My 84 extra cab is gone. Tacoma build now.
Started by Hyena, November 21, 2004, 12:25:12 PM
Mega Baby Huey
NICE RIG! I WISH MY LISCENSE PLATE WAS UP ON THE TAILGATE...MINE KEEPS FALLING OFF!
The Art of Flying is Actually Quite Simple! You Just Have to Throw Yourself at the Ground and Miss!!!                                   All This Global Warming is Wearing Out My Snow Shovel!!!                        Paved Roads: Just Another Example of Useless Government Spending!                                          Toyota. Moving forward... even if you don't want to...
My Old Toy
thanx.  a lot of time and money has brought it this far.
got the fitting for the steering pump drilled out to 13/64ths so the steerin will be as quick a before.  also got my resevoir extended by taking two and cutting the bottom off one and the top off another.  combined them and i have twice the capasity in the resevoir.  I TIG'd them back together.  it was my first time ever using the tig so the welds didn't turn out that great.  i hope they are leak proof.  i also got the coller mounted and the hoses for that ran.  just waiting on the steering box rebuild seal kit.
Shamb
When do you plan on linking it and mounting those air shocks?
i don't know.  i have to move my truck and all my :pokinit: by february 18th and the only place i can keep it at is 30 minutes away in Cool and has no fabrication tools at all.  so i am not sure.  i am hoping to have the links and air shocks done by the hammers.  but probably not a rear cage flatbed thing.
locktup
#1054
Do you have all the junk to link it?
Will Rick let you use the shop?
If you could link it in a weekend I have some space you can use.
Jason
Quote from: MUDDONKEY on November 29, 2005, 05:23:59 PM
LOCKTUP SHOULD HAVE HIS OWN DISCOVERY CHANNEL SHOW!!
www.LOCKTUPFABRICATION.com
Quote from: locktup on January 26, 2007, 03:35:32 PM
Jason
All i have are the shocks.  i could make the brackets pretty easily.  i could probably move the gastank before hand.  so a weekend is doable.  but it won't be for at least a month.  I'll talk to ya tomarrow at the shop Jason.
Shamb
You could leave the gas tank were its at...
run a 2 link w/ a panhard bar... or something similar.
#1057
nah, im gonna go all the way with a dual triangulated four link.
Anyway, hear are some updated pics.  got the ram, resevoir, and intake mounted to day.  i might end up taking almost half an inch off the top of the plate for the ram mount.  there is about 4 inches of room between that and the oil pan and the shocks have 4 1/2 inches of uptravel left  :(  i'll be working on it tomarrow though.  can't try outthe ram yet since i am still waiting for the seal kit for the box.
locktup
Sweet mount  :flamer:.
Let me know when you are ready!!!
Jason
rednk1980
I'll start gathering parts Jason.  and i had to do the go-fast-holes, they are a must.  I might even be trading Rick Tires plus $150 bucks.  his 39.5 iroks aren't in bad condition.
boggerunner
im lovin the build, but whats up with the upside down front axle housing?
factory drain plug and truss on the topside?
im lost
Quote from: boggerunner on January 27, 2007, 07:58:34 PM
im lost
It's custom  :)  when i clearanced the bottom of the housings i took the drain plugs and welded them at the top to fill it easier.  the cut the gusset off the bottom also and welded it on the top for more clearance.  It worked out pretty good.   but i am really surprised that i didn't warp the housing with all the welding that i did on it.
locktup
If you don't trade with Rick I will.
Quote from: locktup on January 27, 2007, 08:02:09 PM
no, there mine, there all mine!
locktup
I called Rick and there mine!! :beerchug:
Rick said you'd shoot your eye out with a tire that big.
I'm just lookin out for you.
You can come over any time you like to visit them  :welcome:.
well, you might as well just give me them 38's then.
locktup
OK you can have the 39.5's
Talk to you later.
Jason
6.72:1
[email protected]
Cell: (205) 919-3290
www.Kupferphotography.com
Today i got the front tube work pretty much done for right now.  it should be pretty strong.  I also took a port-a-power to the inside of the cab prying out on both sides since the sides of the cab were smashed in and hitting the seats.  And i got my new to me 39.5 inch Iroks on!
they rub a little bit.
boggerunner
daaammmm, that looks good, now for some front cab clearance, do they rub hard?
any chance for this rig to ever see another set of doors, or a cut down toyota grill up front?
locktup
gotrocks
not bad man.  I like the new rubber.  I wish I was getting my IROK's I'm holding off now I think for a while.  I need to save some more money.
Quote from: boggerunner on January 28, 2007, 08:01:29 PM
they rub pretty hard.  it has already been clearance a few inches but there is still room to clear it more.  i would have to cut into the body mount, cut the rock sliders and then hope the clutch pedal still has all the travel.  door won't fit on it anymore.  the space between the hinges and the latch actually smashed together so the door is too big.  i could push it back but it would really matter since i don't have a windshield right now.  a cutdown toyota grill would be sweep.  m,ine was pretty banged up but i may be able to get it to work.
Shamb
Brad those Irok's look fawkin awesome on your rig. They look like they belong there!
I'm really starting to like the looks of your rig and the formation that its taking. I wasn't a big fan of the tubed front end at first when I saw it on Pat's rig.. but now that its getting braced and i'm seeing it all tie in together it does look good.
Can't wait to hit up some trails soon!  I'm ordering my coilovers tomorrow (if they give me a price!)
Ramrod
bad ass brad that is sick dude, your truck is set now......... to break that is. no but really that thing is looking sweet
topar
Ramrod
im actually jealous that thing looks sick, look foward to stealing it again actually
Shamb
That should give you motivation to get your shizzle together Pat!!!!!
:flamer: :hammer:
