Twisted's 85 EFI 4Runner
Started by twistedtoy92, July 28, 2009, 09:37:34 PM
twistedtoy92
Quote from: pumkin toy on April 26, 2011, 08:47:16 PM
yeah i would say so! haha       hey man sorry i havnt sent you the pic of that flat pitman arm yet.  I keep spacin it out and i'm felling kinda shitty tonight so im not going to go out and get a pic.   hopefully i will get you one tomorrow..... are you in a hurry for it?
yeah no big hurry, its going to be another two months before I get the engine built unless I get that insurance check pretty soon. Whenever you get a chance, I need to set up another paypal too, I havent used mine in a long time and dont remember my login :pokinit:
Quote from: THK on April 27, 2011, 08:06:15 AM
i dont think any toyota wraps up that high stock.
i wanna hear some videos. lol
you gonna put the stock exhaust on it?
I've had mine over 6200 a few times.... Its got a pacesetter header, 2 1/4'' to a flowmaster 40 series back to a 2 1/2'' tip. It breaths nice :beerchug:
I was going to post up more pics but I was tired as hell last night, I started working on the front hanger yesterday.. I'll post up later
twistedtoy92
well i picked up some metal Monday and got this done
Pressed out old stock bushings
twistedtoy92
I'm gonna have my buddy machine four 3/8'' thick spacers for me to install on the upper shackle bolts to even the shackles up with the chevy spring width.
All that is left with the rear is:
-Install Marlin spring perches
-Finish welding up shackle hangers and rear frame boxing
-Setup/install bumpstops
-Install spacers for shackles
-Install Bilsteins
-Trim fenders
-Tub inner fenders
twistedtoy92
Well I've been extremely busy at work with a few major in-frame engine jobs so I haven't touched the runner for a few weeks. But I will get a nice chunk knocked out these next two weeks.
I got my pistons, rings, rods/mains/thrust bearings (clevite), LCE Pro Torquer Cam and adjustable cam gear ordered so the engine work should progress quite nicely this next month as well! Hopefully I'll be able to drive this thing sometime mid July... but we will see what life throws at me!
:beerchug:
pumkin toy
97 4runner Limited
twistedtoy92
oh i did start on the rear fender trimming and body work, had a nice chunk of bondo and some rust to cut out. its gonna be fun finishing that :pokinit: up... also a pic of the 5/16'' thick SS spacers for my shackles my buddy machined for me.
twistedtoy92
Quote from: pumkin toy on May 29, 2011, 12:38:24 PM
hopefully you get the time to build that engine man!
yeah once I get the bearings and pistons I can mock up my block and see how much I want to deck then send it back over to the machine shop.
twistedtoy92
few updates, got the front hanger built and installed, moved the front axle forward a few inches
twistedtoy92
front will level out just right once I get the engine dropped in. Stay tuned, this project just got kicked into high gear :yupyup:
twistedtoy92
Quote from: THK on June 10, 2011, 10:36:55 AM
that hanger is obnoxious lol, looks good though man.
