Twisted's 85 EFI 4Runner
Started by twistedtoy92, July 28, 2009, 09:37:34 PM
twistedtoy92
yep! its all the same (case wise) just the rails and forks are different! The fork actually has the shifter seat on it..... :beerchug:
pumkin toy
ok thanks man. I will have to see what i can find. I might end up just buying a kit then because top shift cases are hard to come by around here and if someone does have one they probly wont part it out.
97 4runner Limited
twistedtoy92
yeah they are... luckily i have 4 topshift cases and 5 or 6 forward shifts so my parts are plentyful! :yupyup:
I've got the duals in!!! had to redo my crossmember a bit then I ran out of wire in the miller....    :down:
Trying to get my long slip square/balanced and damn its a pregnant dog......  :maddest: Luckily my driveline i had made for my 84 std cab bolted right up perfectly!!!! might just wait until tomorrow to finish the front driveline after we get more wire instead of using stick... I'm tired!!! Still have to fill it up with gear oil, cut the hole in the floor and install the shifters to make it driveable...  :driving:
pumkin toy
Lucky!  i need some top shift parts.  so did you have to convert both cases to top shift for duals, or can you convert the rear case and leave the front case a forward shift?  I'm just wondering if i need to find two sets of top shift stuff or just one.
97 4runner Limited
twistedtoy92
well you need to find out which series of transmission you have .... R151F?  should be forward shift  so you just need the rear case to be topshift. My runner has the W56 A so its topshift.... I didnt realize it was topshift untill I was getting ready to throw the duals in..... So now I have dual topshift cases!  :driving:  In your case you have 4.7s in the rear so you would need to clearance the top shift fork..... Marlins top shift kit is already clearanced!  :biggthumpup:
well the runner is SLOW........  :yesnod: got it all done except for the front driveline.....  :hammerhead:
pumkin toy
yeah i'm packin an R151F.  I will leave the first case front shift and convert the rear case to top shift.  Probly gonna get marlin's kit.  I dont know anyone around here that has top shift parts.
So do you have dual ultimates now. or just duals?
97 4runner Limited
twistedtoy92
just duals.... I'm still sportin the old AA dual adapter with stock 2.28's...... this is actually the third yota I've had them in too! First in my 84 reg. cab, then the 92 reg. cab (poor yota) :rivers: .... and now the 85 runner.  only trouble I had was shearing the input shaft in the front case... but I wasnt being very nice to it....  :_oops:
I will be doing almost the same setup you have in the 92 (drivetrain wise) when I get rollin on that next summer......  :biggthumpup:
pumkin toy
hey man i rocked the stock gear dual setup for six years in the pumkin!  It worked great!  Its gonna be really nice for both of us to upgrade to the dual ultimates though  :eyebrow:   I'm stoked about that!
97 4runner Limited
twistedtoy92
oh hell yes!  I'm ready for 5.29's and dual ultimates with a turbo transmission and a 7mge..... doved, linked, partial exo..... I'm ready for next winter already! :beerchug:
pumkin toy
97 4runner Limited
Quote from: twistedtoy92 on December 28, 2009, 07:13:28 PM
Check your 92's thread dude.
sloyota
do you need any steel for your exo.i got five 20 foot sticks of 1.75"x120 wall DOM for sale
I'm not responsable for my own action's.
44magnum
Nice Runner man it cool to check out some other Runners
twistedtoy92
Quote from: sloyota on December 29, 2009, 08:12:26 AM
PM me on that one.....
twistedtoy92
Quote from: THK90 on December 28, 2009, 10:03:46 PM
The 92's gettin all the goodies... runner is stayin DD and a very capable wheelin machine :yupyup:
Quote from: twistedtoy92 on December 29, 2009, 07:18:20 PM
I know i posted up something on an R151F for you.
twistedtoy92
#106
Notched a few things off the list.... duals are in and front DL is DONE! Scratched the 8 inch in the back,
-12 inch slip for front DL
-Swap in duals and xmember
-get a set of 12'' Bilsteins for the rear (I mounted my ranchos almost straight up and down last night)
-bumpstops all around
-Move steering box forward 2 1/2 inches
-Install steering stablizer
-30 spline Longs
-Install Marlins HD inner axle seals
-Install my amp/5x7s/6x9s/and get a sub
-Build F/R bumpers and sliders
-Mount set of quick release mudflaps
-Build my other engine: .020 over, new head/cam/valves, 300cc injectors, big bore TB
-Marlin HD semimetallic clutch kit
-Transmission shifter bushings
-New switch for rear window
-Minor fender trimming
-PAINT JOB
Little disappointing though..... I found a HAIRLINE crack in my front crawl box.... I'm sure its from running that damn driveline that kept bottoming out...  :_oops:
Its leaking a tiny bit so I'm just going to run it for a while and keep an eye on it..... I also had to notch the frame crossmember in order to keep the CV from hittin.... Tested it out on the way home and it runs smooth at 70 mph in 4WD. :yupyup:
pumkin toy
Nice! 70 in 4hi is always good, i'm hopin my 4runner will do that too
97 4runner Limited
twistedtoy92
I'm taking it out to Juniper to do a little testing.... Nothin crazy though, I'll try to post up some snow wheelin pics :beerchug:
twistedtoy92
Well a small update: pulled the rear diff to reseal it and found 3 broken teeth on the spiders so it got welded. Installed another heater resister block- all fan speeds work now!!!  :biggthumpup:  Last but not least; dropped my 22re block off at the machine shop to get bored .020 over and torque plated.  :yesnod: :driving:  Going to order my rebuild kit from engnbldr either this week or next week!! Pretty stoked to get the bottom end built then should get the new head in March.   :burnout:   :beerchug:
pumkin toy
Quote from: twistedtoy92 on February 09, 2010, 06:06:34 PM
sweet dude! a working heater and new engine is always good!
97 4runner Limited
pretty much a new rig, dope show bro.
NITE KRAWLERS
Sometimes life is a rock an we need a Yota to get over it an Chevy is like a rock so I'm over it!!!
twistedtoy92
hell yeah...... its gonna rock for a lil 22re!  :yupyup: Getn engnbldrs RV Street head with the crawler cam, OS SS valves, blah blah, my intakes already ported, getn a Big Bore TB, new TPS, new 200-300cc injectors (havent decided yet), electric fan, EGR block off, dual row timing chain setup... oh and a killer paint job  :psss:
If all goes as planned and depending on shipping, I should have the bottom end built before march.
:beerchug:
Quote from: twistedtoy92 on February 15, 2010, 11:07:59 AM
:beerchug:
damnnnnn, get it dyno'd!
twistedtoy92
twistedtoy92
Quote from: THK90 on February 15, 2010, 11:58:51 AM
I might, after I get the new header and exhaust done on it.  Wonder how much hp/trq I can push with that simple little setup....   :think:
pumkin toy
Quote from: twistedtoy92 on February 16, 2010, 09:55:25 PM
i'm gonna guess 140 hp and 145 trq.
97 4runner Limited
95SAS
:beerchug:
you're going to love that cam, that's what I've got in mine... I love the performance and it really makes my yota sound like a tractor at low rpms LOL   :thumbs:
1986 extracab, SAS 38.5's Locked Duals, truggyfied, beadlocks
1988 2wd bagged and body dropped 3'' with a healthy 22r....
my build
http://board.marlincrawler.com/index.php?topic=35602.0
