My 84 extra cab is gone. Tacoma build now.
Started by Hyena, November 21, 2004, 12:25:12 PM
Quote from: TEAM RAMROD on January 28, 2007, 08:33:48 PM
im actually jealous that thing looks sick, look foward to stealing it again actually
I'll just steal your taco.  it woul be an even trade i would think  :)
KYOTA
alwayzbroken
Looks good :biggthumpup:
I thought my 38s were huge when I got them 2 years ago. 38s are now :gay:
42s  hmmm.... :idea:
yotamckimboy4x4
that looks bad ass brad. iroks are the only way to go. hope you have fun
"We ride together, We die together, YOTABOYS FOR LIFE"    85 toy pickup 5 inch springs 2inch body lift, 36" IROKS, custom front bumper
"HOLD ON TIGHT"
yotaboy79
well i guess you did upgrade tires, looks good brad
thanx guys.  a little bit of progress, i got the front driveline extended about 5 inches so it should fall out anymore.  and i got my new tie rod end in the mail today.  all i need it the steering box seal kit which should be here in a couple days i hope.  then i can drive it again and see how the steering is.
88Rokyoat
Any plans to cut the floor board where the 4D's rub? I will be doing that to mine pretty soon so I can upgrade tires too.
stupid people shouldn't have kids.
i already tubbed my firewall a couple years ago planing for 37's.  i can probably tub it a little more but not much.
Yota4life
So did you hear from the guy with the seal kits? I need mine now!
Quote from: Yota4life on January 30, 2007, 06:44:13 PM
He sent your's out on monday.  he is sending mine out tomarrow.
Yota4life
Quote from: Hyena on January 30, 2007, 10:43:02 PM
Nice, that means i should have it before this weekend. Did he send it ups ground or did he not say?
So i am pretty much screwed over now.  i got my seal kit in the mail and tried to install it.  tried for about 3 hours.  ended up destroying the 2 white bushing that go onto the worm gear thing.  i don't know what to do now.  it is like the bushing were to big or something because the worm gear wouldn't go into the housing at all.  i am so pissed off right now.  i was hoping to get my truck driving again by this weekend but i guess not now.
gotrocks
what seal are you refering about?
the 2 teflon bushings on the warm gear thing.
dov'd85
man the yota is sick! i am building something simalier a cab on a toy frame... hydro assist 39.5 iroks and i don't know about you but mine rub so bad! the axle is moved forward with the spring hanger then the offset pins and i moved it another half inch forward and they still rub.. i cut the front body mounts off the frame and body and now it flexs into my sliders. :yesnod: ? what front springs are you running? do you still have your body mounts
85 long bed: 30 spline long, hydro assist, hysteer, 223.1 twin sticks, 39.5 iroks, rear disk,
http://board.marlincrawler.com/index.php?topic=28696.msg344178#msg344178
im running toy rear springs with some other leaves mixed in.  i still have the body mounts on there.  and they do rub the hell out of the cab.  i did tub the firewall once and it looks like i will have to do it more.
dov'd85
so with those rears up front thats a 3-4in lift and 2in forward?
the spring gave about 3 inches of lift, the shackles about another inch and the drop hanger about an other inch.  so about 5-6 inches for me.  the axle is only moved forward about 1-2 inches total, not sure.  i actually mounted the springs about 1 inch back from stock not thinking i was going to be running 40's one day  :(
new gas tank is in the worx, can you say stainless?  :)
bigman
MONTANA BOYS KICK A$$
IF U CANT DUCK IT F IT
i was talked into using stainless.  i wanted to just use steel but got the stainless for a good price.  anybody know how much a 36"x14"x7" gas tank will hold in gallons?  do you guys thing thjat it will work ok for only being 7 inches wide?  thats about all the room i have for the place i want to put it.
alwayzbroken
Quote from: Hyena on February 08, 2007, 07:29:29 PM
I am trying to remember how to figure that out. Its killing me, I know that I know how to do that. Awwww screw math.
inmyownsummerami
Thats 15.2727272727 Gallons.
36"*14"*7"=3528 cubic inches, divided by 231(the number of cubic inches in 1gal.)=15.2727272727gal.
WHITE WHEEL ROCK CRAWLERS "If your wheels ain't white, they ain't right"
:greengrin:My 1st Gen. Toyota SAS (2wd to 4wd) :greengrin: (In Progress)
RIP "Goody Goods" My DDW Brother
alwayzbroken
Damn that was easy. I thought you had to use calculus but I just realized that all the sides were given  :hammerhead:
Yota4life
A stock toyota tank holds 17gallons so that would be big enouph id say.
sweet, thanx Dane!  when you gonna have your truck driveable?
Quote from: Yota4life on February 08, 2007, 08:32:45 PM
my stock one holds 19, extra cab hahaha.  but i probably won't notice the loss of 4 gallons.
gotrocks
wow I didn't realize that the stock ex cab tank held that much.
inmyownsummerami
Quote from: Hyena on February 08, 2007, 08:34:01 PM
I got my IROKs on tuesday, and my wheels should be here tommarow. Im finnishing up converting my 2wd transmission to 4wd so it shouldnt be long till its driveable, but then theres all of the crap like the belly pan, cage, rewire the whole truck, propane to replace the carb etc...etc...etc...
