1990 4runner Build (3RZ Swap)
Started by lilbuddy, September 09, 2009, 09:07:30 PM
emsvitil
Why weren't the 2wd 4runners called 2runners?
:slap:
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
Steve97TJ
Not gonna lie, never been a fan of the 2nd gen runners, BUT ive been a huge fan of all your other rigs so im jacked to see what you do with it. Good luck and do work man.
98 Taco
97 TJ
Stephen from SC
Call Sky Chris... I had to.
I almost garuantee its on its way.
86rustbucket
man your fast, my projects on hold while i save up for a u-bolt flip kit
Quote from: 86rustbucket on September 11, 2009, 01:22:50 PM
Make your own... I am.
cost me 25bucks for 4 bolts, 8 washers and 8 nuts and then porb 15 bucks for the two plates
86rustbucket
i was kinda bein a smart :moon: but basically i paid all my bills at the beginning of the month now im broke till next friday, then all i need is a ubolt flip kit to hang my front housing, then assemble the axle, then shock mounts, then brakes then whatever, ijust hope i can finish before you THK because i started 3 weeks ago and already had most of my parts.My first goal was to finish before Blackdog but hes probably got his up at the roundup right now.
lilbuddy
Quote from: THK90 on September 11, 2009, 11:23:01 AM
Didnt come today.. Pissed....
Quote from: Steve97TJ on September 10, 2009, 11:34:48 PM
Thanks dood. Im thinking it should look pretty sweet
RIP Kyota.... you are the man
GET IT!!!
Quote from: lilbuddy on September 11, 2009, 10:16:39 PM
bunk deal.... :/
You have a chance to call them?
lilbuddy
Didnt have a chance... Wayyyyyy too busy all day between work, my "second job" and then coming home around 6 and working on the runna
GET IT!!!
Quote from: lilbuddy on September 11, 2009, 10:19:04 PM
I hear ya..... it's hella exhausting.
glad to see your's turnin out though.
lilbuddy
Quote from: THK90 on September 11, 2009, 10:30:28 PM
Ya dude... Like ive said plenty of times, Im thinking it will be done by next sunday now. Not bad though. Im doin it up right.
GET IT!!!
theoretically i want and think it could be done mid-october.... reality may be more like november....
but things are coming together.
I need this for deer season for sure (oct 15 - dec 1)
but :pokinit: man.... have it done by next sunday... thats kickass.
what you doing in the rear again?
lilbuddy
Allpro 5" rears
Bilstein 12"
6" shackles
Tacoma Rear
4.10
Open
GET IT!!!
yota_krawler
i thought you were getting rid of it? Gald your not.... I know what you mean about being hella busy. I want the IFS gone on my truck but that wont happen for a few more weeks :down:
thegoofster21
Quote from: lilbuddy on September 12, 2009, 09:28:33 AM
Allpro 5" rears
Bilstein 12"
6" shackles
Tacoma Rear
4.10
Open
not goin to weld it?
Quote from: crawlerdad on October 08, 2009, 08:21:17 PM
Any guy who takes his woman wheeling enjoys her. A woman who is owned is left at home to cook, clean, and keep beer cold. So if this offends you you should stop looking and go have some tacos.    :rofl2: And a beer. If your old enough.   :beerchug:   :beer:
04 Tacoma 33s http://board.marlincrawler.com/index.php?topic=61454.0
jmoffroad.com
Allpro 5" rears
Bilstein 12"
6" shackles
Tacoma Rear
4.10
Open
Oh nice!
that should give you a decent stance... i can get ahold of a few taco rears.... so I'd like to see what yours looks like under it before i grab a toyota rear axle to swap under it.
lilbuddy
Yeah Cody im glad I did too. My buddy callen called me gay for sellig it and then the next day at work i came up with the idea to build it on yta axles for now... Kinda stoked. Ill be able to wheel it and take it to the con onece it comes out of my garage which is SICK. Itll be dualed up and all armored and decently built.
Not going to weld. Im going to let my brother take my Audi and ill be DD'ing the 4runner probably. Half the reason I am getting MT/R's
Im stoked to see what it will look Like. I will have 2" wheels with the taco rear. Judging by how wide my Tacoma was with that setup, my runner should look wider since the body i htink is narrower.
GET IT!!!
