it out a little bit
Hyena
I could but that will take away some strength in the arm.
Doof
yea i thought about that right after i posted that...
good luck with that bend... hope it doesnt flopp anything up
Shamb
think that will have issues further down the road if you bend it?
looking at the picture's you'd just barely have to shave a small section out, would it make that big of a diff. on the strength factor?
Hyena
its only a small part on the outside of the arm, but towards the inside i will have to take a little more out.  i may just mill it and then put a brace on the top of the arm.
Doof
i was thinking on the bottom could also work
just some 1x1x 1/8  or 1/4 if you want beef flatbar would be good... since the theme is beef supports now
