Twisted's 85 EFI 4Runner
Started by twistedtoy92, July 28, 2009, 09:37:34 PM
twistedtoy92
Quote from: Crunchy Taco on March 23, 2015, 07:42:04 AM
Hey twisted I found a holset h1c I believe is the number for a bill. What size is that particular turbo? Is it to big for my rz?
If its a 50mm but will support up to 400 hp no problem. Little brother to the hx35.
http://www.d-series.org/forums/forced-induction/120686-holset-turbo-specs-hy-hx-h1c-wh1c-h1e-wh1e.html
twistedtoy92
Got the front shock hoops burned in and shackle spacers installed...
81 shortbed
twistedtoy92
Thanks buddy! Sorry about the shitty cell phone pics, my lens is all scratched to hell...
Nation
twistedtoy92
Quote from: Nation on April 17, 2015, 09:55:32 AM
nice flex!
Thanks buddy!!! Been chippin away at small stuff this week, working on the wiring and whatnot... Hopefully fire this thing up by the 4th of July... Have another yota project on the burner that I have been gathering parts for.  My 78 is getting a 4g63 mated to either a w59, w58 or w55 2wd transmission and an 8'' 3.90 spooled rear end. Have the complete engine, eagle H beam rods, light weight flywheel, wiring harness, couple turbos to choose from... Should be pushing 500+ rwhp in a 2200 lb pickup...
Crunchy Taco
98 Tacoma ex cab, Garrett T3 turbo 7psi, w56, 2.28 duals, ceramic sprung puck clutch, toyota solid axle, Tacoma rear axle w/ e-locker, plated frame front and rear, fuel tank raised with custom armored cradle, 1 ton steering 35" general grabbers wheeler/DD built from stock http://board.marlincrawler.com/index.php?topic=95652.msg1066733#msg1066733
twistedtoy92
HAHA! My thoughts exactly... Decided to cut the tranny tunnel out, built a new crossmember with FROR's custom tcase plate, now its totally flat bellied. I just have to finish up the mounts on the frame then I can close up the tunnel and redo my drivelines.  All suspension, engine, and tranny mounts use the large poly bushings to ease with replacement.  After that's wrapped up I will tackle the rest of the wiring tuck and throw all the engine accessories on, bolt up the factory fuel tank for the time being, mount my batteries, bolt up the exhaust and fire the beast up.  I'm managing the shop now so shits been pretty crazy lately... But there is light at the end of the tunnel as I have been slowly turning less wrenches and will be hiring another tech, so I will have much more motivation/time to work on my own stuff again. :beerchug:  I really need to get a new phone and/or camera to take some decent pics of my progress...  Also, we are getting the JD2 model 4 bender and tube notcher so bumpers, cages and sliders will be a breeze!!! Stay tuned...
twistedtoy92
progress
twistedtoy92
Almost have the intake finished, supra alternator swap, slap the header on, bolt the fuel tank up wire up the battery and finish up wire tuck odds n ends... Getting close to starting it up finally, its been far too long!!! Bought all the remaining engine parts this week so its just a few man hours after work.
OVRAROK
right on, ive been watching this build. been thinking hard of flat belly, any inspiration(pics) would be greatly appreciated. have you tried posting from tapatalk, pics may be bigger
Crunchy Taco
right on. can't wait to see the progress on this one.
twistedtoy92
I picked up an fj 80 hp 4.10 front diff and will be ordering 30 spline RCV front axles soon.
twistedtoy92
twistedtoy92
#406
twistedtoy92
Ordered a set of 37x12.5x15 Maxxis Creepy Crawlers!!! should be in next week :beerchug:
twistedtoy92
BUDDERS
My boss recently told us that our 8 man staff is short 6 people for the amount of work we have in our area and for the last year he's been on us about O.T. hours!  He should be  :smooch: our butts and praising us.....
twistedtoy92
relocated and got another job.... hopefully be up and running before i die of old age...
Quote from: twistedtoy92 on June 21, 2017, 11:03:03 PM
where you at now?
twistedtoy92
i'm back... stay tuned!
Toy(Yota)
Looks so good! Can't wait to see it all together
1985 4runner, 88 body, trussed, locked, single 4.7s and twin stick. Cool paint and 35" Baja Claws