I am going use a Tacoma Rear too, thanks to you chris! lol
how you going to match the rear.... width wise.
lilbuddy
Not going to match.. Just goin to run it. May do the IFS hub thing later on but for now, whatever.
Got the clutch pedals in, frame ground down (except the bottom), frame plates welded on for steering box, and steering box moved forward. Also got my white face gauge cluster installed.
Got a bunch of pics. The clutch pedal swap was wayyy easy. Took maybe half an hr.
GET IT!!!
thegoofster21
we did the clutch swap in coles truck it is way easy for sure
:worthless:
jmoffroad.com
lilbuddy
Got soooooooooo much done today....
Got the motor tranny and duals in and the area below the runner all cleaned up. Its kind of a mess now but whatever...
TOmorrow im going to try and start it and get it running. ALso cut the holes for the transfercase shifters and then clearance the heater hoses for the rear heat. When thats Alll said and done I may even tear into the rear end. Im almost thinkign about waiting till next week to do all that just so i can get the front end completely done and call it good. Ill probably drill out/cut out the holes for the shackle tubes in the front end. I dont know, well see. Still got a bunch to do. Gotta definitely wire in my stereo and speakers along with the sub wires and stuff. Thats a NEED for sure
GET IT!!!
pedal swap is easier then I thought too.
glad to hear though man.
post them pics!!
I'm at a fricken stand still not having a welder or torch yet :(
chim
Post some pics I want to see those gauges and how you moved the rear heater hoses for clearance!
lilbuddy
having issues with the neutral safety switch... need a wiring diagram
GET IT!!!
86rustbucket
im sure you'll figure it out.... have you thought about next weeks buildup? maybe you could do a frame up resto on an old fj by thursday  j/k
cant wait to see it done
nor-cal yota
Looking sweet, Get some pics posted  about the pedal swap.  I will be doing that soon.  :biggthumpup:
You still need to come by sometine to shoot the bull over some some  :beer:
Talk to ya soon.
Halladay
#56
Quote from: lilbuddy on September 09, 2009, 09:07:30 PM
Yea another build... get over it. Im not letting anyone drive this one so hopefully i wont have to get rid of it! i wasnt going to make a build thread since this is my 6th, but whatever.
ANyway its a 1990 runner
22re
auto
2wd
fully loaded and in good condition
picked it up for $500 on July 1, 09
going to be on toyota axles for now, hysteer, 1.5 spacers, 4.10s, welded, tacoma rear, 4.10s, welded, dual cases with 4.7s, sky crossmember, homebuilt sliders and bumpers, 37" MT/R's on 2" backspace wheels
Goal is to have it done with leaf rears, sas front, duals and 5spd by Sept 26th and wheel the on Oct 3... Im thinking I will have it done easily by the 19th, ive already got a lot done. I could easily have it done this weekend but im just taking it slower than i normally would
within the next year it will be on tons and 42s but i just want to wheel and build the tons over time
You been pullin much snatch in this whip?!
lilbuddy
Quote from: nor-cal yota on September 13, 2009, 02:52:44 PM
Talk to ya soon.
Ill post pics later.... Im beat
Got everything figured out. IT was super easy. I needed to run the auto harness not the manual. Once I swapped it, it started RIGHT up.
Quote from: Halladay on September 13, 2009, 03:28:46 PM
Unfortunately no snatch yet
GET IT!!!
kiyul4130
not trying to be a richard, but did you really need to quote every single picture and his plan on the runner, just for that?
-kiyul-
ECV 7-11
KYOTA FOREVER
lilbuddy
Pics from friday, yesterday and today...
Friday I did a lot of grinding.... it sucked.
Saturday I Got the clutch pedals in, frame ground down (except the bottom), frame plates welded on for steering box, and steering box moved forward. Also got my white face gauge cluster installed. Also got the motor tranny and duals in and the area below the runner all cleaned up.
Today I got the box mounted up, buttoned up the tcases and crossmember, figured out some clearance issues with stuff, got a few holes cut for the tranny and the front case, got the wiring harness from the auto back in, got a new throttle body on, figured out the neutral safety wire, and a bunch of other stuff. Most importantly I got the motor running and it runs great! only got one code and its the o2 sensor not being plugged in. No biggie....
GET IT!!!