i know what you mean.... but itll look way better once I get the front bumper incorperated into it :yupyup:
pumkin toy
97 4runner Limited
twistedtoy92
thanks man! thats about as low as I can go with the leafs..... :yesnod: should be nice and stable. I got the flat pitman arm in the mail today, thanks a ton for that!  :biggthumpup:
twistedtoy92
I should have my block back from the machine shop along with my rods mid next week then I can start assembling the engine. Shouldn't be too much longer and it will be running order  :yesnod:  still another month or so until all of the axle stuff will go in but I need some road time anyway to break the engine in before I take it out for a true shake down  :eyebrow:
(Engine Stuff)
-LCE Pro Air Intake kit
-Big Bore TB from LC
-NGK Iridium spark plugs
-NGK wires-Dist. cap & rotor
-LCE spark plug wire bracket
-Alt. belt & P/S belt
-Fuel filter-180 thermostat
-Radiator cap & silicone hoses
(Steering Stuff)
-Drill and tap box for hyrdo-assist
-8'' travel hydraulic ram, hoses and mounting brackets
-3/4'' heim joints and hardware
-1 1/2'' .250'' wall DOM
-Marlins 25mm hardware
-ARP knuckle studs
-ARP hub studs
-Longfield 30 spline
twistedtoy92
Got my block, crank and rods back from the machine shop finally....:woohoo: Everything looks really good! I havent had time to touch it yet, too damn busy at the shop... havent had a day off since a few weeks ago so I am taking tomorrow and monday to relax then I'll get my engine built next weekend and finish up all the welding and whatnot on the front end before I put the engine in... Hopefully a couple more weeks and I'll actually get to fire this thing up :crossed:  :driving: :burnout:
twistedtoy92
should be picking up an MC07 R10 XD 23 spline adapter brand new in box for $200 next paycheck... Can you say SCORE? :yupyup:
twistedtoy92
well I went out to check out the runner and think about further progress today on my smoke break when I noticed someone backed a truck trailer into my rear tire..... Just about punctured the tire and took 1/16'' out of the wheel.... Moved my runner about 2 feet... this is $376.91 for the rubber and $59.95 for the wheel.... Im pretty sure I know which customer backed into my rig, I will find out and get a new tire/wheel.  :down:
WOW someone needs to learn how to drive of give up the driver seat
Zs Confederate Toy
Dude that sucks. I would hate to see that on my smoke break
ZACH
87 Rock Rat X
80 SR5 The Shady Lady
Trail Junky
86rustbucket
Ouch!    I guess the "sorry note" with his insurance info must have blown away in the wind.  :dunno:
twistedtoy92
Yeah that's not how Id like' to spend my smoke break on a Saturday morning after working for free for two days....  :maddest: My service writer is supposed to get a hold of the guy today and figure something out... On the other hand though I made some progress on my engine today, crank is in and all 4 pistons! Pistons sit .006'' above the block deck at TDC which is exactly where I calculated them to be :greengrin: happy about that! The machinist took .014'' off the block to achieve this.
twistedtoy92
reason for .014 off? i know its to achieve .006 above the deck with the pistons at TDC.
reason is? :]
Zs Confederate Toy
Looks good. I am gonna be doing this same thing here soon.
ZACH
87 Rock Rat X
Trail Junky
twistedtoy92
Quote from: THK on August 08, 2011, 07:22:40 PM
reason is? :]
Yes, raise the compression. :yesnod:
Quote from: Zs Confederate Toy on August 09, 2011, 02:05:04 PM
Thanks!  :greengrin:
I got a little bit done today, gasket matched/ported the intake ports in my head and cleaned it all up . Tomorrow I am going to paint my block, install my LCE pro rocker shafts and new Toyota rocker arms with new adjusters, LCE Pro torquer cam, LCE adjustable cam gear, ARP head studs, factory Toyota head gasket and get the head torqued down. After this happens things should progress quite nicely! Should have the engine finished sunday evening then next week I will hammer out all my grinding and welding on the frame. Then the LCE 35 lb flywheel, Marlin SHD Ceramic 1800 lb competition clutch bolted up and engine dropped in. Wanna have it running by the 20th-21st.... just gotta bust ass on it!
:beerchug:
thats awesome dude. you dont mess around. whats the compression gonna be?
twistedtoy92
Thanks! Should be around 10/10.25:1 compression... I got the block painted and the timing cover painted... Didnt touch anything else..... I'm a little wore out, a lot of big engine work lately at the shop.....putting main/rod bearings and an oil pump in a Cummins ISX.... Mains are almost 4'' in diameter..... Ill post pics up later...
twistedtoy92
didnt touch it tonight.... to much damn work to do and its burning me out. Not going to get rushed on building this engine. here are a couple pics:
Zs Confederate Toy
ZACH
87 Rock Rat X
Trail Junky
