Twisted's 85 EFI 4Runner
Started by twistedtoy92, July 28, 2009, 09:37:34 PM
twistedtoy92
Finally wheeled this thing into the shop last night and worked on it till 3 AM. Got alot of the frame cleaned up, pulled the front axle so I can reseal it, install new heavy duty seals, 5th stud and ARPs then burn some tube on it and mount the steering ram. Built the steering box mount all heavy duty beef status and the steering shaft from my 89 fits PERFECTLY. Pretty happy about that. Finished one motor mount and halfway tigging the other one up. Hopefully have the engine dropped in next week and build the shock hoops and engine cage. Stay tuned!
twistedtoy92
Finished up the other motor mount and ordered up 7/8" chromoly heims with high misalignment spacers and 3/4" hardware for my steering linkage. I planned out some more tubing and figured out the hydraulic ram mounting situation. Also got all new knuckle stud hardware and HD axle seals.
Sent from my C811 4G using Tapatalk
twistedtoy92
Few small updates.
Motor mounts
Steering parts
Cleaned up the frame
Shaved sheet metal
And a little sneek at what has been keeping me from the runner
twistedtoy92
Welded up the Heim Steering last night. Got too late so I only burned them on one pass w/o rod. I'll go over them again with rod and fill it in smooth. Really diggin the TIG machine at work, getting better all the time :beerchug: Should be ordering up Marlins 25mm steering pins next check along with the ARP's.
:beerchug:
twistedtoy92
#334
Got my oil pan ready for the turbo. -10AN for the return and welded in a drain plug on the bottom because I hate the one on the side you can never get all the oil/sediments out!
Nation
twistedtoy92
Getn ready to order this badboy!
http://www.diyautotune.com/catalog/megasquirtpnp-g2-t8590-for-the-8589-toyota-4age-and-22re-p-503.html
Also have a line on a tial 44mm wastegate, Mitsubishi 450cc injectors and a 4'' aluminum plenum to weld up to the lower stock plenum, and possibly an LS1 101mm throttle body...
I have a 56mm HX35 turbo, LCE header flange and a box of SS 90 degree elbows for the manifold so I can start building that soon. I'll get this thing pieced together by the new year hopefully. I cant wait to have a boosted yota! :beerchug:  :burnout:
Nation
twistedtoy92
Gathering parts
twistedtoy92
Here is the turbo size. Gonna be running a true hx35 holset.
Nation
Beer, swishers, food, and a turbo..... that's a party!   :boozer:
Crunchy Taco
Just found this. Next time you better tell me u got a hidden 22re turbo thread!
98 Tacoma ex cab, Garrett T3 turbo 7psi, w56, 2.28 duals, ceramic sprung puck clutch, toyota solid axle, Tacoma rear axle w/ e-locker, plated frame front and rear, fuel tank raised with custom armored cradle, 1 ton steering 35" general grabbers wheeler/DD built from stock http://board.marlincrawler.com/index.php?topic=95652.msg1066733#msg1066733
twistedtoy92
Hell yes!!! Its like a secret hidden level on Super Mario Bros! Lmfao!
twistedtoy92
Pans on, rear main done, 35 lb flywheel's on, Marlins 1800 Super HD Ceramic clutch installed, intake installed, injectors installed, custom motor mounts installed, just need valve cover gaskets and my water pump and its fully sealed. Going in after work, dropping it in and finish up frame sides of the mounts.
twistedtoy92
One frame mount done... Picked up my turbo as well.
Nation
Crunchy Taco
Hey you made your motor mounts the same way I did on my cousins 2rz swap. It's actually a really easy awsome way to do them.
twistedtoy92
Hell yeah! I actually cut a set of old boomerang shackles up to make them... worked out nice, every piece of suspension and drivetrain will utilize 18mm greaseable hardware for simplicity :biggthumpup:
twistedtoy92
I'll be hitting this hard after deer hunting. I am determined to get this thing running by the new year... Getn tired of saying it and not happen....
Nation
Quote from: twistedtoy92 on October 14, 2014, 03:12:13 PM
MMMHMMM.......     :cheese:
twistedtoy92
N/A this year, turbo'd- by next summer... Boss let me keep this in the shop so I can get it rolling...
Crunchy Taco
Nation
twistedtoy92
twistedtoy92
Nation
twistedtoy92
Marlin 25mm Pin Upgrade on order today boys n girls :yesnod: I ain't fawkin around anymore.
twistedtoy92
Nation
twistedtoy92
Look what was waiting for me when I showed up to work this morning! Also got brake lines mounted in the engine bay to my fj80 master and engine is officially bolted in to stay!
